Old 05-28-2009, 05:52 PM   #151
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
thanks, when I started working on my truck I didn't know any thing about it, for the heater I have it between the ashtray and the flat part on the glove box
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 05-28-2009, 06:01 PM   #152
flamingbig10
6.0 powered square
Re: my 80 build
but I haven't hooked up the hoses yet, its to hot to worry about a heater
Aaron
Old 05-28-2009, 07:13 PM   #153
GMC Guy
GMC Guy's Avatar
Re: my 80 build
i agree, but in the winter time it really sucked, especially not having a way to defrost the windows...so my challenge was to figure out how to hook up the ducting to the stock defrost vents...(used a lot of duct tape). but i mounted mine so the vents faced up, and i have two 90* pvc elbows attached to the outlets on the heater so that the hoses run straight through the firewall. haven't tested it yet..but i'm sure it will work. just haven't been motivated to get under there and do it yet, been working on other stuff
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 06-04-2009, 12:06 AM   #154
flamingbig10
6.0 powered square
Re: my 80 build
I went to the junk yard today a picked up a few things ok dash, trim pieces that go by the dash and seat belt bolt covers. the dash will be fiber glassed and shaved
Aaron
Old 06-04-2009, 01:26 AM   #155
flamingbig10
6.0 powered square
Re: my 80 build
and the dash I took all of the foam and vinyl off and soon I should be welding up all the the holes or might just add fiberglass over it, and wile I was the junk yard I saw a lot of square bodies, and I also saw a guy have a massive heart attack and he died
Aaron
Old 06-04-2009, 03:33 PM   #156
warpig98
Re: my 80 build
god mines must think alike. thats exactly what i'm in the process of doing with my dash. i'm going to have "chevrolet" put on the front in raised letters.
THANK YOU SOLDIERS!!!!!
VISIT MY 78 BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=334884
warpig98 is offline   Reply With Quote
Old 06-09-2009, 12:24 AM   #157
flamingbig10
6.0 powered square
Re: my 80 build
sounds cool the next purchase will be new tires since I put a couple thousand mile on a unaligned front end they sure wore out the year old tires fast now I need to decided if I still want to run 215/70/15s
Aaron
Old 06-09-2009, 03:33 PM   #158
warpig98
Re: my 80 build
u know i've thought of an idea. u know how you and i are doing our dashes, i wondering if a guy couldn't weld in a piece where the plastic gauge bezel goes and have that all one piece. i think that would look pretty slik., what you think?
Old 06-10-2009, 05:42 AM   #159
rod86
great southern land
rod86's Avatar
Re: my 80 build
got any more pics of the dash in just the steel shell?
how much of it does the foam and vynil make up? i mite end up doing a similar thing...
rod
86 chevy c10 silverado
rod86 is offline   Reply With Quote
Old 06-10-2009, 09:26 AM   #160
JohnC
JohnC's Avatar
Re: my 80 build
That does sound pretty cool. I would be interested in that myself.
JohnC is offline   Reply With Quote
Old 06-10-2009, 12:23 PM   #161
flamingbig10
6.0 powered square
Re: my 80 build
the foam is a bout 1/2 to 1 inch thick
Aaron
Old 06-11-2009, 12:18 AM   #162
flamingbig10
6.0 powered square
Re: my 80 build
since you said that, that's what I plan on doing so it will match my door panels a lot better
Aaron
Old 07-01-2009, 01:33 AM   #163
flamingbig10
6.0 powered square
Re: my 80 build
after not being able to drive my truck for about two weeks with bad fuel pump went got a replacement fuel pump, a metal fuel filter to mount after the tank, and new fuel hose and after install the truck fired wright up with good fuel pressure, the drove it around a little (30 miles) and I started smelling gas so I took it home and checked the lines and there was gas dripping so loosed the line and i forgot to wrap Teflon tape around the tread I tightened it back up and no more drips
Aaron
Old 07-01-2009, 01:42 AM   #164
mongoose
mongoose's Avatar
Re: my 80 build
use thread sealer instead of teflon tape if you have to... the tape will start dissolving with the gas and gunk stuff up.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 07-02-2009, 11:25 PM   #165
flamingbig10
6.0 powered square
Re: my 80 build
thanks mongoose I'll try that next time
Today added 2" lowering shackles to rear
Aaron
Old 07-03-2009, 02:29 PM   #166
flamingbig10
6.0 powered square
Re: my 80 build
I think I got the stance right after the 6th time of trying
Aaron
Old 07-03-2009, 03:43 PM   #167
menace121978
menace121978's Avatar
Re: my 80 build
i agree looks perfect!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 07-03-2009, 07:31 PM   #168
LiveAnimals
LiveAnimals's Avatar
Re: my 80 build
Looks Great
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 07-03-2009, 10:00 PM   #169
silvrbreez
silvrbreez's Avatar
Re: my 80 build
So flip kit and shackles in the rear?
silvrbreez is offline   Reply With Quote
Old 07-03-2009, 11:35 PM   #170
flamingbig10
6.0 powered square
Re: my 80 build
thanks guys and yes beltec flip kit and drop shackles
Aaron
Old 07-04-2009, 01:06 AM   #171
flamingbig10
6.0 powered square
Re: my 80 build
last year
now
Aaron
Old 07-05-2009, 03:56 PM   #172
silvrbreez
silvrbreez's Avatar
Re: my 80 build
Nice. Think I need to throw my drop shackles back on the rear of mine to level it back donw.
Old 07-05-2009, 04:36 PM   #173
JohnC
JohnC's Avatar
Re: my 80 build
Yeah the shackles set it just right. Looks good. How's the dash coming?
Old 07-07-2009, 01:32 PM   #174
flamingbig10
6.0 powered square
Re: my 80 build
thanks guys, haven't worked on the dash
Aaron
Old 07-10-2009, 06:02 PM   #175
flamingbig10
6.0 powered square
Re: my 80 build
here some better pics
with the farm show truck
Aaron
