Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-18-2009, 11:08 PM   #151
djracer
djracer's Avatar
Re: How about some pics of High Performance haulers.
sweet looking truck. How fast is it?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-19-2009, 12:03 AM   #152
paul1969
paul1969's Avatar
thank you its wierd to get to chat with you the blue stepside truck you baught is the example i used for two years to build this truck. so thank you
so for the best its done was 11.70 116 7.52 in the 1/8with the old motor which was a 461 10.1 pro heads w/ a small comp solid cam cast bottom end and turbo 350 w/ 373 29.5 10.5w i hope with this new motor to be mid 6s in the 1/8 but who knows.hows your project comin along?
69 stepside 489ci
60ft---- 1.46
660ft--- 6.570@105.95
1320ft-- 10.37@127.01
paul1969 is offline   Reply With Quote
Old 07-19-2009, 08:51 AM   #153
69trk
69trk's Avatar
nice truck paul. You need to bring it to oklahoma sometime...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 07-20-2009, 09:43 PM   #154
djracer
djracer's Avatar
The new motor is getting close.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-20-2009, 10:41 PM   #155
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
Very sweet looking truck paul1969
_____________________________
1968 c-10 stepside "THE GRAPE APE"
all motor
1.56...60ft
7.41...1/8
89.41..1/8
limitedstreetoutlaw is offline   Reply With Quote
Old 07-21-2009, 03:44 PM   #156
paul1969
paul1969's Avatar
i thank yall for the compliments its seems like it took forever just to get this far
69 stepside 489ci
60ft---- 1.46
Old 07-21-2009, 09:02 PM   #157
bigbadjohn84
hey man. sweet truck! I see you are running coil overs in the rear.. is the rear frame narrowed? my 71 project is heading in the same direction. I just wanted to know how you got those big wheels and tires under that thing. is the inside of the bed tubbed at all? got any rear suspension pics?? thats awesome
bigbadjohn84 is offline   Reply With Quote
Old 07-21-2009, 09:46 PM   #158
paul1969
paul1969's Avatar
thanks john what i did was notched the frame with some 6'' half tube 3/8'' thick and ordered the shock mount kit from swracecars. as far as the bed i cut the inside and made extentions 8'' wide and then welded the itall back in.i hope this helps you out good luck on your build.
69 stepside 489ci
60ft---- 1.46
Old 07-21-2009, 09:54 PM   #159
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: How about some pics of High Performance haulers.
This is the setup I have now on my '62!
http://cid-9169aad55cfc6d79.skydrive...ACKET%e2%80%b3
This is how I dream to setup Ole' Project: Full Metal Yellow Jacket!
http://www.sporttruck.com/featuredve...uck/index.html
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-22-2009, 10:40 AM   #160
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i agree with the license plate that truck is insane
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 07-22-2009, 01:11 PM   #161
bigbadjohn84
dang.. is there really that much room under there for tires?? without narrowing the frame?? are those custom offset wheels, or is the rearend narrowed?? on either trucks
Old 07-22-2009, 02:55 PM   #162
paul1969
paul1969's Avatar
i forgot to add that i narrowed the rearend 6'' total the wheels are 15x10 with a 5'' backspace i can fit a 15x12 with a 7'' backspace which is what i intend to go to when the money gets right again.
69 stepside 489ci
60ft---- 1.46
Old 07-22-2009, 04:04 PM   #163
bigbadjohn84
ahh sweet man. good to know. I've got a 12 bolt loaded with the factory GM posi. Just need some gears and some meats to go under it. that thing looks good
Old 07-22-2009, 05:23 PM   #164
1Bad62Pro/Street
bigbadjohn84,
The Frame has been Modified & Altered.
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
Wheelbase 117”
Rearend / Ratio 58 Ford Wagon 9” / 3.70:1 / 57.25 inches
1957-1959 Ranchero and station wagon 57.25 inches
The narrowest 9" housing....................................
Front Suspension Mustang II IFS
Front Wheel make, size Weld Draglite 15x7
Rear Wheel make, size Weld Draglite 15x12
Front Tire make, size 215/65SR1596H
Rear Tire make, size Mickey Thompson
29x15.50-15LT Tube Type
Here are the Plans:
http://www.jegs.com/
Jegster Ladder Bar Crossmembers
Jegster Ladder Bar Crossmembers #550-40010
Jegster ladder bar crossmembers are stronger per pound, because the included
braces allow the main crossmember to be made of lighter material and allow increasing
the weld area to the frame rails. Made from 1.5'' x .134'' wall mild steel tubing.
56'' Extra Wide
Kit includes:
(1) 56'' crossmember with 2-1/2'' center drop.
(4) .188'' thick, 3-hole brackets with 3/4'' holes.
(2) bracket webs.
(2) 1-1/4'' x 18'' steel tube braces.
(2) bolts and lock nuts.
Competition Engineering Ladder Bar
Competition Engineering #247-2006
Increase traction by eliminating wheelhop
Ladder Bar Features
33" long
Best for 100"-115" wheelbases
Made of 1" O.D./.156" wall tubing
3/4" forged rodends threaded directly into tubing
Front end braces prevent rodends from bending & breaking
Double 360° housing brackets withstand brutal loads
Competition Engineering Floating Axle Housing Mount
Competition Engineering #247-2030
The use of ladder bars with a leaf spring rear suspension requires that the rear
end housing not be rigidly attached to the leaf spring. This is because the
ladder bars and the front half of the leaf spring establish two different and competing
centers of rotation for the axle housing. A floating housing mount eliminates the binding and
allows the housing to rotate properly.
