03-30-2007, 07:02 PM | #151 |
Re: Who has Impala SS rear disc brakes ??
how many sets are you gonna make? I would like to get a set.
03-30-2007, 07:47 PM | #152 |
Next project: 1970 K10
As many as I need to make.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
03-30-2007, 08:00 PM | #153 |
The brackets would be for putting together a 'kit' utilizing Impala rotors w/F-body (LS1?) calipers w/a parking/emergency brake correct?
If so.... I would be interested in a set.
04-01-2007, 02:07 AM | #154 |
SCOTI - You are correct, and I will add you to my list. Thanks!
04-01-2007, 03:47 AM | #155 | |
What about PBR calipers for the front? Has anyone researched this......
04-03-2007, 02:15 PM | #156 |
SCOTI, the calipers with the built in e-brakes are the LT1's, the LS1's use the hat style e-brake like the Impala's.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
04-03-2007, 02:51 PM | #157 |
Thanks Chris! I must have glazed over the LT1/LS1 part.
04-03-2007, 03:38 PM | #158 |
Has anyone came up with p/n's for the brake lines,rotors,calipers etc...just to make it a little easier. I have 4 wheel drum 6 lug, I looking at a rolling 71 frame for the 5 lug set up, I should be able to use the axles from it for the rear right??
Is it cheaper to go Camaro or Impala calipers???
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
04-03-2007, 07:23 PM | #159 |
Which one does everyone use, LT1 or LS1 style?
04-03-2007, 08:08 PM | #160 |
If the LS1 is like the impala ss you would need the backing plate to use the e-brake.
04-03-2007, 08:54 PM | #161 |
Used Register
What is the rotor diameter for this setup (Impala calipers) and how far would the caliper rise beyond the rotor? Trying to figure out the wheel needs.
Herb |
04-04-2007, 12:11 AM | #162 |
No prob Bob. I had to ask Brett about this since he's the authority on LT1/LS1 brakes after doing the swap on his car.
If it were me I'd probably use the LT1 stuff, although Brett says he heard they need regular use to stay adjusted like the Caddy calipers.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 04-04-2007 at 12:13 AM. |
04-04-2007, 12:29 AM | #163 |
I'm still on the fence on which to use for my own truck I will probably go with the Impala since I don't need an e-brake, and I like things simple ya know........
04-04-2007, 12:40 AM | #164 | |
I almost never use the e-brake, and i figure i could always install a line lock for the rare occasion that i need to.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
04-17-2007, 11:08 PM | #165 |
OutOfMyMind & I'llNeverKnowWhy
you could always install the camaro ones and not hook up the e-brake. Then if you ever had too, you woulnt have to pull the brakes off to swap parts.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
01-03-2008, 02:18 AM | #166 |
Classic Chevy Recycler
those look great. If I can't get my buddy to fab me some I would like to get a set as well.
2004 Chevrolet Trailblazer EXT 1970 Chevrolet C50 1979 Chevrolet C30 Need another 67 or 68 soon... |
01-05-2008, 04:52 PM | #167 |
Just to make sure, this setup will work on 73-87 12 bolts?
01-05-2008, 05:05 PM | #168 |
Active Member
Hey Ram-Man did you use a nut as a spacer? I am getting ready to install mine in the next couple of weeks.
01-06-2008, 08:41 AM | #169 |
To bad no one is making a replacement flange so you could bolt up the impala drum in hat e brake
For the six luggers you can use a 88-93 front chevy truck 4x4 rotor take it to a machine shop and have the hub hole cut out bigger I know this works cause I did a disc brake swap on my 97 and used impala rotors and the kit says if you have six lugs use the 88-93 4x4 fronts and have them modified, I beleive tsm manufacturing sells them already modified for you
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
01-06-2008, 09:01 AM | #170 |
Truck and auto performance nut
I didn't see a price for these brackets (must have missed it)....but I'm interested!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
01-06-2008, 09:48 AM | #171 |
glock35ipsc has em' $50
01-19-2008, 10:25 PM | #172 |
New to this board and its a great site . I have a 67 C 10 project truck , I'm wanting to put disk on but its 6 lug and I already have the wheels . Toya rotors I think will work but will have to get machined down but son works at machine shop . I need the Camaro caliper mount specs or the mounts cause I want the e-brake . Glad you guys help alot
01-19-2008, 10:59 PM | #173 |
tommypic, I just sent you a PM.
01-20-2008, 12:51 PM | #174 |
Thanks, good to know. As soon as I get my other chassis home and start the build...I'm going to get a set.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 01-20-2008 at 12:52 PM. |
02-11-2008, 11:37 PM | #175 |
is this the caliper mount I need 94-96 Caprice 9C1 Impala SS rear disc caliper brakets ? found em new for 40.00 good price or not ? going to use caprice rotors too
