Old 08-09-2009, 06:53 PM   #151
carney725
Re: Project '86
looks awesome man, deff subscribing to this one.
carney725 is offline   Reply With Quote
Old 08-10-2009, 10:56 PM   #152
dv8customs
dv8customs's Avatar
Re: Project '86
Got the bed off today and started unbolting the cab. Got the rear two bolts out but after a couple of turns both front bolts started spinning. From what I can tell my only option is to cut a hole in the floor to get the nut. Hope to get the cab off before the end of the week and start on the frame work this weekend.
dv8customs is offline   Reply With Quote
Old 08-10-2009, 11:52 PM   #153
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Project '86
That's exactly what I had to do on one of my front bolts. A just used a hole saw then welded the nut to the support.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 08-11-2009, 09:13 AM   #154
dv8customs
dv8customs's Avatar
Re: Project '86
So when I cut the hole what am I going to find in there? Did they just have a nut welded on and I can remove it with a socket or is it something I will have to weld back on before I can remove the bolt.
Old 08-11-2009, 11:19 AM   #155
smashingchuck
Re: Project '86
There is a square nut that is captured by the support piece. What happens is the support piece gets out of shape (gets bigger) and allows the nut to spin. I just through a tack weld on mine and left it in there, and backed the bolt out. Piece of cake.
78 Build Thread
4Runner Build
Old 08-11-2009, 06:22 PM   #156
jrsmith_2010
I like turtles...
jrsmith_2010's Avatar
Re: Project '86
lookin threw here, where did u relocate your gas filler after you shaved the door?
jrsmith_2010 is offline   Reply With Quote
Old 08-11-2009, 08:38 PM   #157
dv8customs
dv8customs's Avatar
Re: Project '86
The plan is to put a fuel cell in the rear and relocate the fuel filler to the filler panel at the rear of the bed. I had never seen that done until I came across this picture yesterday. If this guy got it to work hopefully I can to.
Old 08-11-2009, 10:20 PM   #158
jrsmith_2010
I like turtles...
Re: Project '86
wow that will look really good! i like it
Old 08-12-2009, 08:08 PM   #159
dv8customs
dv8customs's Avatar
Re: Project '86
Old 08-12-2009, 09:27 PM   #160
jrsmith_2010
I like turtles...
Re: Project '86
hey man, what kind of fittings do u have on the front bags? where did u get them?
Old 08-12-2009, 10:51 PM   #161
dv8customs
dv8customs's Avatar
Re: Project '86
Push to connects right now but the whole thing is going to be done in stainless before the body goes back on.
Old 08-12-2009, 11:03 PM   #162
jrsmith_2010
I like turtles...
Re: Project '86
Old 08-13-2009, 07:19 AM   #163
dv8customs
dv8customs's Avatar
Re: Project '86
Suicide Doors.com
Old 08-13-2009, 03:02 PM   #164
bigbadjohn84
Re: Project '86
question. in looking at your front suspension, I see you used Suicide doors upper A-arm mounts and the factory front crossmember. did you cut the spring cups off of the crossmember, have it boxed in, and then have the upper bag mounts bolt up on the frame? the front is Z'd right? I think I remember you saying the front track is narrowed. how did you accomplish that with factory A-arms? is that what the upper bracket does? I was curious of this, trying to save from droppin 2500 on a drop member. are you running factory steering setup?
bigbadjohn84 is offline   Reply With Quote
Old 08-13-2009, 04:24 PM   #165
dv8customs
dv8customs's Avatar
Re: Project '86
Originally Posted by bigbadjohn84 View Post
Did you cut the spring cups off of the crossmember, have it boxed in, and then have the upper bag mounts bolt up on the frame?
Yes.
Yes
The upper brackets move the arm position up 3" and in 1-1/8". I moved the lower mounts up 3" and in 1-1/8" to match.
I am going to run a rack and pinion.
Old 08-13-2009, 05:31 PM   #166
smashingchuck
Re: Project '86
Have you considered adding a sway bar to the equation?
78 Build Thread
4Runner Build
Old 08-13-2009, 05:37 PM   #167
dv8customs
dv8customs's Avatar
Re: Project '86
Nope
Old 08-13-2009, 06:36 PM   #168
bigbadjohn84
Re: Project '86
looking at the crossmember, the lower A-arms bolt to the crossmember. how did you move it up and inward??
Old 08-13-2009, 08:45 PM   #169
dv8customs
dv8customs's Avatar
Re: Project '86
Measure, measure, measure, cut, weld...
Old 08-14-2009, 07:37 AM   #170
bigbadjohn84
Re: Project '86
HOLY CRAP!! lol.. I am gonna have to save those for future use for sure! thanks for sharing
Old 08-14-2009, 09:03 AM   #171
dv8customs
dv8customs's Avatar
Re: Project '86
NO problem, if you do something similar just make sure you brace it properly because you remove a lot of strength. Those pieces you can see from the bottom are cut from 1/2" plate and are about 1 1/2" tall.
Old 08-14-2009, 09:50 AM   #172
bigbadjohn84
Re: Project '86
yea. i have quite a bit of scrap 1/4" plate laying around. I always tend to over build things.. just cause I worry about it not being stong enough.. lol
Old 08-14-2009, 02:04 PM   #173
johnboyon20s
Re: Project '86
looks like a 88-98 bed floor and gas door, and it looks good between those 67-72 bedsides
johnboyon20s is offline   Reply With Quote
Old 08-19-2009, 08:03 PM   #174
dv8customs
dv8customs's Avatar
Re: Project '86
What I got done over the weekend. Little rust from the rain but it's coming along.
Old 08-19-2009, 08:11 PM   #175
smashingchuck
Re: Project '86
Get some gussets on that z!
Are you cutting the pinch weld off?
78 Build Thread
4Runner Build
