Old 01-05-2010, 11:04 PM   #151
brian69longbed
brian69longbed's Avatar
Re: My 69 longbed
maybe fininsh the cab and work on my frame next
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=354115
brian69longbed is offline   Reply With Quote
Old 01-05-2010, 11:12 PM   #152
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
good progress!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-06-2010, 11:11 PM   #153
brian69longbed
Re: My 69 lonbed
got my custom plate today. it fits and yes it is registered,... and insured.. and in a THOUSAND PIECES!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 01-06-2010, 11:18 PM   #154
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
Cool! I know...I need to actually call my agent...I've had full coverage on the truck and It's frame off :loL:
Old 01-10-2010, 10:59 PM   #155
brian69longbed
Re: My 69 lonbed
outside of frame
PLASMA!
plasma does a great job
plug weld filled
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 01-10-2010, 11:03 PM   #156
brian69longbed
Re: My 69 lonbed
i decided to go this route with my frame to match the angles of my fish plate.
when i boxed my frame i kinda screwed up and made the box plate go to a point in the middle of the 2x5 tubing shown in the bottom of the first picture. i made one of the inside frame box plates match the fish plate angle today but didn't finish it. more to come
THIS LOOKS MUCH BETTER!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 01-16-2010, 10:41 PM   #157
brian69longbed
Re: My 69 lonbed
well got an early start this morning and it somewhat paid off. got the pass side of the frame painted black and continued with my 50 degree angle box plating(see pictures above). a little more cleaning up and the whole frame should be in paint and 90% done. Also went to harbor freight tools to buy 5" casters to roll the frame around on, to my surprise PARKING LOT SALE! my casters were half off at 4 bucks each! pictures to follow hopefully tommorrow
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 01-16-2010, 10:54 PM   #158
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
cool...where are the pictures
Old 01-17-2010, 10:51 PM   #159
brian69longbed
Re: My 69 lonbed
4 dollar casters
Name:  frame pomona weekend 001.jpg
mounted as easily as possible
Name:  frame pomona weekend 006.jpg
welded
Name:  frame pomona weekend 002.jpg
smoothed out
Name:  frame pomona weekend 008.jpg
PAINTED!
Name:  frame pomona weekend 009.jpg
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 01-17-2010, 10:55 PM   #160
brian69longbed
Re: My 69 lonbed
went to the pomona classic auto parts swapmeet and scored this tilt column shift for 80 bucks. came out of a 75 chevy van. should work very close to my stock one.
Name:  frame pomona weekend 004.jpg
comparison side by side. the steering shaft in the van column is about an inch longer but the body of both columns are identical
Name:  frame pomona weekend 007.jpg
and i couldn't leave without these. 50 bucks for all of this eye candy
Name:  frame pomona weekend 003.jpg
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 01-17-2010, 11:01 PM   #161
brian69longbed
Re: My 69 lonbed
and since i scored a column shift i could finally fill this hole in my trans cover
Name:  frame pomona weekend 010.jpg
This is my first time using a TIG [thanks Chris (orange71)]
Name:  frame pomona weekend 011.jpg
up close.(sorry for the picture quality) this was about my best weld just being honest. NEED MUCH MORE PRACTICE!
Name:  frame pomona weekend 012.jpg
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 01-17-2010, 11:36 PM   #162
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
Looking good man. Keep at it.
Old 01-18-2010, 12:28 AM   #163
nuke1
nuke1's Avatar
Re: My 69 lonbed
some nice scores there, and by the time you are done welding, you will be a pro.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-18-2010, 01:09 AM   #164
mcbassin
Still Learning
mcbassin's Avatar
Re: My 69 lonbed
Looking good! Tig welds look good too!
mcbassin is offline   Reply With Quote
Old 01-23-2010, 08:31 PM   #165
brian69longbed
Re: My 69 lonbed
began installing porterbuilt hood hinges today. went very easy. looks and functions great.
THANKS NATE
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 01-23-2010, 08:33 PM   #166
brian69longbed
Re: My 69 lonbed
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 01-23-2010, 08:35 PM   #167
brian69longbed
Re: My 69 lonbed
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 01-23-2010, 08:37 PM   #168
brian69longbed
Re: My 69 lonbed
and i bolted my trans cover in. no biggy but STILL SOMETHING!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 01-23-2010, 09:15 PM   #169
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
looks good. nice clean job on the hinges...
Old 03-15-2010, 07:17 PM   #170
brian69longbed
Re: My 69 lonbed
wow its been too long.
i started back on her this weekend.
been burned out i guess??
cab after blasting myself
Name:  cab and frame 001.jpg
this one is obvious
Name:  cab and frame 006.jpg
fender da
Name:  cab and frame 002.jpg
more daName:  cab and frame 003.jpg
finished with abraisionName:  cab and frame 004.jpg
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 03-15-2010, 07:19 PM   #171
brian69longbed
Re: My 69 lonbed
fender in primerName:  cab and frame 007.jpg
this is where it gets exciting!!Name:  cab and frame 009.jpg
starting to look like a truck again!!!Name:  cab and frame 010.jpg
Name:  cab and frame 011.jpg
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 05-17-2010, 10:53 AM   #172
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
Any recent updates?
Old 05-17-2010, 11:01 PM   #173
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: My 69 lonbed
Looking Awesome! I know that feeling ya get when it starts taking shape, puts a grin on my face!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 05-18-2010, 01:07 AM   #174
mcbassin
Still Learning
mcbassin's Avatar
Re: My 69 lonbed
Ditto on the updates?
Old 08-04-2010, 12:30 AM   #175
brian69longbed
Re: My 69 lonbed
been a while since i've been on here. its kinda hard to get motivated when people don't comment on little updates, but, you see the threads that take off and everyone comments. thats kinda why i've been gone for a while. well as far as updates go, i mocked up the bed sides and started doing body work. the doors are aligned and the hood is on. i had the core support on but took it off because the cancer on it took away from the beauty of all that primer ha ha. i scored on some complete 9" rear ends for 25 bucks apiece! one was a straight 9" the other was a 9 and 3/8s. the 9 has 28 spline the other had 31. i cut all the brackets off and dropped the 9 inch housing and the 31 spline axles off at currie today to be shortened down to 55" total legth. that'll give me 8" from flange to bedside inner! looks like im running 12" rims! also bought 20' of 1 3/4" .120 wall DOM today, which will be my rear suspension links.
I'll try to make it on here att least once a week. thanks old faithfuls!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
