Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-22-2008, 11:13 AM   #151
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: "Slowly but Surely" Big J's build thread...
I got the back 4 pieces welded in and the front pieces tacked in. I should have it all welded up and ground down tomorrow night. I'm getting closer to media blasting and primer
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 02-23-2008, 10:40 AM   #152
Big J
Big J's Avatar
I didn't get any grinding done but I did get all the patches welded in including the passengers floor. I started filling the little screw holes here and there too. If time allows I'll get some more done this weekend.....
BAZINGA!
My Build
Old 02-23-2008, 05:06 PM   #153
vtblazer
vtblazer's Avatar
Don't know about yours but the last one I did had over 125 of those "little screw holes" to fill.
Looking great, thanks for the ongoing updates.
vtblazer is offline   Reply With Quote
Old 02-23-2008, 05:58 PM   #154
Big J
Big J's Avatar
Thats alot of screw holes.... I may have 30-40, so not so bad. The worst hole to fill is the one in the fire wall, its more of a rip, can't figure out how it got there. You can see it in the last pic of the passenger floor. Its about 2/3rds up.
Yeah these ongoing updates seem to be the best way to document the build. If I didn't do it this way I'd forget what I've done
BAZINGA!
My Build
Old 02-23-2008, 06:12 PM   #155
jaros44sr
jaros44sr's Avatar
Don't even waste your time trying to figure out why or how the PO did something
Mine used a can opener to run the antenna wire thru the cowl
Did you have enuff bed panel matrl.? Nice work, looks like your wrapping things up
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-24-2008, 04:18 AM   #156
pound41
Excuse my stupidity are you flanging and welding the seams and screw holes or are you butt welding
pound41 is offline   Reply With Quote
Old 02-24-2008, 12:31 PM   #157
Big J
Big J's Avatar
Not a stupid question at all. On the floors it was a mix of butt welding and some flanging. The screw hole are just ground clean and filled in. The bed pieces are all butt welded. It should hold up just fine, I'm going to be media blasting the top side and underside of the tub. Then primering and rubber coating the floor and Por15ing the underside. Should last for years.
J the material was plenty, I have about a 3rd left, unless some other parts go to crap when I hit it with the black beauty, lol...... Its gonna be bright shiny metal when I'm done with it!
BAZINGA!
My Build
Old 02-24-2008, 06:45 PM   #158
pound41
I wasn't sure if you were flanging and screwing to get your fit and then cutting it to butt weld. I have restored many cars and done the bodywork/ paint but i had the welding done by professional. several years I bought a 75 silverado for a worktruck I decided to semi restore and weld in the panels for practice. I flanged some places on the bed and fender. The patches rusted back out and they started on the inside part of the flange opposite the weld. I didn't do anything to seal that area. I am replacing most of the entire front floor area of my blazer the area under the seats and hump they sit on was rusted badly Shockingly the torsion boxes were in good shape. Thats how i missed a lot of the rust. I had never seen one with good boxes and crappy floors so i never pulled the carpet. Anyway I wanted to flange but was afraid to. I see you are sealing yhe area. I thought of taking body seam sealer more in line with Jaros dum dum caulk and putting it on the edge opposite the weld and then screwing it let it set and then work. Sorry for the long post
Old 02-24-2008, 07:26 PM   #159
jaros44sr
jaros44sr's Avatar
That's the problem, with doing floors. Accessiblity, because of the torsion boxes. When I flanged mine, I still had access to the bottom to finish up the bottom weld. I think that if you use a good zinc primer this should stop the rust, or at least act as a sacrificial matrl. After your done welding, then you can come back with a good brushable seam sealer
Pound 41, let us know how you make out, curious, always open for new solutions to old problems
Sorry for the hyjack Big J., hyjack off
SAFETY FIRST
AS usual, off topic
Jim
Old 02-25-2008, 05:54 AM   #160
Big J
Big J's Avatar
I sealed up underneath while I could get my arm up in there. It will probably rust again in about 40 or so years.... Maybe it won't. The only flange is on the outside edge of the floor. Its mostly protected, under and on top.
I got all my grinding done today. Got a bunch of holes filled in too. I found 3 more that I need to do. I should be able to get that done tomorrow.
BAZINGA!
My Build
Old 02-26-2008, 05:18 AM   #161
Big J
Big J's Avatar
Wow, all kinds of posts today on the Blazer board. I figure I'd better post a pic of what little I did, lol. I put the drivers door on. Thats mostly it, . I have some adjusting to do but its not far out. I put the plate around the door latch on the passenger door too. Got the hinges off, just need to rebuild them.
BAZINGA!
