Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-08-2010, 06:29 PM   #151
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 72 GMC 4x4 rebuild
That looks really nice!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-15-2010, 09:57 PM   #152
Mr-Jack
Beer Drink'n Knuckle Dragger
Mr-Jack's Avatar
Originally Posted by Crumley View Post
I also installed a new adjustable offset drag link. The stock one was on a steep angle due to the instillation of the 6" lift. Trying to eliminate bump steer.
Here are some pictures:
Where'd you get your drag link from...do you have any specs on this? i'm lifting my truck and need something like this...thanks
Jack
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US
- 67 GMC Long-Wide 350/SM420
My BACON Wrapped Meatloaf Recipe
Mr-Jack is offline   Reply With Quote
Old 03-23-2010, 08:52 PM   #153
Crumley
Crumley's Avatar
Mr-Jack:
The offset drag link came from 4 Wheel Parts Wholesalers. They have quite a number of stores around the US. I called one closest to me and found out they had one is stock. I drove over to the store and picked it up. It works great. If you need offset specs, let me know I will will measure the one I have.
Crumley is offline   Reply With Quote
Old 03-23-2010, 09:14 PM   #154
Mr-Jack
Mr-Jack's Avatar
if you can measure that would be awesome...looks like a 3" drop drag link just from eye balling it. but better safe than sorry, also do you know what rod ends those are? i'm lifting mine 6-7 inches and will most definately need something like this. Is that adjustable too?
Old 03-27-2010, 11:57 AM   #155
Crumley
Crumley's Avatar
Mr-Jack:
The drag link has an offset of 3-1/2" center to center. The tubing is 1-1/4" OD with thread ends. It has heavy duty rod ends. It is adjustable. The rod ends have zerk fittins for greasing.
With the 6" lift, raised steering arm and offset drag link, it drive and steers quiet nicely atleast for an old streight axle pickup. Very little to no bump steer. The only complaint I can come up with is the Grant 13-1/2" steering wheel is to small. I will be upgrading to a larger 15-16 inch steering wheel in the future.
Old 03-27-2010, 05:04 PM   #156
jimmypop
More pictures of it in the shop with the cowel cover on.
Regular work has been slow (been working 24 hour work weeks) so money is short.
I am having to save up the cash to get the windshield and back window installed. I feel this process is best saved for someone that doest it everyday.
Your Truck looks great!
what year hood are you using?
jimmypop is offline   Reply With Quote
Old 03-27-2010, 05:50 PM   #157
Crumley
Crumley's Avatar
Jimmypop:
It is a 67-68 chevrolet hood. If the 67-68 hood is used on a 69-72 model the hood bump stops will need to be relocated.
Old 04-03-2010, 01:57 PM   #158
Crumley
Crumley's Avatar
Mr-Jack:
These pictures of the offset draglink are for you. I hope the picture with all of the writing on it make since. The pitman arm is stock If you have questions drop me a line or two, to help clarify.
Old 04-03-2010, 08:29 PM   #159
Mr-Jack
Mr-Jack's Avatar
looks good. i've located the drag link at 4wheelparts.com did that raised steering arm come with a lift kit? and looks like you're running the stock 1/2 ton 10 bolts front and rear right? Thanks again for taking the time to measure that drag link Crumley!
Jack
Old 04-03-2010, 09:06 PM   #160
msgross
msgross's Avatar
Mr Jack,
There is a raised steering arm for sale on the parts board if you need one... do a search and you'll find it...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-04-2010, 01:40 AM   #161
Mr-Jack
Mr-Jack's Avatar
Originally Posted by msgross View Post
Mr Jack,
sweet...i just responded to it!
Jack
Old 04-04-2010, 01:36 PM   #162
Crumley
Crumley's Avatar
Well after lots of rotory fileing, cutting and adjusting I got the new aftermarket tail gate trial fit. Not impressed, very flimsey metal. I am afraid to breath on it because it might make a dent. The metal is just a little thicker then aluminum foil.
For now, I will run the after market talegate until I can repair the factory one. For the picture hounds out there here ya go:
Old 04-04-2010, 01:59 PM   #163
Crumley
Crumley's Avatar
Mr-Jack:
The truck has the factory front and rear 1/2 ton axles. The front is a 10 bolt axle and the rear is a 12 bolt axle.
