#1602 |
Next project: 1970 K10
Re: Glock's new project: "Fred" w/ 5.3L LS swap info
Hehehe...
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#1603 |
I have car A.D.D.
And around here the WINNER is.......BOB!
![]() Looks like good progress Bob. I see you were using your flash in those pictures, good plan. ![]()
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
#1604 |
I think that is about the old ride height!
#1605 |
You are using an OE radiator, correct?
I swear this question was asked, and answered, in this thread someplace but I can't find it now. My crewcab needs a new radiator, bad, but if the stock one isn't swap-friendly I'll patch it up somehow for the time being. I bought 1972supercheyenne's extra harness the other day. Even if I ain't in the game yet at least I'm AT the game. |
#1606 |
Yes, the OEM radiator is very swap friendly. When you do get your engine, if it's not a super high mileage one, be sure to get the upper rad hose too. Since the donor truck's upper rad hose is in the same position as the OEM rad, it's a direct fit.
Pull up a seat and grab some beer. With all the GenIII swaps going on in here right now, it's a great game!
#1607 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
I am totally loving all the Gen III swaps going on around here. Cant wait to see progress of youre D.FENS
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. Last edited by STOCKISH; 04-07-2010 at 09:29 PM. Reason: Cant spell |
#1608 |
Hey Bob, I'm sure it's mentioned somewhere in here, but I'm too lazy to dig through 41 pages to find it lol.
What size tires you running and how far have you dropped it? |
#1609 |
65 pages, but who's counting?
![]() BFG 275/60-15 all around on 15x8 wheels. Cut one coil from the front, and removed the second leaf from the bottom in the rear. Front and rear springs are original as far as I know. I'll probably cut another 1/2 coil from the front here soon. It has right at 1-1/2" rake, which leaves almost equal space front and rear from the top of the tire to the edge of the wheel well. I want that gap in the front to be slightly lower than the rear.
#1610 |
Haha, 41 pages if you have 40 posts per page lol.
And thanks, that's close to the stance I've been thinking I want, but wasn't sure on exactly how much to lower or what tire size I'd need. |
#1611 |
truck looks great, I have to say I will be using alot of info from this build. Its nice to have someone to learn from but I wish there was something I could find that hasent been done before.
Project "Abby" 84 swb 6.0 swap and rebuild. http://67-72chevytrucks.com/vboard/s...d.php?t=395121 |
#1612 |
GM Addicted
where did you get that a/c line crimp tool at and where can you order your own hoses for the a/c??
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#1613 |
Never Satisfied
I see it totally different. I am rejoicing in the hundreds of dollars I'll save by having someone like Bob and others who has been there, done that. Show individualism in paint or in your choice of wheels. Hats off to ya Bob.
1973 4x4 Blazer- Parting Out 1986 LWB Silverado Undergoing LQ4/4L80E Swap '86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566 Last edited by bigdnew; 04-08-2010 at 09:27 AM. |
#1614 | |||
#1615 |
GM Addicted
thanks man when you use the tool please post it up with detail how you ordered all the right fittings and all that. Because i want to change to a serpatine system on my truck and dont want to pay to get the lines done.
#1616 |
Honestly, if your lines are in good condition (soft and pliable, not hard and un-flexible) doing what you want to do would move the compressor from the drivers side to the passenger side, correct? All you would probably have to do is cut the hoses to the right length, and have two fittings crimped on. In your case you would be using the same compressor (most likely). You would cut the aluminum lines at the compressor manifold leaving an inch or two. Then you would solder these on to the aluminum lines:
![]() That would solder on to the aluminum lines at the manifold, then install the hoses and crimp. I would bet you could find a local hydraulic shop that would crimp them for next to nothing, if not free. Which is what I am doing with the large line that runs off of the accumulator. I'll cut it, solder on one of those ^^^ on, then crimp on the hose that runs to the compressor.
#1617 |
GM Addicted
actually my truck has the larger style compressor and the serp system that im going to use takes the smaller version and does move it to the passenger side. I will be using a serp system off of a 94 chevy pickup. I also wanted to see if they had steel braided ac lines.
#1618 |
great info once again. THANKS BOB!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#1619 |
hey guys, I read on another forum of guys having problems with the russell quick connect fitting coming off, which I thought they were
![]() its snapped off,,,
ONCE YOU GO LS, YOU NEVER WANT LESS!! ![]() Last edited by fpjr0; 04-09-2010 at 07:08 PM. |
#1620 |
the one on the fuel rail?
#1621 |
yeap... that one... kind of sucked being watch by 1/2 the neighbors lol
ONCE YOU GO LS, YOU NEVER WANT LESS!! ![]() |
#1622 |
![]() you got the tranny fixed?! ![]()
#1623 |
yeap.. the problem was the guy sold me a 2008 tranny knowing I need it a 2005 , then it worked just fine for a couple of hundread miles then it burned,,, the junk yard owner sent it to a independent transmission shop with the understanding between us that if it was the wire harness(which I modified) I was going to pay for the repairs, but if it was the transm. because being newer he was going to take care of it, = I didnt pay a thing and they even installed a high performance band and corvette servo...
ONCE YOU GO LS, YOU NEVER WANT LESS!! ![]() Last edited by fpjr0; 04-09-2010 at 07:28 PM. Reason: cant spell |
#1624 | |
I thought about this when I was hooking it back up last weekend after swapping to the braided hose. That's quite a bit of weight hanging there. I might make a little bracket of some sort to support the weight that's being put on that fitting.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 04-09-2010 at 07:59 PM. |
#1625 |
i was thinking the same Bob. i'm going to see if i can mount the line on the firewall some how just for support.