My Build
Old 02-28-2008, 09:28 AM   #162
Big J
Big J's Avatar
Got the hinges rebuilt tonight for the passenger door. Man that top hinge gave me fits. I used a torch to heat it and everything, even busted out the BFH! Ended up bending the hinge, good thing I had several laying around. I broke a punch too... It wasn't until I got to the third hinge that I was able to get it apart...... The door lined up pretty nice. I still have some adjusting to do but for the most part they look good. I plan on mounting up the outer rockers this weekend.
BAZINGA!
My Build
Old 02-28-2008, 10:23 AM   #163
Big J
Big J's Avatar
I almost forgot about the goodies!!! Heres all the stuff to get it ready for paint. Primers, filler, cleaner, primer gun, metal prep, sand paper, dura-blocks...... Gettin' there, "Slowly but Surely", .
BAZINGA!
My Build
Old 02-28-2008, 10:29 PM   #164
49m
49m's Avatar
Where did you get your paint supplies and how much did they cost
My Rides
1969 Mustang gt coupe
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
2005 Ram 2500 Cummins
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=279831
49m is offline   Reply With Quote
Old 02-29-2008, 01:47 AM   #165
Big J
Big J's Avatar
I got them from a place in Lousiville called Finishmaster 4350 Robards Lane, Suite B Louisville, KY 40218 (502)458-9002. Ask for Mike. All the stuff you see is just to get primer down and ready to paint. I'll pm you the rest....
BAZINGA!
My Build
Old 02-29-2008, 06:26 AM   #166
49m
49m's Avatar
My Rides
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
My Build Thread
Old 02-29-2008, 09:22 AM   #167
Big J
Big J's Avatar
No problem....
Well with the advice a wisdom filled fellow board member I started pulling out and installing my new body mount set on this old frame. I really want the doors and outer rockers to line up the best they can so add one more step to this slow process. I should have all that done tomorrow night. I'm really wanting to get my outer rockers on so I can call the floors done!!!! Then on to the bedsides....
BAZINGA!
My Build
Old 02-29-2008, 04:27 PM   #168
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Way to go Big J, great progress!
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 03-04-2008, 07:44 AM   #169
Big J
Big J's Avatar
Well this ended up being one of those weekends with lots of projects to do.... Not including the Blazer, lol.... I did get the doors all lined up nice and straight..... A shim here and a shim there along with some adjusting at the hinges... They came out nice... to me anyways, . I started fitting the drivers outer rocker. I've got it close to welding in. Hopefully I'll get some time this week to knock both of those out.
BAZINGA!
My Build
Old 03-08-2008, 09:40 AM   #170
Big J
Big J's Avatar
I haven't got much done...... The drivers outer rocker is ready to weld on. I'm going to throw a fender on to make sure but it looks pretty good right now. Maybe this weekend I'll actually get something done. I've been tinkering with a couple new mowers we picked up... Ones a John Deere 400 and the other is a Cub Cadet 2135. Fun stuff. Tinkering that is, not mowing, that just sucks . Neighbors giving me a hard time. I've got a mower collection going on, JD GT275, 216, 210, and the Cub 2135
I like lawn mowers, I really want a small tractor, oh well. Thats way down on the list. I've still got to pick up a new grill and paint and tires and etc......... It'll be worth all the blood, sweat, and tears when I get to drive it. Yes there were tears, lol.... After bloodying my knuckles I wasn't able to wipe the sweat out of my eyes quick enough so I teared up, .
BAZINGA!
My Build
Old 03-08-2008, 07:38 PM   #171
Burt4x4
Burt4x4's Avatar
Keep going
Looks like the factory green on your firewall is the same as mine was.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-09-2008, 03:54 AM   #172
vtblazer
vtblazer's Avatar
Doors look like they came out great, nice job.
What's next after the floors are finished?
Old 03-09-2008, 07:54 AM   #173
Big J
Big J's Avatar
Originally Posted by Burt4x4 View Post
Keep going
I'm tryin'... Friggin' mig, fought with it all day.....
Well a P.O. cut off the bottom edges of the rear wheel wells, so probably fixing that. Then some dent work. Glad you like the doors. Hangin' doors by yourself is fun.....
I got the drivers rocker done today and the passengers ready to weld up. I'd got more done if my mig hadn't been acting funny. Maybe tomorrow it will cooperate I also had to go play in the snow with the JD... We're supposed to end up with 6-13" of the white stuff.
BAZINGA!
My Build
Old 03-09-2008, 09:08 AM   #174
jaros44sr
jaros44sr's Avatar
Try checking amps and volts, maybe something is sucking some of your current away....Dang PO's
SAFETY FIRST
AS usual, off topic
Jim
Old 03-09-2008, 09:46 AM   #175
Chevyman63
Chevyman63's Avatar
Looking good man!
1972 4x4 Blazer
RIP
- CLR 10/11/09
