Closed Thread
Old 02-08-2011, 12:20 AM   #1601
MadDog
1970 GMC
MadDog's Avatar
Re: What did you do to your truck today!
installed the head light bezels on my 70 GMC, bolted the bed to the fram, and took the tailgate handle out of my old bed so i can get it painted to match the new tailgate..
MadDog's Website
MadDog is offline
Old 02-08-2011, 12:52 AM   #1602
ItsRandy
ItsRandy's Avatar
Sanded my frame. My finger tips are sore!
ItsRandy is offline
Old 02-08-2011, 02:05 AM   #1603
project 67 sub
project 67 sub's Avatar
adjusted the pb panhard bar and threw a quick crappy paint job on my glove box door will redo it better later. and took a couple of pics of the clearance of the pb bar and brackets just perfect lol. and also took a pic of the part of the rear brake line that i can see from underneath.
project 67 sub is offline
Old 02-08-2011, 04:10 AM   #1604
BadaSs_Cal
BadaSs_Cal's Avatar
Starting to make my intake shiny.
66 Gmc 1 ton. Long Step 351e V6
69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil
61 Shortbed Fleetside 1/2 ton.. in progress
Next a 50-53!
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=447926
BadaSs_Cal is offline
Old 02-08-2011, 09:30 PM   #1605
ramey
71' Custom 10 (ole blue)
ramey's Avatar
Cool Re: What did you do to your truck today!
stole a q-jet from my uncle today. he knew i was gettin it, he's got twenty layin around. gonna rebuild it tomorrow n put it on the 69, n ima take the holley off and throw it as far as i can!
GM Goodwrench 350
Turbo 350 Transmission
ramey is offline
Old 02-08-2011, 09:53 PM   #1606
60ratrod
yes, i do
60ratrod's Avatar
hey just send it to prostreet. he's a holley guy. otherwise it isn't even worth the effort to me to throw a holley. EDELBROCK
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline
Old 02-08-2011, 10:30 PM   #1607
Dano69c10
Dano69c10's Avatar
Removed the trailing arms off of my rear axle, luckily no issues.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline
Old 02-08-2011, 10:42 PM   #1608
glider_6969
Tonight I installed my new overflow bottle that I picked up at an Auto zone for about $10 bucks with the bracket,for the radiator. I was debating on were to mount it. I think I found a good spot. I made a bracket that wraps around the battery and bolted it to the rad support, then mount the bottle bracket to it.
glider_6969 is offline
Old 02-08-2011, 11:37 PM   #1609
ItsRandy
ItsRandy's Avatar
Sanded my frame. Did I tell you my finger tips are sore?
ItsRandy is offline
Old 02-08-2011, 11:42 PM   #1610
67chevy1series
67chevy1series's Avatar
started making my buddy bucket seat adjuster lever since when i bought my seat it was broken! so any one who wants to make on you will need :
one 8'' or however long or short you want it rod 1/2 inch thick round stock rod
and a grinder with a 80 grit sander to make it nice and smooth after you grind it down
and a torch to bend it how ever you want and some bolts i am thinking a 3/8th or 5/16 th bolts and nuts
67chevy1series is offline
Old 02-09-2011, 02:33 AM   #1611
project 67 sub
not a whole lot but i repainted my gauge bezels and started installing them in the cluster. now i need to buy the rest of the gauges so i can finish it, and also make/cut out a piece so i can install my gas gauge and turn signal lights in the cluster.
Old 02-09-2011, 02:33 AM   #1612
project 67 sub
Old 02-09-2011, 11:35 PM   #1613
Keller
Keller's Avatar
I tracked down a ground issue and got it to start!
Keller is offline
Old 02-10-2011, 12:00 AM   #1614
RickBost
RickBost's Avatar
I got the truck to run under its own power for the first time since i onwed it and now the tranny is bad. I am still trying to figure out if a t-10 will bolt to and use the clutch from the m-20?
72 GMC Jimmy 8" lift 38" super swampers
77 GMC C15 High Seirra Short Step lowered 6/8
http://67-72chevytrucks.com/vboard/s...53#post8999053
1972 Plymouth Roadrunner
2005 Cadillac Escalade
2014 Ram Ecodiesel
RickBost is offline
Old 02-10-2011, 01:14 AM   #1615
mcmlxix
Collector of Projects
mcmlxix's Avatar
I picked up a set of Hummer H2 chrome rims and tires for $200...
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Old 02-10-2011, 01:50 AM   #1616
project 67 sub
i installed my sun visors back in the burb
Old 02-10-2011, 02:04 AM   #1617
ItsRandy
ItsRandy's Avatar
I picked up a small soda blaster to finish cleaning my frame, it works real good and my fingers won't be sore anymore.
ItsRandy is offline
Old 02-10-2011, 02:42 AM   #1618
blazerboy_4life
70Custom10
What did you go with and how well does it work?
blazerboy_4life is offline
Old 02-10-2011, 07:22 PM   #1619
67Slider
67Slider's Avatar
I took the day off from my real job and installed 3 inch drop coils up front, shock relocation kit in the back, double adjustable panhard bar, new shocks(front and back) and 5 inch drop coils in the back. Also checked and filled my rear diff. Took about 5 hours but was well worth it. I love the new stance. I will post up some pics this weekend.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 02-11-2011, 01:02 AM   #1620
ItsRandy
ItsRandy's Avatar
Found (bought) a right AND a left big block motor mount stands today. I got one (the left) from a Chevy dealer in Costa Mesa, California for $108.00 and the right from a Chevy dealer in North Carolina for $60.00. I feel blessed.
ItsRandy is offline
Old 02-11-2011, 02:08 AM   #1621
project 67 sub
not much of an update on the burb but i did pick this up out of a jeep for it lol. and also picked this up for my beetle for $100.
edit: also purchased a 3rd door sill plate from sharpie
Old 02-11-2011, 02:35 AM   #1622
70chevykidd
70chevykidd's Avatar
Loosened up the starter while laying in a puddle of freezing water and snow lol and started to figure out how i'm gonna put my buckets in and what seat covers. Leaning toward some mr.horsepower ones for $20 new
70chevykidd is offline
Old 02-11-2011, 02:24 PM   #1623
AustinScott
AustinScott's Avatar
I took her out and picked up a fridge.
This was her first haul since I dropped the rear. She did fine!
AustinScott is offline
Old 02-11-2011, 10:20 PM   #1624
ItsRandy
ItsRandy's Avatar
Harbor Freight, it holds 40lbs of baking soda and it works great. I used it for about an hour and got as much done as I did the previous 8 hours. There are places I was able to get clean (paint and grime free), like around rivet heads and where brackets are attached to the frame, that I wouldn't have been able to get to with sand paper. WEAR A RESPIRATOR IT IS VERY DUSTY!
ItsRandy is offline
Old 02-11-2011, 11:40 PM   #1625
sjarrett71
sjarrett71's Avatar
Tried to install my new turn signal switch but it was messed up from the manufacturer. Hopefully I can fix it myself and get it in tomorrow.
-Scott-
sjarrett71 is offline
Closed Thread
