05-24-2011, 09:08 PM | #151 |
Re: 77 yellow gmc swb
always something simple! lol
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
05-25-2011, 07:53 AM | #152 |
just youre typical DOHW moment
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
05-26-2011, 08:55 PM | #153 |
More progress , I got all the wiring tired up, and the led lights I got for the rear were sticking out to far to get the lens on, so I bent up a box and did a lil filing on the hole , 2 rivets and some silicone and they clear fine !
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237 |
06-10-2011, 10:32 PM | #154 |
I've made some more progress , got all the underhood wiring done , even hooked up a underhood light , made a battery tray with hold down, finally got the drip rails on , I'll never take them apart again, I had to grind some off the base so I could get the ss trim on , now onto the interior next !
06-10-2011, 10:42 PM | #155 |
Clean & simple - love it man!!!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
06-12-2011, 07:09 AM | #156 |
Thanks , I finally got started on my dash panel yesterday ,made from 1/8" aluminum, just taped together at the moment ,
06-12-2011, 07:43 AM | #157 |
Now there's a different look - cool!
06-12-2011, 09:06 AM | #158 |
trick idea
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
06-12-2011, 04:34 PM | #159 |
I had a problem finding LEDs for the rear lights up to now, because they do only light up one way and do not reflect on the reflector. because of that you only get one bright spot in stead of the whole rear lit up.
do you have all LEDs in your rear lights? any pics of all of them installed and pics of them lit up? (sorry for my english, I am dutch).. And I had the problem that there is too little difference between BRAKE, FLASHER and NORMAL light at night..
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
06-12-2011, 04:37 PM | #160 |
Just here to tinker
Wow! I think you are on to something there. That looks like it could've been a GM design. Great job!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
06-12-2011, 05:04 PM | #161 | |
06-12-2011, 07:07 PM | #162 |
NICE !!!!!!!! That aluminum dash panal will look great buffed & polished. Again and as always AWESOME work...
06-13-2011, 10:15 AM | #163 | |
I might even consider doing a mod using these led strips in red: I have been told that white LED behind a red lens dont light up well, so I will go with red LEDs.
06-13-2011, 09:40 PM | #164 |
Thanks guys , I cant wait to get this dash panel done ! as for the led's I bought these http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT and 1156 just like them, I think they work good ,first pic is tailights second is tail ans stop, I also got all the dash wiring tuned up and put some 5mm leds in for the turn signals,brights and low brake, they are bright !
06-13-2011, 11:37 PM | #165 |
Looking good!
Posted via Mobile Device |
06-14-2011, 12:32 AM | #166 |
nice build.
06-14-2011, 03:28 PM | #167 |
nice work on the cluster man is gonna look good once youre done with it.....
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... |
06-15-2011, 12:26 AM | #168 |
Thanks guys , you help keep me motivated ! I got a lil more done on the dash panel, I also made a panel to cover up my air compressor mount and horns after seeing the pic of the taillights on, I really noticed that area needed tuned up,fixed it right up, next I got the washer squiters in so I went to put them on but the cowl hood doesnt have the vents for them to exit so I used an old 1 and made a extension, they exit though 1 of the holes in the cowl of the hood ,I'll clean/paint them up and install tomorrow ,
06-16-2011, 12:55 PM | #169 |
very nice. subscribed
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
06-20-2011, 09:27 PM | #170 |
Thanks ,I got the dash panel tacked together and all fit in with the mounting screws ,also made a plastic template for the column cover,
06-21-2011, 11:32 AM | #171 |
nice work, it looks great.
06-22-2011, 01:07 PM | #172 |
I've been turning new knobs for everything , lights, wipers,turn and tilt levers ... and the heater controls , I had a rough time getting the knobs off the new heater control ,finally ended up cutting them off ,I'll take more pics of them as I get them mounted on ,
06-22-2011, 05:03 PM | #173 |
i think twist style knobs would look better on the truck not sure if they make sumting that would work on the truck setup though
i used to have a opel astra in europe the knobs on that where cable operated and where backlight pulling the middle knob activates the rearscreen heater the 2 push buttons at the bottom are for airco and closing the outside vent (when driving behind a stinking dieseltruck ) its all build together on a plastic frame
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 06-22-2011 at 05:06 PM. |
06-22-2011, 05:24 PM | #174 |
I think the knobs looks AWESOME, unique !!! Also what kind of speedo are you goin use, a 160mph ?
06-23-2011, 12:43 AM | #175 | |
Home Built '87
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
