Old 06-25-2013, 12:19 PM   #1676
doubleb's69
doubleb's69's Avatar
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by Dieselwrencher View Post
Yes sir, Bud did a great job! I think my brother wants him to do some on the Vette now..............
You got my number!
Bud
doubleb's69 is offline   Reply With Quote
Old 06-25-2013, 04:04 PM   #1677
6lcummins
Originally Posted by ryanroo View Post
fed ex ups and usps too, as much crap as we send back and forth...
seems that there is some more iron in the back of my truck labeled for iowa
That door looks awesome. excellent work Bud
I heard someone is going to have to free up some vacation time to get said iron.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 06-25-2013, 04:15 PM   #1678
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Last night I finished up my new trans cross member, and this morning I mounted it on the truck. I had Nick help me hold up my last cross member and we got it tacked up. I welded it in place and started welding my spacers for the trans cross member on the frame. Nick cut the pieces we needed to modify the radiator support some more. He ground the surfaces and marked them, and I welded them in. We still have to build some reinforcing plates to help stiffen the support up. Tonight I'm going to build the trans mount, and in the morning I'll weld the tabs to the cross member. The heat and humidity is here too by the way!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-25-2013, 08:00 PM   #1679
ryanroo
ryanroo's Avatar
well just have to see who it is. ill be motoring through there sometime in the fall with my big white **** missile, so ill be available to drop it then provided plans dont change...
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 06-26-2013, 12:58 AM   #1680
6lcummins
Ryan
That would work, but I know I want to make a trip to wyoming sooner than later but have to see if my planned trip to Canadia goes through.
"STOCK"
ASSEMBLY THREAD
Old 06-26-2013, 01:52 AM   #1681
coggonobrien
transfer case crossmember looks like its much more pleasant to install then the stocker
coggonobrien is offline   Reply With Quote
Old 06-26-2013, 06:53 PM   #1682
Dieselwrencher
Yes it is!
Okay, some more progress. I got the trans mount installed and welded the tabs on the cross member for it. This is the first time since I ripped this truck apart that it has had a trans cross member and mount bolted in it!
Nick made great progress on the core support. Gussets are welded on and the intercooler clears the hood latch now! Tomorrow he'll finish the lower intercooler mounts and bolt the upper portion to the support.
I removed the rear end from the chassis so I could finish welding everything up on the rear axle. I only have 2 more welds to complete on one air bag mount, and I have to make some boxing plates for my panhard bracket and weld them on, and then the rear end is done. I have to finish my upper panhard bracket, weld some holes on the bottom of the frame, extend the frame at the back so the bed has a place to rest evenly, and then clean up some welds, and paint the frame. Getting closer.....
Ryan
Old 06-26-2013, 08:53 PM   #1683
ryanroo
ryanroo's Avatar
Lookin good! what do you have to do to your piping?
72 K20 12v build
Old 06-26-2013, 09:26 PM   #1684
brimc
brimc's Avatar
This is a great build. I read this thread on and off for awhile now but found myself re-reading the whole thing again. I can't wait to see more!
The orange looks great. I really wish you could find 67~72 body's that clean around here. Keep it up!
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 06-26-2013, 10:26 PM   #1685
Dieselwrencher
I have to lengthen the LH CAC pipe now that we moved the IC farther down. Maybe I'll get lucky and the silicone hose I use will make up for it. We shall see.
Thanks. This truck has transformed to a complete new truck, and I've had 2 different manuals, an auto, and this is the third engine. Haha The body was pretty rough when I first got it. There are only 2 panels original to this truck, and that would be the doors.
Ryan
Old 06-27-2013, 01:19 PM   #1686
Mattman2010
Mattman2010's Avatar
Looking good bud! Cant wait to see this thing in a week hopefully!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 06-27-2013, 03:19 PM   #1687
6lcummins
So far I had to lengthen the driver side pipe 3.5" since that's how far I dropped the CAC to clear the hood latch assy.