That other Truck was in the Sport Truck Magazine
1956 Chevy Truck - Double-Stacked Lightnin'
The 411
Engine/drivetrain:
'70s 355-cid GM small-block / forged-steel crank and LT-1 rods / custom dual 6-71 blower intake manifold with 15 psi total boost / ported and polished heads with 2.02/1.60 stainless valves / 0.532/0.305-lift Comp Cams cam / single 750-cfm Holley carb on each blower / GM TH400 trans with 3,500-stall converter / Ford 9-inch rearend with 4.11 gears and posi / MSD 6AL ignition box and Pro-Billet distributor
By: Kenny Larson, Florence, Oregon
Rims:
Front: 15x6 Center Line Warrior
Rear: 15x12 Center Line Warrior
Tires:
Front: 26x7.50-15 Mickey Thompson Sportsman
Rear: 29x18.50-15LT Mickey Thompson Sportsman
Suspension:
Front: Air Ride Technolgies airbags / Chassis Engineering control arms
Rear: Triangulated four-link / Koni shocks
Accessories: 11-inch Chevelle front disc brakes and calipers
Chassis: '72 Chevelle front subframe / boxed rear framerails / Alston's Chassisworks rollcageBy: Owner
Body Mods:
Hood pancaked 3 inches / top chopped 3 inches / rear fenders widened 1 1/2 inches / bed raised 2 inches / front fenderwells raised 1 1/2 inches / suicide doors / custom smooth inner fender panels, firewall, and tailgate / front turn signals removed / custom spoiler / frenched headlights / '50 Pontiac taillights / exhaust collector replaces side steps / door handles removed / hood cut out for dual blowers and forward-tilt hood hinges added
By: Owner
Custom Paint:
DuPont clearcoat/basecoat black
By: Owner
Interior:
Chris Alston modified rollbar kit / Summit Racing seats and four-point harnesses / custom black carpets, door panels, and headliner / Auto Meter white-face gauges in custom dash / custom console
By: Owner (console and dash) / Wayne at Classic Upholstery, Florence, Oregon
Audio/video:
N/A
Club:
Rody Cruisers
Old 07-22-2009, 06:44 PM   #165
bigbadjohn84
wow.. did you leave anything out? what's your shoe size? lmao kidding. sweet truck man
Old 07-22-2009, 08:22 PM   #166
1Bad62Pro/Street
Ha ha. Yea, just copied and pasted from my build thread, and that other page.
Quicker doing on my BlackBerry phone.
Thanks bud,
29x15.50-15LT Tube Type Wide Hides
Old 07-25-2009, 11:57 PM   #167
MoFaster
MoFaster's Avatar
Wow, these trucks are amazing. My truck doesnt look nearly nice but Ill still post up a pic. This is my daily driver so those are just 600 Holley's. I do have a set of predators if I ever get it to the track.
78 Stepper Big Block
http://i62.photobucket.com/albums/h1...19-09_1639.jpg
Dont brake till you see God!!
MoFaster is offline   Reply With Quote
Old 07-26-2009, 03:10 PM   #168
bigbadjohn84
HOLY CRAP! did you say daily driver.. geeze man. that big tunnel ram intake on there looks good. how is it on the street?
Old 07-26-2009, 05:56 PM   #169
MoFaster
MoFaster's Avatar
Its pretty good with the 600's. It has the Lunati Voodoo 292/300 Roller cam and believe it or not im still using my power brakes. lol I did live in Fort Smith, Ar. and I could drive it anywhere I needed to. Now I live in San Antonio and Im now looking for a newer truck. I put the Predators on for a weekend and those are AMAZING, but not very streetable. I hope I can get it to the track pretty soon. Im going to replace fuel system before I take it.
Old 07-27-2009, 06:22 PM   #170
limitedstreetoutlaw
Hey MoFaster did that truck set at the back of a car lot in van buren for awhile? i remember seeing one that looked just like that.
all motor
1.56...60ft
7.41...1/8
89.41..1/8
Old 07-27-2009, 08:01 PM   #171
MoFaster
MoFaster's Avatar
Man Im not sure. Could have been I know it got passed around for about 6 months. One guy bought it and he was told that it had a 454 in it and he couldnt get it to run right. So my buddy bought it from him and we pulled tha motor and it was a .030 over 396 with a 454 balancer and flywheel. So I ended up with it. When I got the motor it was apart. I put new bearings in it and put it back together with the right stuff.
Old 07-28-2009, 03:26 PM   #172
merlinman572
c30full size fitted with merlin stroked 572.
hi still not had success at loading pics of my c30 1977 twin cab pick fitted with merlin 572 628hp 700lbft torque best time on track 13.07@102mph weighing 2800kg almost 3 ton with driver can be seen on youtube under merlinman572 please feel free to leave a comment
merlinman572 is offline   Reply With Quote
Old 08-01-2009, 12:05 AM   #173
Legend56BC
Legend56BC's Avatar
Ok I have to show you straight liners that these trucks can also haul roundy round style! This is from "69 GMC Forever"(my crew chief)and my win this June against cars!My daughter was the trophy girl that night so it was really special!
It is a 1972 Chevy C10 1/2T fleetside with a 70 Chevy grill in it..350,PG,373 12 Bolt on a stock 2 barrel and stock ram horns putting 327hp on the dyno..
Legend56BC is offline   Reply With Quote
Old 08-01-2009, 06:30 PM   #174
68racer
Yeah baby!
68racer's Avatar
merlinman, here is a link to a pic on the butty run site:
http://www.butty-run.com/images/Old-...n-2009-44.html
There are some more pics there, Neil.
11.37 @116
68racer is offline   Reply With Quote
Old 08-02-2009, 02:32 PM   #175
merlinman572
thanks for taking great pic
