Old 04-12-2010, 11:56 PM   #1601
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Daverods project 66
probably should have ordered it from AVS. We got a new CNC at work other one was having some problems so we have to set it up and play with it.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-16-2010, 10:00 PM   #1602
bubba327
HOW long until spring??
bubba327's Avatar
Dave -where did you finally set your timing at with the new HEI? What is your plug gap setting ?
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 04-16-2010, 11:44 PM   #1603
daverod
SSN 706
daverod's Avatar
I set my plugs at 45. I think my timing is at 8. I was moving it around to see what it did. I was kinda amazed at how much I could move it and it would still run about the same. Let me know what you set yours at.
daverod is offline   Reply With Quote
Old 04-16-2010, 11:53 PM   #1604
daverod
SSN 706
daverod's Avatar
Got my brackets for my bags. Put everything together. Watched it go up and down and up and down. Need to hook up two more lines for my rear.
Old 04-17-2010, 12:08 AM   #1605
bubba327
bubba327's Avatar
Be careful watching that up and down stuff.
Old 04-17-2010, 12:15 AM   #1606
daverod
SSN 706
daverod's Avatar
Your just not kiddin. It pretty easy to forget that the frame hits the ground and smashes everything in its way.
Old 04-19-2010, 09:09 PM   #1607
RMrider17
Looking Good Man
-Adam
RMrider17 is offline   Reply With Quote
Old 04-19-2010, 09:54 PM   #1608
ruffrida2005
I dont know what your problem is Dave, but I haven't see a pic of the front laying frame yet.
Pics of it didn't happen.
Paul
Old 04-20-2010, 12:10 AM   #1609
daverod
SSN 706
daverod's Avatar
My front tires/wheels are to big. I have a 17" rim and the tire height is 30" they hit my cab. The tires on my 64 are only 27 " tall. If I stand on the cross member it's about 1" from the ground. Figured out why my upper arms where hitting the frame (post 1514). No shims. Need to get some 15" rims and different tires. Guess I'll pull my cab off and paint my frame next.
Old 04-20-2010, 12:21 AM   #1610
watahyahknow
watahyahknow's Avatar
seen photos of wat people did to there cabs to get 22 inch rims and tires to fit
they cut out the piece hitting the tire and weld in a piece of trailerfender , works quite good actually
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 04-20-2010, 12:26 AM   #1611
daverod
SSN 706
daverod's Avatar
I guess I better good measure some tire wheel combos. I was thinking I would do 18 or 20's.
Old 04-25-2010, 09:57 PM   #1612
daverod
SSN 706
daverod's Avatar
Put my engine on my frame. Tested out the front bags. Everything worked good. Pulled the oil pan off my 64 and changed the gasket. What a pain in the butt.
Old 04-25-2010, 10:37 PM   #1613
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Alan's Classic is offline   Reply With Quote
Old 04-25-2010, 10:58 PM   #1614
daverod
SSN 706
daverod's Avatar
Made a little movie but could'nt get it to load. You have to go to my photobucket. It under 66 chevy .http://s697.photobucket.com/albums/v...hevy%20bagged/
Old 04-25-2010, 11:13 PM   #1615
bubba327
bubba327's Avatar
Hey what it that blue oval doing parked in the driveway? Your garage is much to clean .. No wonder you get stuff done. I spend way to much time looking for the parts I just set down and now cant find..... Your Frame looks good laying down on the slab!
Old 04-25-2010, 11:22 PM   #1616
daverod
SSN 706
daverod's Avatar
I knew someone would say somthing, Plan is to trade it for a s10 then put a 51 on it. Don't tell the wife it's hers and she doesnt know the plan.
Old 04-25-2010, 11:34 PM   #1617
shrunken66stroker
shrunken66stroker's Avatar
Nice work daverod. Let's see some real progress now that the weather is getting nice.
shrunken66stroker is offline   Reply With Quote
Old 04-26-2010, 10:18 AM   #1618
daverod
SSN 706
daverod's Avatar
I think real progress is linked more to money then it is to the weather. But it is nice to see summer. Least I get to drive my 64 .
Old 04-26-2010, 01:52 PM   #1619
shrunken66stroker
Good point. I guess I get a little lazy when it's "cold" outside. You know, down in the 50's.
Brrrr.
Old 04-26-2010, 02:21 PM   #1620
ruffrida2005
Hey Dave you need a s10 frame I got one, It's just the frame. you will have to come and pick it up though.
The frame looks good.
Paul
Old 04-26-2010, 04:47 PM   #1621
daverod
SSN 706
daverod's Avatar
Thanks but I think the gas would kill the deal. You could bring it up here it though. Put it in the back of a 2 1/2 ton and tell them you need to do a road test. We use to go get fire wood that way till we rolled one off the side of the road. Told the CO someone hit us in the parking lot.
Old 04-26-2010, 07:07 PM   #1622
ruffrida2005
that's funny man. It's not that easy any more.
Paul
Old 04-28-2010, 07:59 PM   #1623
daverod
SSN 706
daverod's Avatar
Ordered a trans cross member from brothers. Thinking about getting a quart of por15 for my frame? Don't know if I'm rich enough for the por15? Feeling kind broke this month.
Old 04-28-2010, 08:06 PM   #1624
scotts62
One day...
scotts62's Avatar
Yeah im with you there dude
Scott
93 crew cab build
Project 62
Old 04-28-2010, 08:08 PM   #1625
Strodder
Daring to be Different
Strodder's Avatar
When you use the POR-15 make sure it's in a clean environment because it dries very show and will collect dirt. Especially in a dry climate. Where it's humid it dries faster. And mix it really good to get all the deposits from the bottom.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
