Old 06-12-2007, 04:46 PM   #151
56chevy1300
56chevy1300's Avatar
Re: My Project 56Chevy1300
Had some time to finish my airbag cutouts. Also bought a fuel pump, brake calipers and a a power brake booster and master cylinder from CPP.
56chevy1300 is offline   Reply With Quote
Old 06-13-2007, 06:14 PM   #152
texascowboy593
texascowboy593's Avatar
Nice progress!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 06-25-2007, 10:05 AM   #153
tiggerstoy
tiggerstoy
tiggerstoy's Avatar
love the progress...on another note, my band will be playing the urban lounge( the one on whyte) we are called Smart-Alex...will be there by 7pm,come on down with some pic's, and i'll buy you a drink....if you can.
oh ya.....it's on the 4th, hope you can make it......max.
tiggerstoy is offline   Reply With Quote
Old 07-15-2007, 09:29 PM   #154
56chevy1300
Hi Tigger, sorry I missed your gig, hope it was a good one, I haven't been to the urban lounge for several years!!!
Old 07-15-2007, 09:33 PM   #155
56chevy1300
front suspension starting to come together.
Old 07-15-2007, 09:38 PM   #156
56chevy1300
On the advice of Poncho Villa, I sent my old steering box to Randy at Steering Solutions, he sent me a completely rebuilt box.
Old 07-15-2007, 09:39 PM   #157
jkaylor68gmc
jkaylor68gmc's Avatar
You have done a really nice job, kudos, hope it continues to go well. It is going to be one awesome truck.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 07-15-2007, 09:43 PM   #158
56chevy1300
1) Picked up a Flaming River u-joint; 2) Mating the stock Trans Am shaft to the '81 GMC van column; 3) 10 bolt Camaro rear axle w/342 gears.
Old 07-15-2007, 09:45 PM   #159
56chevy1300
Hey thanks, jkaylor...Truck Builder rocks!
Old 07-15-2007, 10:19 PM   #160
56chevy1300
Another pic of the steering shaft...any advice would be appreciated (angle, length, etc.)
Old 07-15-2007, 10:31 PM   #161
1-ton of fun
polishing a turd
1-ton of fun's Avatar
you may need to start over with the column linkage. it looks like you need two u-joints to get the shaft to line up, and some cut to fit DD shaft. with two u-joints, i would have a bearing on the middle section of shaft (many people use a big heim for ease of fabrication)
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 07-15-2007, 10:58 PM   #162
56chevy1300
Thanks for the feedback. I have seen many setups with 2 u-joints. What is the main reason for using 2, is my angle too great?
Old 07-16-2007, 09:55 AM   #163
1-ton of fun
polishing a turd
it just looks like it doesn't line up to bolt together. if it does, then i don't think the angle is too bad.
Old 07-17-2007, 08:45 PM   #164
56chevy1300
You are correct, 1 ton of fun, the u-joint binds, so I think I do need 2 u-joints.
Also, how is the column attached to the firewall? Is it welded, or is it just clamped? Feedback please and thank you!
Old 07-18-2007, 11:05 AM   #165
pgf545
pgf545's Avatar
56, I just pulled the column out of my camaro and it has a plate the is attached to the column and the is bolted to the firewall. I haven't done the truck yet so I am not sure what I am going to do on that.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 07-18-2007, 12:30 PM   #166
1-ton of fun
polishing a turd
i would bolt it, in case it would ever need to be serviced in the future. i try to design my stuff so i can work on it easily for maintenance and repairs.
Old 07-18-2007, 02:26 PM   #167
CAL 58 GMC
CAL 58 GMC's Avatar
Hey 56, The angle on mine is close to what yours is. I did use 2 joints and a double D shaft. I did not use the rag joint at the steering box. Here's a few pic's.
CAL 58 GMC is offline   Reply With Quote
Old 07-18-2007, 02:38 PM   #168
OrrieG
OrrieG's Avatar
Borgsons web site gives some good info on where and how many universal joints you need. I'm getting ready to tackle mine and have figured I would need one at each end with a slip joint in the middle because based on previous experience with 4wd the cab and frame will flex when off-road.
OrrieG is offline   Reply With Quote
Old 07-18-2007, 07:16 PM   #169
56chevy1300
Thanks guys. Hey Cal 58, did you install a vibration dampener as well?
Old 07-18-2007, 07:17 PM   #170
56chevy1300
Also Cal 58, how did you attach the bottom u-joint to the steering box? Thanks!
Old 07-18-2007, 07:19 PM   #171
56chevy1300
How do you suggest I bolt my column to my firewall, keeping an asthetically pleasing both in the cab and in the engine compartment?
Old 07-18-2007, 08:58 PM   #172
CAL 58 GMC
CAL 58 GMC's Avatar
No, I did'nt use the dampener. I can fill a small amount of viberation in the wheel but nothing really bad. I still might put the dampener in later. The bottom u-joint is attached to the steering box and then to the double D shaft. If you in need of a double D shaft let me know, I have a new one that was powder coated I would let go real cheap.
Old 07-19-2007, 12:41 PM   #173
1-ton of fun
polishing a turd
i'm using one of these, and making a plate to cover the factory hole:
http://www.flamingriver.com/index.cf...rod/prd169.htm
Old 07-19-2007, 03:09 PM   #174
56chevy1300
I've looked at those floor mounts...doesn't it need to slide over the column from the bottom? Would my shift link on the bottom of my column get in the way?
Old 07-19-2007, 05:17 PM   #175
1-ton of fun
polishing a turd
yes, i am trying to figure out how to disassemble the column linkage to get it on there
