Old 12-18-2009, 08:09 PM   #151
Willys47
Willys47's Avatar
Re: Header Solution
pic would be nice please
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 12-18-2009, 08:24 PM   #152
weircc
weircc's Avatar
Re: Header Solution
are these in stock ready to ship cause i have been watching this post for months and doesn't seem like anything has changed and i would like a set, first gen big block stands and mounts with 700r4
weircc is offline   Reply With Quote
Old 12-19-2009, 02:11 AM   #153
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
The SB ones are $550.00 bare, $865.00 CHROMEX ceramic coating, and $975.00 stainless 304.
Jokers69 is offline   Reply With Quote
Old 12-19-2009, 02:17 AM   #154
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
The BB one are not in stock they will have a final test fit on monday. I will post installed picture then. They will not be available with 3.5" ball and socket collectors. (no tooling available for that) I will keep you all posted. Thanks
Old 12-19-2009, 02:40 AM   #155
Willys47
Willys47's Avatar
Re: Header Solution
will the bbc be in stainless 304 as well?
Old 12-19-2009, 03:05 AM   #156
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
The BB ones will not be available in stainless at this time. It maybe something we work on in the future. We don't have the ability to bend the 2" stainless at this time. Thanks
Old 12-29-2009, 02:36 PM   #157
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
The BB headers are done. Here is some pics of them installed before and after paint. We have 2 sets in stock and working on a couple more. I have a couple of more pictures on the camera I will post when I download them.
Old 12-29-2009, 03:11 PM   #158
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Here are the rest of the pictures.
Old 12-29-2009, 09:27 PM   #159
weircc
weircc's Avatar
Re: Header Solution
my question is will they work with pre 72 stands cause looks like 72's in picture
Old 12-29-2009, 09:52 PM   #160
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
They are 72 stands. They should work with no problems. I'm looking for a early year local truck to test fit them on now.They have plenty of room.
Old 12-29-2009, 10:37 PM   #161
Willys47
Willys47's Avatar
Re: Header Solution
will they be in the CHROMEX ceramic coating as well if they fit the pre 72 and they look like they will you will need to ship some up to Canada. Boy do they look good!
Old 12-29-2009, 10:49 PM   #162
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Yes they are available with Chromex coating.
Old 12-31-2009, 09:57 PM   #163
Dan 67 Chevy LWB
Re: Header Solution
How much for the coated BBC?
Dan
67 Chevy LWB, Small Window - In the process of being rebuilt. Small Block is coming out & I'm gathering parts to switch to a Big Block 496.
Dan 67 Chevy LWB is offline   Reply With Quote
Old 01-01-2010, 12:23 AM   #164
Brewski*
Brewski*'s Avatar
Re: Header Solution
I know this has been asked but I don't have time to read all 7 pages Will they fit a 3/4 ton 4x4 Manual? small block?
Brewski* is offline   Reply With Quote
Old 01-01-2010, 11:25 AM   #165
327-C10
Re: Header Solution
Originally Posted by Jokers69 View Post
These will not work on manual transmission with factory clutch linkage. The headers tubes will not fit around the clutch linkage.
WOW they are impressive. Are you going to develop a header for us standard transmission guys?
As a side question is the clutch linkage problem typical of all headers?
327-C10 is offline   Reply With Quote
Old 01-02-2010, 06:35 PM   #166
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
No they won't work on manual transmission. The problem is to keep them above the frame it won't fit with the manual factory clutch linkage.
Old 01-04-2010, 11:40 AM   #167
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
BB Headers coated will be $925.00 with chromex coating.
Old 01-04-2010, 03:14 PM   #168
70stroker
70stroker's Avatar
Re: Header Solution
I am in need of these still. when will you be able to have more in stock? cost, and different coating options?
70stroker is offline   Reply With Quote
Old 01-04-2010, 03:57 PM   #169
fbird68
fbird68's Avatar
Re: Header Solution
Awesome job on the headers and thanks for going through the hassle! I'll be looking for results of a test fit on the pre 72 then will order a set.
Richard
STR Restoration and Customs
1971 C10 Custom
1964 Impala 2dr Hardtop
1965 Parisienne CS
1937 Nash Lafayette
1947 Willys CJ-2A
fbird68 is offline   Reply With Quote
Old 01-04-2010, 04:03 PM   #170
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
We have them in stock now. As for coating options they come bare or Chromex coated. $575.00 bare or $925.00 coated.
Old 01-07-2010, 07:55 PM   #171
chevy71c10
chevy71c10's Avatar
Re: Header Solution
Just wanted to drop a line and say the coated headers arrived and look better than I expected, also a day early. Can't wait to get them installed, maybe late next week to mock-up for the exhaust routing. Thanks for the great transaction!
Justin
71' C10 SWB
00' Dakota R/T
05' Z-71 Silverado
16' Z-71 Silverado
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904
chevy71c10 is offline   Reply With Quote
Old 01-28-2010, 06:23 PM   #172
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
The BB header will not fit the 67 frame rails. We tried repositioning the tubes but with 2" primaries spark plug access would be almost impossible without pulling header loose. For those willing to trim the frame rails you can make them work. Sorry for the inconvenience we thought they would fit them all.
Old 01-28-2010, 06:48 PM   #173
70stroker
70stroker's Avatar
Re: Header Solution
shouldnt have a problem with 70 rails with pre 72 stands correct?
Old 01-28-2010, 07:26 PM   #174
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
I am looking for a 68-71 BB truck to fit them in right now. But it looks like they will fit it just the 67 upper frame rail is to wide.
Old 01-30-2010, 10:25 PM   #175
Dan 67 Chevy LWB
Re: Header Solution
So just the top of the 67 frame rail is wider? How much will need to be trimmed on the frame for the BB headers? How much wider is the 67 verses the other years?
Any word on the BB Stainless?
Dan
