#151 |
Re: 71 Cheyenne Super- A Combined Effort
Hey it's looking good on all 4 wheels,you are making alot of headway,when's the date to put cab back on?Cool build,keep the pictrues of the progress coming
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, ![]() |
#152 |
Do you all ever have days that nothing seems to go right? I worked on fitting the driver's side cab corner to the cab yesterday. It took a lot of manipulation to get it right, but I finally got it lined up and tacked it in place. Things were going well, so I decided to weld it solid. The outside turned out OK and won't take much filler to make it right:
![]() However, no matter how hard I tried to get the seam in the back smooth, it got worst. I concluded that the original metal in the cab was very thin (not rusted, just thin compared to the replacement cab corner) and it either warped when I was welding it or I didn't fit the cab corner as good as I thought. I finally gave up when it got to this point: ![]() BLECH! By then, my wife was telling me that dinner was ready, so I put the tools up for the night. However, all I thought about last night and today at work is how ugly the back of the cab turned out. I know some would say, "just finish welding it and let the bed cover it up"....but I just couldn't leave it like that. So, I cut out the worst section tonight and fit a new patch panel to it. I only had enough time to tack it in place tonight. However, I am much happier with how it is turning out. I think it will look much better when it is finished. Here is how I left it tonight: ![]() Have fun with your build and don't give up!
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
#153 |
Still Learning
That looks great to me. And in the long run it may take less time than trying work the worpage out of the thin metal. Keep the pics coming.
#154 |
6>8 Plugless........
![]() Join Date: Sep 2007
Very nice fix on that. I've had the same problem in the exact same area when doing cab corners on these. Maybe the metal is thinner there from where it stretches when the stamp it at the factory? IDK
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#155 |
I thought the exact same thing...it is good to know that others have had problems with that same area.
#156 |
VA72C10
![]() Join Date: Mar 2008
Good work. Always better to do it right than to always have that bothering you later....
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#157 |
A guy with a truck
Looking good. I'm in...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#158 |
Restoration Virgin!
Jesse is the best partner to have on the project!!!....Thanks bud for continuing to move forward on this!!!!.....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#159 |
Nice work!! the truck is coming along great. I have found that cutting out the old cab corner along the body line makes it much easier to weld in the replacement panel. The metal seems to be thicker there and the body line makes the weld disappear.
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see." - Thomas Jefferson 72 C10 SWB "Work in Progress" |
#160 | |
![]() Thanks for the advice bcutt. I thought about cutting it along the body line, but was concerned about how straight it would be after welding. I'll keep that in mind on the next cab corner.
#161 |
![]() Join Date: Jan 2010
Work looks great, you guys are doing a nice job.
#162 |
![]() Join Date: Jan 2009
awsesome build
#163 |
Looking good on the repair,keep the hard work going & keep on truckin''
#164 |
Restoration Virgin!
Ok folks.....Jesse and I decided to gather at my place this weekend and do a little cutting, welding, sweating, shortening, and creating "rust-free"
![]() I bought some decent LWB bedsides to shorten, used this very helpful thread that Rokcrln created to shorten these sides (starts at post #195)...we had a few gap issues to overcome but ultimately got them all tacked together and ready to be finished (I must say I was more of an apprentice/ helper for this weekend's work...Jesse did all of the welds, and most of the cutting...Thanks Buddy!!!!) So for the pictures...using the above thread and double checking our measurements, Jesse begins cutting ![]() ![]() ![]() tada...the first side is completely cut....we did the same for the other one before we lost the daylight (and didn't want to bother the neighbors too much this Friday evening ![]() ![]() So Saturday morning we decide to move the Mistress out so we'd have some shade and be a little cool (suppose to be 95 Saturday...yikes) ![]() get the panels to line up...add panel clips....and hit it with the heat ![]() ![]() ![]() and wa-la....we got ourselves a shortened bedside ![]() ![]() All in all I think it took us 4 hours to cut everything up (had a neighbor stop by with their 3 yr old son who wanted to see what the sparks/ metal was all about ![]() ![]() ![]()
#165 |
Nice work guys!
#166 |
Here is a picture of the fender with the new cup welded in place. We have some rework to do on the front/inside portion of the cup.
![]() Geoff mentioned that his neighbors came over to watch the "fireworks show". Apparently, their son was very intrigued by all the noise and sparks. When he asked about it, his parents told him that we were cutting metal. When they said their prayers that night, the little boy said, "let's pray for the metal". He was very concerned about it! ![]()
#167 |
Still Learning
Nice work on the rust repair and bed modification. Keep the update pics rolling in.
#168 |
VA72C10
Nice work!!!
#169 |
67cheby
![]() Join Date: Sep 2008
nicely done....
#170 |
Just checking up on your build, & i see you've made alot of progress,love the pictures of the bed sides & fender,keep the hard work going forward & pictures coming.Keep on Truckin''
#171 |
fat old dude
![]() Join Date: Feb 2010
good job guys. when your done you can work on mine =]
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
#172 |
Nice work! You guys made that swb cut down look so easy.
#173 |
Yes they do,looking good,keep the pictures of the porgress coming
#174 |
Restoration Virgin!
Sneak peak pic for this weekend's accomplishments....almost time for it to be on its way
#175 |
VA72C10
Looks like a truck
![]() So...are you just meaning it's almost ready for paint and then selling it or did you already line up a buyer before it was completed?