Old 04-04-2010, 05:27 PM   #164
Mr-Jack
Mr-Jack's Avatar
cool...you have any plans for a front bumper, or you gonna leave it open? I think it looks pretty good without it actually. i've seen a few lifted classic chevy trucks running on front bumpers and they look pretty nice. It's making my decision to leave mine or take it off that much harder
Old 07-03-2010, 12:02 PM   #165
Crumley
Crumley's Avatar
Update on the truck build: Sorry I haven't been posting much. I have been pulling my hair out working on an 1980 corvette.
Mr Jack: I will eventually install the front bumper. The origional one has a few dents in it. They will need to be heated up and knocked out. I will sand the chrome plateing off and paint it silver like the back bumper. Or I will save money and buy a new aftermarket chromed one....
Well I finally got the tailgate painted and installed on the truck. I also installed the wide tail gate molding. I am currently debating installing the upper molding.
The old truck now has approx 1000 miles on it since the build. Luckly I have only had a few minor problems. It is probably getting about 11-12MPG, but who cares it is a awsome truck.
Old 07-03-2010, 08:06 PM   #166
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
The truck looks prefect man good work!
Tony
Old 01-15-2011, 05:42 PM   #167
Garys57
I just came across your build thread and read it start to finish. You did a great job and the truck is the best!
To be truthful, I was never a huge fan of long wheelbase pickups.........but
I gotta say I would love to have it parked in my driveway. Congrats on all
the great work you did and to have a finished product like you got is nothing
but the best !
Hope you enjoy it to the max and drive it as much as you can !
Good luck !
Garys57 is offline   Reply With Quote
Old 01-15-2011, 06:59 PM   #168
Crumley
Crumley's Avatar
Thank you Garys 57.
I had alot of fun working on it. I am currently looking for another project car/truck to work on. The corvette is an absoulute pain in the a$$ to work on and everthing is expensive to buy. I have lost interest in it.
If I where to do the 72 GMC again I wouldn't put the 6" lift under it. It looks awsome with the lift, but it is a pain climbing into it, especially on a hill.
Old 01-15-2011, 09:55 PM   #169
j.kirn
Very nice truck indeed great work
j.kirn is offline   Reply With Quote
Old 01-16-2011, 12:36 AM   #170
lycominghunter
sweet!!
lycominghunter is offline   Reply With Quote
Old 01-18-2011, 09:26 PM   #171
JPCY72
how does it ride compared to stock with the lift?
JPCY72 is offline   Reply With Quote
Old 01-20-2011, 02:43 PM   #172
Crumley
Crumley's Avatar
The lift springs are stiffer then the stock ones, so it is is a little more harsh while traveling over bumps. With the 6" lift it actually drives decient not as good as it does at the factory height. It tends to wonder in turns. Requiring more steering wheel input.
Old 03-11-2011, 08:47 PM   #173
RShaips
Love your truck build! I am in the process of a 72 Jimmy 4wd body off build. I really like that hood on there. Was the only thing you needed to change was the bump stops? I may want to do that with mine. Awesome build, really like it. I had a 6" lift on mine and really had a tough time getting it to drive right. I think I will put a 4" lift on when it goes back together. Thanks for the post, nice job.
RShaips is offline   Reply With Quote
Old 03-14-2011, 03:16 PM   #174
Crumley
Crumley's Avatar
RShaipes:
Thank you for the truck compliment. The hood is off a 67-68 chevy/GMC pickup. Try and find one that doesn't have the trim holes in it.
There is a little more to do then relocating the hood pads. All of the rivits holding the top chrome trim on will need to be drilled out. This chrome piece will need to be removed. The origional pad brackets will need to have some extensions welded on to move the pad to the new location. Some angle brackets will need to be bent to attach the grill to the latch assembly
Attached are a few pictures, hope this helps. Feel free to ask any questions you might need.
Please overlook all of the dust on the latch assembly. The truck has been sitting awhile in my shop.
Old 03-14-2011, 07:53 PM   #175
RShaips
That doesn't look too tough to do. Thanks for the close up pics. Can you take a close up of the grill and how it meets the hood. The gap between the hood and grill is what i am wanting to see. You also did not put the trim on the fenders either? I like the look, the last truck i did was a 67 SB 2WD and I love the front end on it, but I really like yours!
