#1701 |
Lucky Teter at the wheel
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
I shot the last coat of primer at 5 this afternoon, then wet-sanded with 600 grit, prepped and ready to shoot. Don't forget to run a TACK CLOTH over everything right before you shoot.
Another trick if you see a speck of dirt or fuzzy while you are spraying is to half pull the trigger and only shoot air out to try and blow the speck off the panel. This only works of course if you haven't already stuck him with paint.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#1702 | |
#1703 |
Oh heck, who am I kidding. I finished this too tonight.
#1704 |
VA72C10
![]() Join Date: Mar 2008
Looks great! Getting really excited to see this beast together!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#1705 |
Moderator
![]() Join Date: Jun 2008
He practically did. Nice Job...which is an understatement. You have to be as proud as (or close to) the day you had your first child.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
#1706 |
67cheby
![]() Join Date: Sep 2008
man ....you are the KING of GARAGE PAINT !!
#1707 |
Houston, we have a problem.
Giant run on one rear side and orange peel all down the other upper side. Looks like a redo tonight. I'll tape off everything else that looks good and be able to really concentrate on just the upper sides. I was feeling the pressure last night of so much stuff to paint at once.
#1708 |
67cheby
cant you just wet sand that out ??
#1709 | |
My shop teacher in high school used to do that. He would build hydraulic log splitters and the metal shop students would do the welding of the frames, the small engine shop students wouild rebuild the motors, and he would make the money! Smart guy!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#1710 |
Yep, and I could then buff it down and pray I don't burn through the paint anywhere - or - since it is all taped up and so easy to spray....
The problem with counting on buffing is if you do burn through, you have to go back and completely retape/cover everything, blah, blah, blah = Nightmare.
#1711 |
67cheby
makes sense !
#1712 |
Still Learning
It's a real fine line between perfect wet coat and running on the floor. Sorry to see this happen to ya. Hope you have better luck on the second try.
#1713 |
Ever tried to walk the edge of a razor blade????? Its about like that.
#1714 | |
PITbut
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! ![]() My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
#1715 |
I dnt know if this is ur first paint job or not but don't be scared of wet sanding and buffing. Especially a run cuz you've got to keep in mind that there's already to much paint there anyway. If you put three coats of clear on it you can do alot of sanding and buff before you burn through. Just my. 02 though.
Posted via Mobile Device |
#1716 |
Chevy Enthusiast
^ Single stage, not base coat clear coat.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#1717 |
![]() Join Date: Mar 2011
Drew, have you ever used a painter nib file, their about 1-1/2" square and look like a file. Go over the run and it cut them down little by little, most paint supplies have them. I've also used a single edge razor blade, hold with both hands and drag over the run, it will also cut it down. Then wet sand and buff....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#1718 | |
#1719 |
I think Drew has got this guys....The proof is in the pudding, as one might say. Drew you are making great progress and I could only hope to be as detailed on my build as you are with Young Frankenstein. Can't wait to see this beast together. I log on everyday just to see the progress. Keep up the hard work.
71 Ol' Blue: http://67-72chevytrucks.com/vboard/s...d.php?t=474752 Carving the Jake-olantern: http://67-72chevytrucks.com/vboard/s...d.php?t=679537 |
#1720 | |
![]() Join Date: Aug 2010
Jeff 1972 Blazer CST 2wd- My son Sam's Project "S" Project "S" 1970 Suburban - SOLD "One Bad Burb" Photobucket Album 1986 C30 Crewcab - 63K original miles, original paint Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP... |
#1721 |
![]() Join Date: Jul 2010
pudding..where
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
#1722 |
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#1723 |
6>8 Plugless........
![]() Join Date: Sep 2007
Hey, at least it was only on the upper areas! I hate it when you are spraying a long and then come back and see it ran! I tend to spray heavy and have to learn to walk away.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#1724 |
looks sweet keep it up
old school like your mother..... My Build--- Body dropped 67 service truck http://67-72chevytrucks.com/vboard/s...d.php?t=485504 |
#1725 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Drew keep up the good work its almost there...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
