05-29-2008, 07:27 PM | #151 |
Re: project INCREDIBLE HULK 6.2L with 6L80E
Where did you get the pan and the fuel pressure regulator setup?
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-29-2008, 11:09 PM | #152 |
rob,
that's the vette filter/regulator, can buy it at any parts place. I got one on mine, think I paid $39@ oreillys
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
05-30-2008, 06:51 AM | #153 |
lwr kickpnls came from LMC and kennys trucks (in tulsa OK)....the LMC dr. side lines were off so another one was bought at kennys trucks that fit...
06-02-2008, 11:06 AM | #154 |
this weekends progress report :
got the trans cleaned and painted, mated it back to the engine, and installed them in the frame....the trans mount is about 2.5" higher then the 4l60e, so the trans x-member had to be modded to move the mounting pad up...and a few pics of the headers installed ,,,,,here are a few pics |
06-02-2008, 12:32 PM | #155 |
Under Construction
looking good Don....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
06-02-2008, 09:39 PM | #156 |
look ma no header clearence issues!
06-02-2008, 11:27 PM | #157 |
what headers are those?
06-02-2008, 11:38 PM | #158 |
Dude, is that a new white carbon fiber drive shaft?!?!
06-02-2008, 11:49 PM | #159 |
Just hang'n around
I'm liking this very much. Great build and great pictures. I'm really facinated by your frame cut and splice. Great way to do that.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. Last edited by Steelawork'n; 06-02-2008 at 11:50 PM. |
06-02-2008, 11:51 PM | #160 |
and some beefed up u joints
R.I.P. Killer 71 10/26/07 |
06-03-2008, 02:18 AM | #161 | |
Also I missed it last time but nice job on slicing the rocker to fit the door/fender profile. Most poeple don't take the time to do this and it really pays off in the end. Kevin LFD Inc. |
06-03-2008, 12:28 PM | #162 |
A guy with a truck
Go with the stock harness/PCM. You are more than capable of re-routing some wires. It looks worse than it is...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-03-2008, 01:47 PM | #163 |
yea, that would be my first choice (do it myself) but john at speartech is also another great option, he knows his stuff......
S&P is hit and miss on knowledge, enough so i dont base decisons on what they say... |
06-03-2008, 11:21 PM | #164 |
Doing the harness is not that bad. Very scary looking and confusing at times with the mess of wires everywhere. Just do it one connector at a time and label everything... In the middle of doing mine and I quite enjoying it.... I do have one question for ya Don. Do you think it will affect the knock sensor reading if i route them inside the harness with the starter solenoid wire. They are a twisted pair of wires so I don't think induction should be a problem.
Thanx Trevor |
06-03-2008, 11:34 PM | #165 | |
06-04-2008, 02:51 AM | #166 | |
Kevin LFD Inc. |
06-04-2008, 10:25 AM | #167 | |
06-04-2008, 10:52 AM | #168 |
i believe it was in my build up awhile back.
06-04-2008, 11:01 AM | #169 |
A guy with a truck
It's a Dakota Digital item...
06-04-2008, 12:16 PM | #170 | |
06-04-2008, 12:17 PM | #171 |
I knew it was in one of these threads but couldn't remember which one. I just re-read through Don's SS build-up as well as LowBuks & didn't see it. The Killer build-up was next on my list.....
06-04-2008, 01:13 PM | #172 | |
Kevin LFD Inc. |
06-04-2008, 02:39 PM | #173 |
I was meaning to look into that CC switch. To make that functional all a guy has to do is add the CC input from that switch to the PCM, right?? I was shocked on how cheap it is!!
06-04-2008, 04:06 PM | #174 |
yes, the pcm controls the CC... just connect the on/off switch, resume/ accelerate, set....and you're done..
06-04-2008, 06:54 PM | #175 |
Cool, I gotta have one...
Thanx Trevor. |
