12-20-2007, 11:01 AM | #151 |
Never Done?
Re: Thrash 2007: Will I drive it to the board meet?
hahaha, oops. Guess I don't know my stuff after all. I had remembered it the other way around! Hrmm.. guess I'll have to cut on the bedsides instead (*edit* or measure my axle and see if it's 71-72 already), especially when the rear discs go on. The "hats" on the rotors are thicker than the drums (I think I might need longer wheel studs actually), which pushes the tire out further, if ever so slightly. The joys of off-the-shelf wheels with only one backspacing available!
12-20-2007, 11:59 AM | #152 |
Adam..... Share the specs on the wheels/tires. They look great! Maybe I'll try that 'reverse bait & switch' & get some discounted wheels for myself .
12-20-2007, 12:08 PM | #153 | |
Never Done?
It looks a little funny with the front wheels pulled in from the fender so far and the rear wheels right up against the bedside, but for the money I won't complain. And it might look better out in the sunlight where I can get more than a few feet away and take it all in. Yeah, I got a great deal. There's no way I would've been able to afford these otherwise. It wound up I paid approx. $140/wheel shipped. The luck ran my way this time around! |
12-20-2007, 01:24 PM | #154 |
BlahBlahBlah
Im surprised the fronts are pulled in. I thought when you put a disk brake conversion on 67/68 it actually widened the front track.
12-20-2007, 02:47 PM | #155 |
It does.
12-20-2007, 04:40 PM | #156 |
Never Done?
Ok, at any rate, I measured my axle (best as I could) on Ethel tonight. Considering I got over 57" backing plate to backing plate (it was hard to read it lying on my back under my aired out truck), I'm thinking I have the 71-72 (wider) axle under there right now. Once I can get her outside and get some help measuring I'll know for sure.
And the fronts aren't pulled in all that far really, just looks that way compared to the rear. My front wheels and tires are the same as member "see ten", so you can see his truck for how they look on a static-dropped truck. Last edited by Alvin; 12-20-2007 at 04:40 PM. |
12-20-2007, 06:10 PM | #157 | |
Village Idiot....
Adam, If that is the rear end that came with Ethel, it came from a 72 (or so the guy I bought it from told me) at any rate that might help with your answer.
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
12-20-2007, 06:39 PM | #158 |
Never Done?
Thanks Keith! At least my suspicions were correct, I have the wider axle. I'll do some measuring once the bed is bolted down and hopefully 3/4" on each side will remedy the problem.
12-21-2007, 04:31 PM | #159 |
Never Done?
01-01-2008, 03:42 PM | #160 |
BlahBlahBlah
You have those new wheels and tires ready to go and mounted yet? I wanna see, I wanna see...
01-01-2008, 03:45 PM | #161 | |
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
01-02-2008, 12:48 PM | #162 |
BlahBlahBlah
Hey those look great. Hmmm and the pictures look familiar. I must have seen em somewhere on here. Im drawing a blank...Seems to be happening more and more
01-09-2008, 05:27 PM | #163 |
Never Done?
01-09-2008, 06:00 PM | #164 |
Texas Big Wig
Sweeet bro !!!
You HAVE to get this thing to the board meet THIS year bro !!! |
01-09-2008, 06:23 PM | #165 | |
Never Done?
Thrash 2008: Will I drive it to the board meet?
01-09-2008, 06:31 PM | #166 |
Texas Big Wig
Yeah, well it'd be nice to get to drive it a lil bit before the meet lol
I can't remember how many days I had driven my truck before the meet, but it wasn't much lol |
01-09-2008, 07:35 PM | #167 |
1969 Short, Fleet, and Beat
Alvin get back to work. I want to see pics of that truck out on the road. *****in truck!!!
01-10-2008, 03:49 PM | #168 |
Never Done?
Not much new tonight. I got the other rear brake rotor painted.
And a look at how Ethel sits right now: In somewhat exciting news, a friend at work has a milling machine and would like to prototype some billet aluminum hose clamps off of my truck. With ordering the water neck and hoses this weekend, hopefully I'll have the clamps before spring gets here! |
01-30-2008, 05:41 AM | #169 |
Hot Rods For Life
Truck is looking awesome
01-30-2008, 11:29 AM | #170 |
Never Done?
Well I started laying out my gauges on the bezel to see how they'd all fit. Now if I could just figure out the best way to cut on that expensive piece of plastic!
Here are the gauges, Stewart Warner Power Series. When I saw they were available with the light blue ring in the center I had to have them. Bought a sandblasting cabinet this past weekend and have cleaned off quite a few parts with it (the glass broke on it tonight... guess I have to work on it now too). Remember those nasty brake calipers from a few posts up? I took one apart and threw it in the blasting cabinet to see how well it cleaned up. Now if the weather would break I could spray some paint! Also got a bunch of new parts in the mail. Radiator mounts and hoses, caliper rebuild kits, rear caliper hoses, and e-brake cables. |
01-31-2008, 03:08 AM | #172 |
Please keep us posted on the gauges. Those the same set I was interested in.
Wheels look great. |
01-31-2008, 03:16 AM | #173 |
Just here to help
i can't wait to see it in person at the meet this year
01-31-2008, 03:23 AM | #174 |
Insert Title Here
coming along great
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
01-31-2008, 05:09 AM | #175 | |||
Never Done?
