Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 06-24-2017, 11:08 PM   #151
Captainfab
60-66 Nut
Re: '60-'62 POwer Brake Booster Adapter Bracket With A Clutch
PM sent
Originally Posted by Eyreone View Post
Hello Captianfab, I am very interested in purchasing the brake booster bracket with clutch and for a 1960 c10. Please PM me with information on how to do so. Thank you
Old 06-26-2017, 10:43 AM   #152
sirJim
Originally Posted by mojakeke View Post
It doesen't seem like there will be an issue to install it on mine, If so, I'm intrested on this option(#2), and woul like info on other options for color, Thanks!!!!
I am working on one with the same spring (62 chevy suburban) I have put 2 washers on the lower block on the firewall to change the angle a bit. Just have to figure out the placement on the pedal for the right through length.
sirJim is offline   Reply With Quote
Old 06-26-2017, 11:08 PM   #153
Captainfab
60-66 Nut
Isn't there another clutch return spring elsewhere, so you can remove that huge spring and bracket? I do not currently have a '60-'62 cab to look at, but I do not recall seeing that spring on all the '60-'62's.
Old 06-27-2017, 08:53 AM   #154
3100 Stepside
It seems to be a help spring for an softer clutch.
We are adding a 2 washer spacer to change the angle a bit with a longer bolt to keep the original spring and gain the small amount of clearence needed. Should Work fine Ill keep you informed and try to take Pictures.
3100 Stepside is offline   Reply With Quote
Old 06-27-2017, 01:10 PM   #155
sirJim
Here is the mod I made just a small adjustment in the angle, 2 washers width.
Old 10-17-2017, 11:57 PM   #156
Captainfab
60-66 Nut
All of my booster brackets now come with slotted booster mounting holes to also accept aftermarket universal boosters with the 2-3/8" x 2-3/8" center to center mounting studs.
Old 01-10-2018, 01:09 AM   #157
Captainfab
60-66 Nut
I am officially notifying everyone that I will be on vacation from 02-05-18 thru 02-13-18. I will do my best to get all orders built and shipped before I leave, if placed by 01-31-18. Orders placed while I am gone will be built and shipped in order of receipt of payment once I return. Thanks for understanding.
Old 05-24-2018, 12:29 PM   #158
62chevy302
hillbilly
62chevy302's Avatar
I am using a nv3500 5 spd with internal slave cylinder. The factory master for this slave cylinder is 18mm. I would need a clutch master that matches that. Also i would like to do the lower pedal mod that i have seen many do where it lowers all the pedals. Will your linkage allow for the shorter throw of the clutch since it will be closer to the floor?
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 05-24-2018, 11:52 PM   #159
Captainfab
60-66 Nut
I have a .700" bore clutch master in stock. The threaded rod between the clevis and the rod end could be shortened. This depends on how much you are going to move the pedals. In moving the pedals, you will need to maintain the original pedal travel distance. If that is not possible, we may need to increase the bore size of the clutch master.
Old 05-25-2018, 09:13 AM   #160
62chevy302
hillbilly
62chevy302's Avatar
I am sure it will be a shorter throw. Do you think that you could get by with a straight rod going in the clutch master cylinder
-1962 C-10
Old 05-26-2018, 01:19 AM   #161
Captainfab
60-66 Nut
It is possible but hard to say for sure until the pedal assembly is done and you see what the stroke of the clutch pedal is where the clutch master will have to attach.
Old 01-18-2019, 12:29 AM   #162
Captainfab
60-66 Nut
The Wilwood clutch masters went up in price again, so I had to raise my price on this conversion.
Old 07-02-2020, 10:10 PM   #163
bhap
bhap's Avatar
Hey CaptainFab, I'm finally getting around to installing your power brake booster bracket and have a quick install question. On the clutch bracket that mounts on the inside of the firewall there are two hex shaped spacers welded to the bracket, one is threaded, the other is not. At the tip of the spacers there are small "nubs" - one on each spacer. What is the purpose of these nubs? Do I just tighten the mounting bolts and pull them into the metal on the firewall? I'll attach a couple of pictures so you can see what I'm talking about. Thanks for your help - this is definitely a well made piece!
bhap is offline   Reply With Quote
Old 07-04-2020, 10:11 PM   #164
Captainfab
60-66 Nut
I replied to your PM. I am only here on the forum once a day. If you require a quicker reply, please send me an email. I answer all emails 4-5 times a day 7 days a week.
Old 07-08-2020, 10:28 PM   #165
CC's 62
I'm also close to installing your power brake booster bracket and was wondering the same as bhap. Thanks
CC's 62 is offline   Reply With Quote
Old 07-09-2020, 10:20 PM   #166
Captainfab
60-66 Nut
The notches machined in the ends of the coupling nuts are there for a specific reason. They are machined like that to straddle the double sheetmetal lap joint on the inside of the firewall and keep the pivot mount sitting flat.
Old 03-31-2021, 04:35 AM   #167
Evkev
Man I just noticed where you are Captain Fab. I live in Chewelah Wa. Can a guy come see you and get parts? I definetly need the booster and master cylinder set up for my 60.
Owner Operator at DMC Square Body and Egg Farm.
Evkev is offline   Reply With Quote
Old 03-31-2021, 09:58 PM   #168
Captainfab
60-66 Nut
Yes you are welcome to come pick up your order at my shop. But I do not have any products welded up and sitting on shelves. All orders are build in the order received. Due to an overwhelming number of orders, I am currently 25 days out on building and shipping orders. I will need to know what you are using for a clutch slave cylinder or hydraulic release bearing.
Old 06-27-2021, 08:26 PM   #169
Captainfab
60-66 Nut
Due to an increase in the cost of having my parts laser cut, I have been forced to raise my prices. I'm not making any more money, just trying to stay in business with these increases in my costs. Thanks for understanding.
Old 01-09-2022, 04:46 PM   #170
saltcity62
Great product. Worth every penny!
saltcity62 is offline   Reply With Quote
Old 01-11-2022, 10:53 PM   #171
Captainfab
60-66 Nut
Thanks for the kind words, I appreciate the purchase. What diameter is that booster?
Old 01-16-2022, 06:57 PM   #172
saltcity62
It is a 8" single diaphragm from CPP.
Old 01-17-2022, 10:55 PM   #173
Captainfab
60-66 Nut
How well does your truck stop with that small of a single diaphragm?
Old 01-19-2022, 10:56 AM   #174
saltcity62
Honestly it stops great. Good pedal feel after lowering the mounting point an inch on the brake pedal. I'm running wilwood d52's up front and eldorado rears.
Old 01-30-2022, 08:15 PM   #175
AngryPirate
AngryPirate's Avatar
Does anyone have a picture of this part installed?
AngryPirate is offline   Reply With Quote
