05-23-2009, 06:09 AM | #151 |
Re: 1969 Chevy Stepside Restoration/Build up
Sure turned out nice. You should be proud.
Great looking truck. Bill |
05-23-2009, 03:53 PM | #152 |
69' Chevy Stepside
Thanks, I never thought it would come out this good!
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
05-23-2009, 04:03 PM | #153 |
69' Chevy Stepside
Since it got really dusty from being in the garage such a long time it was time to give it it's first wash! Luckily it didn't leak any water, except for around the top of the drivers side door a bit because its out from the top of the cab slightly.
05-23-2009, 04:22 PM | #154 |
cleaned of nicely!
R.I.P. Killer 71 10/26/07 |
05-23-2009, 10:37 PM | #155 |
that thing looks great matt
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011 Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 |
05-23-2009, 11:34 PM | #156 |
69' Chevy Stepside
Thanks!
I still have a lot of lose ends to tie up, like the computer thinks its in drive all the time, only the front brakes work, and a power steering fluid leak. Also I have to get the crank position sensor relearned because it has a code P1336. The scanner at the shop I took it to won't initiate the relearn procedure with the computer thinking its in drive all the time. Today I decided to investigate the problem and found that the wires to the neutral saftey switch were never connected to the computer so I have to get them hooked up (whoops).
05-29-2009, 03:50 AM | #157 |
69' Chevy Stepside
Forgot to post this. I took the 69' to a car show on Memorial Day! Everyone was really interested in the engine and how it was installed and such. Anyway here's some pics.
--Also does anyone have any Ideas on why I can't keep my front brakes working??? I converted to front discs, power brakes and a new CPP proportioning valve for the setup. I bent up new lines from the master cyl to the proportioning valve I have the one going from the rear of the cyl to the front brakes and from the front of the cyl to the rear brakes. I started off by bleeding the rear brakes, got those working. Then moved to the front passenger side wheel and bled that one and then to the drivers side wheel. Then I discovered that the shuttle valve moved forward and cut off the front brakes. So i reset it and bled and bled and bled to get any air out. Now when I press the brakes it feels normal then there's a sort of a click or pop and then the fronts kick in and start working. While driving the shuttle valve seems like it moves forward or something and then I only have rears if I reset it I get fronts for a while then it moves forward again! Sorry for the long message....
06-05-2009, 05:06 AM | #158 |
The front of the master cylinder goes through the front of the proportioning valve and then to the front brakes. The rear goes to the rear. I looked through your pictures until I found one that showed the brake lines and it looks to me like you have them flipped.
I also noticed that you mounted your CPP prop valve low on the firewall. I'm not sure why but if you would have used the bracket to mount it on the mc mounting bolt the lines would have fell in place. I used a slightly different booster and mc so I had to bend up a different rear mc to valve line than was supplied with the kit but the front lines were perfect as is. Here's mine using a CPP prop valve. Tom Last edited by basketcase; 06-05-2009 at 05:07 AM. |
06-05-2009, 02:49 PM | #159 | |
69' Chevy Stepside
06-05-2009, 05:11 PM | #160 |
Absolutely beautiful truck! Love the color. Congrats!
-- Tall, Dark and Handsome... Or so my mother says -- There is no fate, but the fate we make. |
06-05-2009, 06:39 PM | #161 |
69' Chevy Stepside
06-05-2009, 10:06 PM | #162 |
69' Chevy Stepside
Well I installed the bed wood and strips today temporarily until I get a fuel pressure regulator for the inline fuel pump setup that I need to install. But for the moment its complete until I have to install that pump.
I ran the vent line for the gas tank up the stake pocket but I need a filter or something for the end of it so water doesn't get down it.... Couldn't put in some bolts because of the gas tank and filler neck.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 06-05-2009 at 10:08 PM. |
06-05-2009, 10:20 PM | #163 |
spirit rider66
Location: pahrump, nevada, in the bowels of the Mojave desert
Hi Matt;, just going to put my two cents worth of praise ,,cool looking truck you did an awesome job on it and you did it in Alaska, "WOW" it couldn't have been any harder, but you did it Matt, love that color, matches your hair, lol lol
i went through the whole thread and how did you get the bed done,liked what you did with the seats and the center consul ,, cool dude,, and to finish ,i'm going to say how jealous i am, your work on the truck could be your future, keep up the nice work . only i wish i was 30 years younger, I'm 66 now and just finishing my restore on my 70 1/2'er. it's taken me a year and a half, and loved every minute of the rebuild, congratulations to your work. OK caught the last few pics ,,nice job on the bed. Larry
:Chevy: If you don't run your own life,, some one else will. to our vets,, welcome home,, and thank you for your service.:Chevy: Last edited by seldomseen65; 06-05-2009 at 10:23 PM. |
06-05-2009, 11:13 PM | #164 |
Use a check ball style vent for a motorcycle. That's exactly what I did on my truck. My truck has sat outside 24/7 since Nov. 2006 and I never got water in my tank.
I don't want to mess up your thread with pics of my truck, so check out post # 202 & 203. http://67-72chevytrucks.com/vboard/s...+thread&page=9 Your truck came out beautiful, I love it!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 06-05-2009 at 11:14 PM. |
06-06-2009, 12:26 AM | #165 | ||
69' Chevy Stepside
06-06-2009, 04:47 AM | #166 |
Glad to help.
The bed looks fantastic. I'm guessing you won't be stacking concrete blocks in there anymore. What kind of wood did you use? Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
06-06-2009, 10:00 AM | #167 |
If you can't find one local, they're on ebay too (this is where I got mine.)
http://cgi.ebay.com/ebaymotors/Gas-F...Q5fAccessories
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
06-06-2009, 07:00 PM | #168 | ||
69' Chevy Stepside
06-07-2009, 02:30 PM | #169 |
low n' slo
amazing job man, nice color choice too. now you need to bag it! lol great truck..
06-07-2009, 02:47 PM | #170 |
low n' slo
oh, what did you use to strip it down to metal?
06-08-2009, 02:37 AM | #171 | |
69' Chevy Stepside
I just used a DA Sander, Wire Wheel on a grinder and a grinder on heavy rust or welds.
06-09-2009, 03:02 PM | #172 |
69' Chevy Stepside
Well fixed my brake problem I did as basketcase said and plumbed new lines from the master cylinder to the proportioning valve. This completely fixed the problem now I have good front and rear brakes. Here's a pic:
07-02-2009, 06:17 PM | #173 |
69' Chevy Stepside
I installed a Compustar Pro Security System In the truck last weekend. Now I can remote start it (yes pointless). The main reason I got it was because it has a very good security system. Door sensors, hood, shock sensor, and starter kill relay. Anyway seems to work good. It's pretty funny being able to remote start such a old truck. Still need to fix a power steering leak and install the rear view mirror on the windshield. I'll put up some pictures of the security system tomorrow.
07-03-2009, 08:55 AM | #174 |
On the fast track to nowhere..
Your truck looks really good man. It's been a lot of work but you stuck it out until the end and finished it and that's about as hard as the work Enjoy driving that thing!
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
07-03-2009, 09:34 AM | #175 |
Beautiful Truck!!
