12-11-2008, 02:44 PM | #151 |
PITbut
Re: My build. Project Karma. 71 stepside.
Now, here is where it gets interesting. I didnt realize how HOT headers got. YA, they get hot.. Very hot. So before i started it i spent some time nicely routing them and making hold downs to keep them from touching the headers.. You can see the aluminum piece here in the pic.
Then i added my pretty wire connectors. So, we have everything ran, and here is the video of the start up that followed... I was planning on runnin it for 20-30 mins on the first start up... Needless to say, that didnt happen. |
12-11-2008, 02:53 PM | #152 |
PITbut
After it started and ran for two minutes, you notice the smoke. Well, i spilled some oil on the drivers side header. I thought i had it all cleaned up.. Well, i didnt.... 20 seconds after the video shuts off, the left side of the truck shoots flames 3 feet in the air. Needless to say i was FREAKED. We did have an extinguisher ready and it was quickly put out, but i was just stunned. I felt like it was the end of the project... Everyone else didnt think it was any big deal. After a few hours and 10 beers later i realized that there was almost no damage. Just some dirt..... Here is the after pics.
I also noticed that my wire holders melted, and this melted. Thats the fuel filter.... It had a hole in it when we shut the truck off and was leaking gas.... I moved that and also pulled all the spark plug wires and put some cool tape on em just to keep the temps down. I then proceeded to take 2 of engine break in. This time it ran and we didnt have any issues... I shut it off about 5 minutes later because the fan i was using to keep the engine cool wasnt sufficient enough... I have now wrapped the headers in header wrap, wrapped a few other lines with some 1200 degree cloth to keep things even cooler. I installed dual flexalite fans and should have the remainder of the break in finished this weekend.... Then the cab goes on and start to get that primed and ready for paint so we can start putting it back together... The bed is still in the process of being taken care of also... |
12-11-2008, 03:15 PM | #153 |
Under Construction
trucks looking good bro!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 12-11-2008 at 03:15 PM. |
12-11-2008, 04:14 PM | #154 |
Project: years too late.
its coming together very nicley!
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here. |
12-11-2008, 11:53 PM | #155 |
very AWESOME, i have burnt many a plug wire in my day, plus other things, breakins are always nerve racking, glad to hear her run
James
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
12-12-2008, 12:26 AM | #156 |
Too bad you didn't have the fire on tape, I would have freaked out as well , but it would have been cool to see. lol
When did you want to put the cab back on? -Joel |
12-12-2008, 12:49 PM | #157 |
PITbut
Very very soon.... I have to install 2 heat shields, then install the passenger side header, and two air valves and the cabs ready... So, sunday is still looking good... Thats all out the window though if it snows.
12-15-2008, 11:48 PM | #158 | |
PITbut
Well, it did snow.. ahah. that didnt stop me from doing the final break in. She fired right up, no issues. Sounded REALLY good. Finally got to hear it idle alng with rev it up a bit. I didnt idle it long, just for a few seconds to set the idle... Still need to do timing and that portion is done... Here is the vid of the final break in.... I also installed my two heat shields. i installed one and left one of them off. I wanted to make sure they actually did something. After it was done running i laid a piece of plastic on the muffler and it melted almost immediately. I laid another piece of plastic on the heat shield side and it was absolutely fine. Also, the header wrap worked wonders also. At idle i can hold the header. About 30 seconds after you shut the vehicle off i can hold my hand on the header. I have a hard time holding my hand on the valve cover 30 seconds after it shuts off. The new fans i installed worked perfectly..... I then welded the tabs on the muffler. To be continued. |
12-15-2008, 11:50 PM | #159 |
PITbut
I also finished installing my front air valves for my air ride...
THis coming up weekend i will be installing the cab and going from there. Dont really know what to do. Startin to get a bit overwhelmed with all the body work left.... I plan on spending a full day here really soon and just grinding the heck out of the cab so i can put the whole thing in epoxy. Once i do that i will be ahead of the game. Right now i cant get my garage any warmer then 45 degrees so i wont be painting in there any time soon... |
12-16-2008, 12:08 AM | #160 |
looking mighty fine, she sounds really good!
12-16-2008, 12:20 AM | #161 |
Awesome Vids....Starting em for the first time is really exciting (and scary)....Can't wait until I get to fire mine for the first time!
Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
12-16-2008, 12:23 AM | #162 | |
PITbut
Its tough. I literally work on it 1 hour or so a weekend.. Just hard getting time when there are soooo many kids... Not only do i have my 3 but, then im watching my brothers plus the 2 my wife watches.... Gets tough. |
02-10-2009, 10:56 PM | #163 |
Hey Lyrikz... I wanted to give ya an update on the 250 that came out of your truck. It is still running great and gets around 20mpg in town with the 3speed standard and 3.73's. I am getting rid of the 72 it is in so there will be a new owner soon but I wanted to let you know it sure has been a great running motor for me.
Good luck with the big block.
1972 LWB 1969 4x4 Suburban 1989 4x4 Jimmy |
02-10-2009, 11:41 PM | #164 | |
PITbut
My 454 is doing good. Put the cab on this weekend. Need to notch teh bottom of the cab to clear the driveline. ahaah |
02-10-2009, 11:47 PM | #165 |
In fact, that's the only problem I ever had with it. I had to change the whole tank out though to stop getting rust. I am about to see it but before it goes I will take some pics of in the truck and post em for ya.
02-10-2009, 11:48 PM | #166 |
PITbut
02-16-2009, 01:38 AM | #167 |
PITbut
Kind of an update. I installed the cab (1 step forward) and then found out that my driveline is to high and it hits the cab, and the exhaust doesnt fit. (two steps back)
I went in today, removed the exhaust, removed the custom tranny crossmember and notched the ends. Lowered the tranny to wher eit should be and now with the vehicle totally aired out with weight on the rear, the driveline is | | that close to the cab. Doesnt get any closer even if you bounce hard on the truck. I am not going to reinstall the exhaust until the truck is done. If you go back and check the pics i have the mufflers right under the cab and i think its going to be to hot there. I will have some more pics tomorrow of everything i did. |
02-16-2009, 02:11 AM | #168 | |
all that sounds just way too familar, onestep forward and two back, but it seems more like 5 backward
02-16-2009, 01:48 PM | #169 |
Tasty Cakes!
Been awhile since I read through this thread, so I don't remember if this has been covered, but what about using a heat shield type of product on the inside of the cab to keep it from getting too hot? Second Skin makes excellent products. That's what I'm going to eventually put in mine if I ever(!) get to that point.
And good idea on waiting on finished the exhaust until she's put back together fully. That's what I'm gonna do.
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
02-16-2009, 03:25 PM | #170 | ||
PITbut
02-18-2009, 12:43 PM | #171 |
PITbut
Here are some pics. First is the tranny crossmember that i notched. Fits really nice now and driveline clears the cab when fully aired out.
I then moved on to mounting my air tank. I mounted the tank next to my compressors under the cab. This tank fits perfectly. You cant see it from the side. Its a 7 port, 7 gallon tank. I had to cut the mounts off and make my own, but it fits nice and snug.. Super clean... Also, i can add another tank on the other side later if i need to. Tank in original mounts. New mount on the front. Welded on some studs and snugged it close to the tank. Back mount. NEw front mount |
02-18-2009, 12:45 PM | #172 |
PITbut
Here is the tank mounted... Can barely see it.
Mounting hardware. So, now i just need to add fittings and install the front valves and its ready to go.. Should have the air finished up tonight... While working on the cab, i noticed an area that looked like rust. Now, i sandblasted the cab, then epoxied it. It sits in the garage. WHy and where would this come from? I was thinking it was metal shavings that flash rusted.. ANy thoughts? |
02-18-2009, 04:17 PM | #173 |
Mean Buzzin' Half Dozen
Well, wheres that at? Humidity can cause some rust, and you might possibly have some rust on the other side of the metal and it's seeping through the crack. Is it in a spot where there's two or more layers of metal. like in the cab roof for example.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale) 1967 C10 SWB Dylan |
03-03-2009, 04:14 PM | #174 |
PITbut
Well, im back...
Finished the air system. Love having the tank in this location.. room for another one on the other side if i need it... Also started finishing up grinding all my welds... Patched the cab near the window... Some pinholes and what not... |
03-03-2009, 04:21 PM | #175 |
PITbut
I also picked a cheap 20 sand blaster. Add another 25 for the aluminum oxide and your set. This thing works AWESOME on small stuff.
I had the cab sand blasted but after a few months there are some tiny flash rust in the corner so i cant get a wire wheel in there. This works great.... Will have more pics of that soon. |
