Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-01-2007, 11:18 PM   #151
Re: 68 K-10 SWB build thread - project Money Pit...pics galore!
That cab fit right on there,huh?That`s a 5' wide trailer,right?
Old 07-01-2007, 11:25 PM   #152
msgross
msgross's Avatar
I think so...just like you said it would Tim....... yur smart!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-02-2007, 02:39 AM   #153
GREASEMONKEY72
GREASEMONKEY72's Avatar
some nice progress since the last time i saw
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 07-02-2007, 08:38 AM   #154
msgross
msgross's Avatar
thanks... I had to rush and get it together so that I could move it back to my house. I was paying $120/month in rent to be in a big "group" garage....That starts adding up fast.
The Garage:
Old 07-02-2007, 02:23 PM   #155
bdozeraz
bdozeraz's Avatar
Originally Posted by msgross View Post
My "made in India" mounts are going right back to NAPA and they can kiss my "made in Indiana" butt!
I'll try a set from autozone or go with energy suspension. I think that they have a set for this truck....
What is everyone's thought about the tranny mount bushings and torque arm bushings being a size larger than the bolt. The outer brackets are the the right soze so it seems like energy did it on purpose.... maybe they want to allow for slight movement or the bushing is just needed for "crush" resistance?
Get the energy suspension mounts. I went through the same thing. I went to 4 different auto parts stores and they all had the same india mounts with the metric thread.
about your drive line being offset the drive trains usually are offset to the passenger side about 3/4" to 1" for brake booster clearance and extra foot room for the driver.
Your tranny mount bushings sound like all the ones I have ever used. They allow a little bit of play so you can line things up. There should be a sleeve that goes through the bushing that the bolt goes through.
bdozeraz is offline   Reply With Quote
Old 07-02-2007, 03:05 PM   #156
msgross
msgross's Avatar
The sleeve is what I meant to say was larger than needed. 1/2" bolt and 9/16 or 5/8 sleeve??? The top and bottom metal brackets are drilled for 1/2" though??
So the mounts are metric? that would explain why it slipped.... I'm taking them back and will order the energy one's... what a PITA!
thanks.
The Garage:
Old 07-19-2007, 09:59 PM   #157
deer slayer
when you painted your frame what ratio did you use did you thin the primer too any particular brush you suggest
deer slayer is offline   Reply With Quote
Old 07-19-2007, 10:39 PM   #158
msgross
msgross's Avatar
They don't recommend thinning at all...so I didn't. The primer sealer is pretty thin but covers in one coat, the paint was a little thick though. I used a good foam brush (lowes, wal-mart etc...).
The Garage:
Old 07-20-2007, 05:35 PM   #159
deer slayer
so how many coats did you put on did you use the wole quart and the pint
Old 07-20-2007, 05:40 PM   #160
msgross
msgross's Avatar
2 coats of each (primer and paint) and covered the frame, crossmembers, axles, springs with 1 1/2 quarts of each.
So I needed 4 total quarts, still have 1/2 quart of each left and spent $100 on product and about $20 on brushes. Be sure to buy dishwashing gloves cause this stuff doesn't come off for a week once it's dry! Cleans up with mineral spirits for about an hour, recoat within 48 hours.
The Garage:
Old 07-20-2007, 06:10 PM   #161
deer slayer
you recommend getting the frame blasted or just wire wheel
Old 07-20-2007, 09:16 PM   #162
msgross
msgross's Avatar
I suggest taking as much of it apart if it's as bad as mine was, then getting it blasted ($150-$250). The primer sticks better to freshly blasted metal and it's faster than doing the wire wheel job...
The Garage:
Old 07-21-2007, 06:20 AM   #163
Gets in those nooks and crannies (think english muffins) like a wire wheel can`t.Mike,do you have any prints of your work?It would be neat to make a didplay for Carlisle.Maybe you could get alot of work from it.
No,I was thinking it would be a nice show off of your progress...motivating to have all to see and comment.
Old 07-21-2007, 07:27 AM   #164
msgross
msgross's Avatar
Like I need to work on someone else truck!
The only area that was hard to get to was behind the rear shock mounts. Since I removed most of the crossmembers due to rot it was easy for me.
I could just tow the rolling chassis to Carlisle Tim! j/k
The Garage:
Old 08-11-2007, 03:27 PM   #165
msgross
msgross's Avatar
Well, it's been awhile since I touched the truck. Decided to pick up a new starter ($35) and water pump ($25) and work towards getting the engine fired up again. Painted the new water pump, installed the starter and fuel pump. Next I need to add a Helicoil to the intake so I can get the carb on again and then install my ramhorns. Plan is so blast and coat them but I may get it running first. I'll post some pics tonight...
Oh yeah, I also made a small cart for my cab to move around on. Bet nobody has used 2x6 oak to hold their dolly wheels!
The Garage:
Old 08-11-2007, 11:05 PM   #166
msgross
msgross's Avatar
here's some of the pics from today.... my bad luck had to kick in and the John Deere died on me just as I was starting to mow... spent the entire evening changing battery cables, hope that fixes it....
The Garage:
Old 08-11-2007, 11:13 PM   #167
1969k10stepside
Good progress.I'm almost to the point of no more work on my swb 4wd till paint so I went out and bought another 4wd,a 72 Blazer Yet another project for poor ol' Dustin
Keep up the work Mike!
1969k10stepside is offline   Reply With Quote
Old 08-12-2007, 10:50 AM   #168
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Excellent progress!! Looks great! Keep up the good work.
I built something similar to move my tub around, works great, but I got a little stupid.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 08-12-2007, 11:01 AM   #169
msgross
msgross's Avatar
wow, that's quite the setup... mine is a piece of 3/4 plywood with some 2x6 and dolly wheels.... Figured I could flip the cab on its back and work on it too....
The Garage:
Old 08-12-2007, 12:17 PM   #170
Chevyman63
Chevyman63's Avatar
wow, that's quite the seup... min is a piece of 3/4 plywood with some 2x6 and dolly wheels.... Figured I could flip the cab on its back and work on it too....
Good idea.
I built mine originally to haul my tub home from Iowa and just put 4x4's and wheels under it.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 08-12-2007, 11:57 PM   #171
ChevyDude
I'm sure it's going to be awesome when you finish!!! Looking really good!
Alex
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 08-18-2007, 06:51 AM   #172
72armyswbtruck
72armyswbtruck's Avatar
NIce build thread, can't wait to see the finished project
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 08-18-2007, 08:59 AM   #173
msgross
msgross's Avatar
thanks... there's gonna be a big delay from Oct till April while i'm in Alabama at school... Can't wait to search some lower AL junkyards though (RUST FREE!)
The Garage:
Old 08-18-2007, 11:42 AM   #174
Rust Buster
Rust Buster's Avatar
I was looking forward to doing the same when I was down in training in AL, but when I asked around they all said to bring a big stick to ward off the snakes that are apparently all over those places, and I hate snakes...so I never went.
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 08-19-2007, 02:18 AM   #175
msgross
msgross's Avatar
true, they do have rattlers in that area.... Better wear my leather boots and carharts then...
The Garage:
