02-13-2011, 11:33 PM | #1651 |
Re: What did you do to your truck today!
Painted 1/2 of my frame today.
02-14-2011, 12:35 AM | #1652 | |
RAT1968 '68 Cab/'71 Parts
wire with the ends cut on the bias and pressed in with a touch of glue. The logo is my motorcycle "club"...a sticker reduced on th e printer, cut out and glued to the black face of the aftermarket tach.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 02-14-2011 at 12:41 AM. |
02-14-2011, 12:42 AM | #1653 |
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
02-14-2011, 12:59 AM | #1654 |
I fixed my squeaky clutch pedal - I ended up having to pull the dash to get at the top hinge, but it doesn't squeak now - very nice.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
02-14-2011, 01:10 AM | #1655 | |
Craig |
02-14-2011, 02:11 AM | #1656 |
70Custom10
I ordered Aluminum valve covers for my new motor that should be done next week!
02-14-2011, 04:25 AM | #1657 |
installed the rear bags and lines, aired it up and set it on the ground. then i moved the jack stands to the front, so i can tear it apart in the next couple of days or so to do the front bag and drop spindle install. also installed the chrome exhaust tips.
02-14-2011, 05:56 AM | #1658 |
Words under my name
Changed out water pump due to bad bearing, and turns out the water pump was for a 69 corvette??? brought old one with me and matched up. Replaced while it hailed on me on Saturday night...and replaced both belts. Need to replace pump pulley since that happens to be the cause of my screech when I rev it. After work it will be replaced. And then put it all back together. oh yeah...got the driver door to lock now.
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project. 2010 VW Golf, daily driver Wrench Rookie Last edited by steelscout; 02-14-2011 at 06:37 AM. |
02-14-2011, 01:28 PM | #1659 |
Replaced my heater blower, since it wouldn't work while working in Louisianna for a month, while they had the rainiest/coldest Jan on record. Fogged up windows the whole time. Checked fuses,switch, voltage at blower connector, all good. Replaced motor, No work. Tapped the ground wire above motor with screw driver, works great. Anyone need a 40 yr old working blower motor. Also installed my licence plate frame to rear sport bumper. Still need to buy light for it. CHeck your grounds. Jim.
02-14-2011, 08:55 PM | #1660 |
wire wheeled and grinded down the a arms, want to get them sand blasted before paint and reassembly. gonna go back out and start tearing apart the front end in a few minutes
02-15-2011, 12:47 AM | #1661 |
Rebuilt the upper and lower control arms today, became a man in the process.
Posted via Mobile Device |
02-15-2011, 03:15 AM | #1662 |
got one side of the front end all torn apart, need to do some cutting on the spring pocket tomorrow, gonna be cutting out the top for air line, valve, and bag bolt access
02-15-2011, 03:52 AM | #1663 | |
Kill Bill...et
02-15-2011, 04:56 AM | #1664 |
yesterday
tonight
Always remember those that had your back Never forget those that turned it Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt, Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner |
02-15-2011, 05:01 AM | #1665 | |
oh for sure i will be posting pics, will most likely, (later), run the valves right directly at the bag port, and the line straight into that with no elbows lol. can you say fast haha. edit: ah i have seen that too, but it wont work for me lol. that and i am trying to be a little different Last edited by project 67 sub; 02-15-2011 at 05:05 AM. |
02-15-2011, 03:24 PM | #1666 |
Installed new Eaton posi unit with new bearings.
71 C10 2WD,472 Big Block Buick B4B Intake,800 cfm Q-Jet built by(Fred Catlin) Comp Cam 254/268@ .050 .530/542 lift 1 7/8 supercomp headers, 2 1/2 X-Pipe/ Magnaflow's Mallory fuel system Igniter Flame thrower Ignition system TH350,Hughes 3500 Converter ,3.73's Its just an old heap, but its my hot rod! |
02-15-2011, 06:28 PM | #1667 |
New oil pan gasket, and bolts a 700r4 up to my 250. All it took was some blood,sweat, lack of sleep and help from zip ties and all thread!
1968 Chevy c10. CPP drop and disc brake conversion. straight six 250/powerglide. YUP!!! truck club |
02-15-2011, 08:48 PM | #1669 |
[QUOTE=mcmlxix;4488882]Ordered my Art Carr shifter....
I like it..
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
02-15-2011, 08:58 PM | #1670 |
nec absolutum
sent my 96 to the transmission shop and ordered the new filler neck grommet for the new gas tank on the 69...
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants."~ Thomas Jefferson 1967 GMC C1500 LWB 250/3 on the tree- 1969 Chevy C/10 SWB 350/TH350 1996 Chevy Silverado LWB 350/4L60E 1997 Chevy K2500 350/4L80E |
02-15-2011, 08:58 PM | #1671 |
Collector of Projects
[quote=trkfrk;4489107]Thanks.. they joke it looks like an old arcade game joystick.. but I plan making this work anyway....
02-15-2011, 09:01 PM | #1672 |
looked for a lt1 for the 67 swb then blocked out the tailgate for 72k10 cause this guy keeps telln me my bed sides are gona start slaping around if i dont get one on soon
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
02-15-2011, 09:47 PM | #1673 |
The Niner
Got my steelies back from the painter (nice and white) and ordered my tires (Michelin LTX M/S2 265/75/16) today.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
02-15-2011, 09:52 PM | #1674 |
yes, i do
looked at a 67 chevy parts truck that a guy is parting out and is going to let me have the front end sheet metal for only $50! so my 72 gmc will get the nice sleek look of a 67.
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
02-15-2011, 10:36 PM | #1675 |
vw guy & now c-10 guy
finally removed my old cracked windshield!
