Old 04-26-2011, 10:10 PM   #151
Indian113
Indian113's Avatar
Re: My 50 roadster pickup build
Lookin good,I'm going to print off this entire thread when your done!
Indian113 is offline   Reply With Quote
Old 04-26-2011, 10:16 PM   #152
oldman3
oldman3's Avatar
Better watch it, the tree lovers will be after you.
oldman3 is offline   Reply With Quote
Old 04-26-2011, 10:21 PM   #153
Indian113
Indian113's Avatar
I get ready to start working on mine I'm going to give you a land line call and bend your ear on some ideas I have going thru my head.
Old 04-26-2011, 11:26 PM   #154
oldman3
oldman3's Avatar
When ever your ready, PM me and we will swap numbers. I'm not the brightest light in the pack, but I put out a little glow.
Old 04-27-2011, 07:07 PM   #155
oldman3
oldman3's Avatar
Going to be installing new latches in the doors. I chose to use bear claw type latches. I had used them before and they worked good. Make sure you buy good quality to start with, not the cheap crap.
My install is a little different from most, as I will be installing mine the opposite of most.
This shows the opening I cut for installing latch.
Old 04-27-2011, 07:10 PM   #156
oldman3
oldman3's Avatar
This is the piece I made with the latch. I chose to mount mine in the back body door opening. I will show why a little later.
Old 04-27-2011, 07:11 PM   #157
oldman3
oldman3's Avatar
Here everything is welded in place.
Old 04-27-2011, 07:12 PM   #158
oldman3
oldman3's Avatar
This is the old latch opening in the door.
Old 04-27-2011, 07:14 PM   #159
oldman3
oldman3's Avatar
Here it is with the striker mount in the door. This left room to reinstall the window channel in stock location.
Old 04-27-2011, 07:18 PM   #160
oldman3
oldman3's Avatar
By mounting the latch in the body it allowed me to make up this manual button system for opening the doors. A hole was drilled in the cab corner, pipe welded to the hole in corner, and a threaded rod thru the pipe with a knob on the end. Push up on the knob and the door pops open. Part way up the threaded rod is a tee mounted, to this I added another rod that will stick out passed the interior panel for inside use. The top of the threaded rod is secured to the lever on the latch.
Old 04-27-2011, 07:19 PM   #161
oldman3
oldman3's Avatar
If anyone wants more info on this just ask, I will make a drawing and take a couple of more pics.
Old 04-27-2011, 07:21 PM   #162
oldman3
oldman3's Avatar
Doors on and working like a charm. Now I can work on the gap a little more.
Old 04-27-2011, 07:23 PM   #163
oldman3
oldman3's Avatar
I decided I did not want any of the vent stuff on the cab. The drivers side was welded shut. This view shows the passenger grill cut out.
Old 04-27-2011, 07:24 PM   #164
oldman3
oldman3's Avatar
Not a good pic, but shows the opening patched with the old grill beside.
Old 04-27-2011, 07:25 PM   #165
oldman3
oldman3's Avatar
This was someone's ideal of a hole for an antenna, or something???
Old 04-27-2011, 07:26 PM   #166
oldman3
oldman3's Avatar
Old area cut out and new patch panel made and installed.
Old 04-27-2011, 07:28 PM   #167
oldman3
oldman3's Avatar
Tomorrow we go back to the doors for more mods.
Old 04-27-2011, 08:58 PM   #168
Indian113
Indian113's Avatar
Post #134 shows that knob pretty good,you have to look for it.I like that idea!!
Old 04-27-2011, 11:37 PM   #169
oldman3
oldman3's Avatar
Good eye, yeah it works real easy.
Old 04-28-2011, 08:13 PM   #170
oldman3
oldman3's Avatar
Here I'm cutting off the top part of door. Cut was made at the top of the body line, this will eliminate where the old window surround was installed. I had to remove this so it was level with the rear of cab.
Old 04-28-2011, 08:15 PM   #171
oldman3
oldman3's Avatar
This pic lets you see what I was referring too. I also had to rework the cab body line to line up with the door better.
Old 04-28-2011, 08:17 PM   #172
oldman3
oldman3's Avatar
By removing the top part of door piece (left) I had to make up a new piece that would stiffing up the top of door, and have a place to attached window felt. The piece on the right is my new piece.
Old 04-28-2011, 08:18 PM   #173
oldman3
oldman3's Avatar
Not a good pic, but if you look at the opening you can see the 1/8" steel piece that was welded in.
Old 04-28-2011, 08:20 PM   #174
oldman3
oldman3's Avatar
Now the inner and outer height is the same. I also modified the inside garnish molding to extend back and tapper to an end.
Old 04-28-2011, 08:22 PM   #175
oldman3
oldman3's Avatar
This was the windshield header and how the door matched to it. Once I start making the top this will all change.