"STOCK"
ASSEMBLY THREAD
Old 06-27-2013, 04:02 PM   #1688
Dieselwrencher
Today I cut the rest of my small pieces I needed and ground them and fit them. Then I welded them all up. I finished the 2 pieces on the rear end as well. I have 4 pieces I'd like to add to the frame and then I have to finish welding some holes up on the bottom rail, and it'll be time to clean up all the welds and stuff.
Nick made the lower intercooler mounts last night and installed the intercooler this morning. He then cut the LH pipe and started fitting a new piece in there. Tomorrow we'll finish it up.
Ryan
Old 06-28-2013, 11:53 AM   #1689
Str8-6-68
Str8-6-68's Avatar
Sweet progress Ryan, the build is looking really good now. ill have to remember to mount my intercooler low the first time or just stick with my water/air cooler under the hood.
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube.
68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd.
Str8-6-68 is offline   Reply With Quote
Old 06-28-2013, 02:36 PM   #1690
doubleb's69
One week!
Bud
Old 06-28-2013, 03:48 PM   #1691
6lcummins
Originally Posted by doubleb's69 View Post
One week!
Zip it.... lol
"STOCK"
ASSEMBLY THREAD
Old 06-28-2013, 05:19 PM   #1692
Dieselwrencher
Thanks. Yeah, I should have built a different support, but no time for that right now.
One week!
Yeah, we're feeling the heat!
Ryan
Old 06-28-2013, 05:21 PM   #1693
Dieselwrencher
Nick got the LH intercooler pipe completed this morning, and I installed 2 gussets on the frame and finished up some welding. Tomorrow the work begins to get it running............
Ryan
Old 06-30-2013, 10:30 AM   #1694
brimc
brimc's Avatar
That IC pipe turned out awesome. Was it Mig or Tig welded together?
BRIAN
Old 07-01-2013, 02:48 PM   #1695
6lcummins
Mig welded and then ground down.
"STOCK"
ASSEMBLY THREAD
Old 07-01-2013, 03:17 PM   #1696
Dieselwrencher
Well we made good progress, but never enough if ya know what I mean. Ran into some issues, but it is back as a roller and.................................It Runs!!!!
We got the frame painted. This was the first time I've used the POR-15 chassis paint, and I'm not real pleased. The gloss black por-15 lays down a lot nicer than this. We'll have to second coat this later. We cleaned up welds and sanded/cleaned the frame and rear axle.
Ryan
Old 07-01-2013, 03:50 PM   #1697
woodwright
Enjoying left field
woodwright's Avatar
You're not gonna put a stack on it are you?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 07-01-2013, 04:31 PM   #1698
brimc
brimc's Avatar
I thought so . I have always had trouble miggin pipe. Once I learned tig it is much better. Problem is I don't have a tig at home.
That pipe work looks awesome!
BRIAN
Old 07-01-2013, 04:34 PM   #1699
6BT 56
6BT 56's Avatar
Ya got to love it when they start to look loke trucks again . once they make noise then you really get stoked . Truck looks awsome . You have come so far ! Running well ? I'm no fan of POR 15 my self. I hear of lots of people that swear by it but I ask my self if they really put some mi on it after . I used it on my hwy tractor after giving the frame a quick touch with the blaster . I actually drove it and put 100,000 mi on it and the paint was done in 6 ish months . No match for a Ontario winter I have spots on the truck that were done with trimclad yars before and they are still holding up better than that stuff .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 07-01-2013, 04:38 PM   #1700
brimc
brimc's Avatar
That frame looks good in the pictures. I do agree with you on the POR top coats. It does not lay down like the rust paint. Next time you use it, or if you do another coat you could try this....
I set the paint can in hot water for a bit before I was ready to brush it. The heat made the paint "thinner" and it flowed much better with "less" brush marks. If you don't want to use the can you can pour small amount into a cup and try.
Truck looks and "sounds" great. Keep the updates coming!
BRIAN
