08-16-2008, 11:45 PM | #151 |
PorterBuilt Man Crush
Re: Dropmember Rear 63-72 Spy Pic
asd
The 72 will live again Last edited by jasonb72; 08-16-2008 at 11:45 PM. |
10-21-2008, 03:03 AM | #152 |
just wondering why this thread has been dead for 2months...any updates on these kits nate?
-wes |
10-21-2008, 07:09 AM | #153 |
Nate~ With this set up how wide of a tire can you fit?
Kevin LFD Inc. |
10-21-2008, 07:48 PM | #154 |
10-22-2008, 02:03 AM | #155 |
I have sold quite a few of them.... maybe I better get some good pics up! Give me a couple days.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
10-22-2008, 09:07 AM | #156 |
I have some from n2billet but don't want to post w/o permission.
10-22-2008, 02:31 PM | #157 |
3DrDwn--the 'burb not the band
I'm just finishing mine up. I only need to weld in my axle pads and I'm done.
http://67-72chevytrucks.com/vboard/s...28#post2930828 I'll try to get the pics with the 4 link/ panhard bar finished up in the next day or so. Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
03-10-2009, 09:36 AM | #158 |
so is there a price for just the notch?
2009 dodge hemi custom paint 86 lwb bagged layin frame 73 2 door nova 54 bel air |
04-30-2009, 10:08 PM | #159 |
A guy with a truck
Do the link mounts align using the leaf hanger holes? Would this work on say, I dunno, a 4wd Blazer...?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-30-2009, 11:36 PM | #160 |
A guy with a truck
I realized my post was a bit vague. I was speaking of the four-link. My Blazer is already step notched. If the brackets locate off the forward spring hanger holes, then it should align perfectly, since the Blazers and trucks share rear spring dimensions.
05-01-2009, 12:50 AM | #161 | |
The only thing I would need to change is the angle of the forward mounting tabs (they sit at about a 4 degree angle due to the frame taper on the 2WD). Since the 4WD is a straight rail design, I would just need to eliminate the angle on the mount. It's a pretty simple change for me to make. If you are interested, I would just mod a bracket and send it out so you could test fit and verify. Not sure if you would have to modify your floor for front upper bar clearance.
06-30-2010, 08:35 PM | #162 |
Squarebody guy
Well guys, I have emailed Nate and posted elsewhere but I figured I'd give you something semi-interesting to discuss.
Goal is to lay out a 62 LWB with a 63+ frame on air. Front will be the complete PB setup. Options are Rear drop setup using PBs Trailing arm "kit"(all PB parts like notch etc...) Rear drop setup using PBs 4 link kit I would automatically assume the 4 link is better but I have been wrong before. Will be a daily driver including the ND winters(focus on the suspension, not the winter affecting air ride) so any "extra" ground clearance is a plus. Big wheels are on the list of to do, I figure about 29" tire diameter. Most everything I have figured out so stick with the rear suspension differences. Thanks a ton guys! What would you do? |
06-30-2010, 10:36 PM | #163 | |
06-30-2010, 10:40 PM | #164 |
Squarebody guy
Rim will be 10 inch wide or less
07-01-2010, 11:43 AM | #165 |
07-01-2010, 11:48 AM | #166 |
Squarebody guy
I have been following yours from the start, love it. Yours and a few others have been my main inspiration.
I guess my main question is, suspension performance, which is better? Price wise they are close enough for my budget. Last edited by Ghostwhite; 07-01-2010 at 11:50 AM. |
07-01-2010, 11:58 AM | #167 |
OK GOT ya.I hope to have mine on the road soon.But i went with what I did because i started something and the trailing arms fit what i stared.I would have loved the 4 link but had already started.I have heard that the 4 link rides great .Havent heard much on the trailing arms but I will but a review up when i get it on the road.
07-01-2010, 12:04 PM | #168 |
Squarebody guy
Both setups are legit thats for sure, I had already planned on the T arm setup but now that I have more time and budget, makes me wanna be sure of which I want. I know the 4 link has the advantage of sides but that alone is not enough of an advantage for me
07-01-2010, 02:43 PM | #169 |
Factory truck arms ride great w/bags as well.... PB's set-up won't ride worse.
07-05-2010, 04:54 PM | #170 |
big guy
hey scoti has any one confirmed that a 12" wide wheel will fit with the trailing arm setup yet? I have this setup on my 69 and the numbers don't look good. I wish i had a couple of wheels so i could see for sure with different back spacing. It is going to be close....
07-05-2010, 05:26 PM | #171 | |
07-05-2010, 07:29 PM | #172 |
big guy
I did try and confirm it with nathan but he couldn't say for sure. I didn't mean to upset anyone, the cost of wheels is way to high to mess up and i didn't want to wait. I guess i will be waitting till i can check for myself.
Thanks Ray Last edited by lowdownstar; 07-06-2010 at 06:35 AM. |
07-06-2010, 02:09 AM | #173 |
I don't think anybody is upset. There is room for a 12" wide wheel, but I didn't have an offset to give (I have not yet installed a 12" wide wheel with this set-up), and suggested mock-up and measurement on your end. The last thing any of us want is a custom wheel that doesn't fit right. I will have some good mock up pics and measurements of a 20x10 with a 5.5" backspacing and a 67-69 rear-end here shortly. I will offer all the input and advice that I can... but the backspacing and measurement confirmation will be the end users ultimate responsibility.
07-06-2010, 06:57 AM | #174 |
big guy
I understand it's up to me nathan to make sure it's going to fit, i was just asking if anyone has done it yet to confirm, because when i had my setup together, (no bed) there was very little room for a 12 wheel. So your 100% right i need to mock it up for myself, but i also need the bed installed to do that right. For me it's aways nice to know that some one else has come up with the same numbers so i can feel better about what i found out. I made up a measuring stick and the wheel guys told me a 12" wheel is 13" across with out having one to measure i am not 100% sure of that. if they are, i had only like 3/4" of an inch before i hit the bag mounts. that didn't give me a good feeling they would fit. I am sorry for being a pain in the butt to everyone but i know you guys know a hell of lot more then me. Plus i am pour and don't have the money to screw up! I just didn't want to wait because the wheels take 4-6 weeks to come in, and the summer will be over before i can get it on the ground. that will make two years with out driving it and i am already in the dog house. thanks Ray
07-06-2010, 10:35 AM | #175 |
A 12" wheel does = 13" lip to lip as the tire bead needs approx .500" to seat.
As for calculating tire sidewall 'bulge', it can be done using other possible combos to get a visual 'feel' for how much room is necessary (a 315mm tire on a 12" wide wheel would have 'bulge' comparable to a 265mm tire on a 10" wheel etc....). Ray, have you considered a 20 (or 22) x11"?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-06-2010 at 10:36 AM. |
