Old 10-30-2012, 10:58 PM   #151
AJohn6
Knuckle head
AJohn6's Avatar
Re: Project Step Aside, 1971 SWB/Step
Originally Posted by raull View Post
looking good !!!!!!
Thanks raull.
After looking at the photos again I should probably move the empty propane tank...
At least went and got a couple fire extinguishers for the garage this weekend.
Adam
'71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750
2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC
'00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed
'09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD)
1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785
1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis.
AJohn6 is offline   Reply With Quote
Old 10-31-2012, 10:16 PM   #152
gdavis
gdavis's Avatar
Originally Posted by Tinkermc View Post
truck looks great can't wait 4 U 2 start again. Thanks 4 your service I am so old I did this little thing called Viet Nam a long,long time ago
So did I 69 thru 70 i am a little old myself 63
gdavis is offline   Reply With Quote
Old 11-01-2012, 09:05 AM   #153
AJohn6
Knuckle head
AJohn6's Avatar
Sir,
I feel this doesn't get said enough to your generation; thank you for your service and sacrifice.
Respectfully,
Adam
Adam
Old 11-19-2012, 10:20 AM   #154
AJohn6
Knuckle head
AJohn6's Avatar
Well I got the cab thrown on the truck so I can make room for the Monster Transmission 4L80E. Thing is quite a bit bigger than the TH350.
I started by cutting out the portion of the firewall so I could get the cab on the frame. Once I did this I cut the front portion of the trans tunnel and then cut front to rear on the lower portion of the tunnel. After I removed it I was able to sit the cab on the frame. I had to remove the pinch weld above the frame so the cab would sit on the body mounts, this was because of the 3/4" body drop. I did some pie cuts and used scrap to hold the tunnel where I needed it.
On this note I need a hand. Can someone tell me if the thicker body mount goes in the front or in the rear mounts.
Adam
Old 11-19-2012, 10:30 AM   #155
AJohn6
Knuckle head
AJohn6's Avatar
I started to fill in the open space with some 18ga sheet metal and, again, started to realize that I am terrible at this. But I looked at the replacement floor pans I had and the wheels started to move.
The replacement pans had bends that looked just like the original tranny hump so I took a couple quick measurements and figured I could just flatten those bends out and it would fill the gap perfectly and it would look more stock than the filler piece. Plus in the end it would be less welding and grinding if I just replaced the floor and filled the gap at the same time.
What do you think?
Adam
Old 11-19-2012, 10:35 AM   #156
AJohn6
Knuckle head
AJohn6's Avatar
While in the process of looking at some other threads on here I got to thinking about going fast on a drag strip and not getting kicked out. I did a bit of research and have decided to put a roll cage in the truck. I am thinking of using the S&W 6 point and add an additional 4 points to make it an NHRA certifiable 10 point. I want to be able to run 10.00-10.99 at greater than 135 mph.
Sounds fun huh?
Adam
Old 11-19-2012, 11:36 AM   #157
gringoloco
A guy with a truck
gringoloco's Avatar
Sounds like a BLAST! Using the existing floor patches looks like a smart idea, but what you have going doesn't look bad either. Keep up the good work
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-19-2012, 01:11 PM   #158
raull
raull's Avatar
nice progress !!!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 11-19-2012, 10:29 PM   #159
AJohn6
Knuckle head
AJohn6's Avatar
nice progress !!!!
I appreciate it guys.
Adam
Old 11-30-2012, 01:13 PM   #160
AJohn6
Knuckle head
AJohn6's Avatar
Well for those who are tracking my progress, as slow as might be, I am not able to get anything done for a month or so. I have had some knee problems lately and finally had surgery on my knee. It was an Arthroscope and hopefully it helps.
Adam
Adam
Old 01-09-2013, 10:03 PM   #161
GEARBOXGARAGE
Do you know what air dam that is mounted on the bottom of your front bumper? It looks to be from a later model, but wasn't sure...
GEARBOXGARAGE is offline   Reply With Quote
Old 01-10-2013, 11:44 AM   #162
AJohn6
Knuckle head
AJohn6's Avatar
I am not sure either. If I had to guess I would say it would be the old body style 1988-98. I just did a quick image search and it looks very similar.
Adam
Old 01-10-2013, 12:22 PM   #163
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Really cool build you have going, Adam!
Zoomin is offline   Reply With Quote
Old 01-10-2013, 01:16 PM   #164
GEARBOXGARAGE
I looked through several parts catalogs and that is what my guess was, also. Thanks!
Old 01-13-2013, 12:49 PM   #165
AJohn6
Knuckle head
AJohn6's Avatar
Thanks Steve,
This is the first weekend in about 2 months that I am able to work one the truck and I have gotten quite a bit done. I will get some pics once I find my camera.
-Adam
Adam
Old 01-15-2013, 11:34 PM   #166
BossHogg69
motor exploder
BossHogg69's Avatar
Thanks for sending me the link to your build thread. Some SICK fab work and welding skills going down on this build. Thanks for the inspiration - it's good to see a wicked homebuilt ride!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-16-2013, 07:00 PM   #167
AJohn6
Knuckle head
AJohn6's Avatar
Thanks man.
As promised here are some pictures.
Adam
Old 01-16-2013, 07:40 PM   #168
AJohn6
Knuckle head
AJohn6's Avatar
A couple more..
Adam
Old 01-21-2013, 10:37 PM   #169
AJohn6
Knuckle head
AJohn6's Avatar
I definitely took some liberties when replacing the floor pans and lower portion of the kick panels. I did one side the way it "should" have been and didn't like the way it looked so I did away with the seam. To say this is a learning experience is an understatement, it is kicking my A$$.
Here's a few more pics, enjoy.
-Adam
Adam
Old 01-21-2013, 10:39 PM   #170
AJohn6
Knuckle head
AJohn6's Avatar
A couple more....
Adam
Old 01-21-2013, 10:46 PM   #171
Bennett68C10
Bennett68C10's Avatar
Nice job on the rust work, glad to see your feeling better after the knee surgery. Keep up the progress.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-21-2013, 11:05 PM   #172
AJohn6
Knuckle head
AJohn6's Avatar
Thanks bro. My knee gets sore after working in the garage but all in all it is healing up quite nice. Hopefully I'll be able to run in a couple months.
-Adam
Adam
Old 01-22-2013, 05:18 PM   #173
gdavis
gdavis's Avatar
your work looks gam up and jelly tight my friend.
Old 01-22-2013, 06:24 PM   #174
emilio impala
emilio impala's Avatar
Wow! Me gusta mucho lo que estas haciendo!
emilio impala is offline   Reply With Quote
Old 01-22-2013, 07:06 PM   #175
AJohn6
Knuckle head
AJohn6's Avatar
Thanks man.
Muchas gracias mi amigo. (Thanks to Google as well...)
Adam
