Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-04-2012, 03:24 PM   #151
LSPWRD67CHEVY
LSPWRD67CHEVY's Avatar
Re: 1967 C-10 LS POWERED Build
Got a few more things done last weekend. Got the seat brackets made and bolted in. got all shocks mounted up. got the new pinion yoke and spicer u joint installed. Got all the gauges wired up and column installed. Heres a few pics..
1967 C-10 (project)
1964 Pontiac Lemans (Treasure lol)
2009 GMC Denali Truck (DD)
LSPWRD67CHEVY is offline   Reply With Quote
Old 10-04-2012, 03:25 PM   #152
LSPWRD67CHEVY
1967 C-10 (project)
Old 10-05-2012, 12:47 PM   #153
Wasted Income
Boosted Member
Wasted Income's Avatar
Sweet project.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-06-2012, 02:42 AM   #154
BigDan3131
BigDan3131's Avatar
I would have waited on the seats until after you put the roll cage in. With the cage installed you could have made tubular mounts instead.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 10-06-2012, 08:44 AM   #155
LSPWRD67CHEVY
No cage at this time.
1967 C-10 (project)
Old 10-06-2012, 09:44 PM   #156
Street Smart
Street Smart's Avatar
GREAT LOOKIN TRUCK!!! I`m in for the ride.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 10-08-2012, 10:18 PM   #157
Street Smart
[Got the cross member plates made for the trailing arms to get the pinion angle correct]
Question here, couldn`t you have used angle shims at the U bolts to correct the pinion angle? lowering the arm mounting point will move your "Instant Center".
Old 10-08-2012, 10:57 PM   #158
LSPWRD67CHEVY
Well we went that route, not only correcting the pinion angle, but also lowering the truck. It's just the way I decided to do it.
1967 C-10 (project)
Old 09-01-2013, 11:20 PM   #159
LSPWRD67CHEVY
Been awhile since i've updated. Not much has changed up until the last few months. Finally got most of the interior put together. recovered factory door panels. Got the bed sprayed and put on. I'm going to skin the floor with aluminum and have some aluminum tubs shaped like factory just wider for tires of course. Here's some pics of progress and a mile stone might i add!
1967 C-10 (project)
Old 09-01-2013, 11:27 PM   #160
LSPWRD67CHEVY
1967 C-10 (project)
Old 09-04-2013, 06:01 PM   #161
Wasted Income
Boosted Member
Looking AWESOME dude.
Turbo diesel
Old 09-05-2013, 12:32 AM   #162
noonzor
One slick ride man, keep up the good work!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 09-05-2013, 12:08 PM   #163
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
waiting to here your times. Our motor's are the same but you've gone a bit bigger in the cam and stall departments, mine was carb'd but now efi, and I'm running a 4L80e instead of t400....and your trucks is a bit lighter I'd bet.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-06-2013, 09:36 AM   #164
LSPWRD67CHEVY
What times did you get out of your old setup?
1967 C-10 (project)
Old 09-06-2013, 01:32 PM   #165
68GMCCustom
only went one time carb'd to 1/8mi track and was only in the 8's and I forget the mph. Crappy converter and slipping trans....not now tho. Think it would do better now but starts to shake bad at 80-85...so I haven't been back. Planning to replace slip yoke, upgrade to 1350 pinion yoke, and get a aluminum shaft...then reduce angles to 1*. Then it should be smoooth.
Kurt -
Old 09-08-2013, 12:03 AM   #166
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Sweet truck..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 09-08-2013, 03:00 AM   #167
LSPWRD67CHEVY
Got the floor frame welded, bolted and painted today. Got the aluminum for the floor cut out tonight too. Some pics
1967 C-10 (project)
Old 09-08-2013, 03:02 AM   #168
LSPWRD67CHEVY
1967 C-10 (project)
Old 09-08-2013, 03:05 AM   #169
LSPWRD67CHEVY
1967 C-10 (project)
Old 09-08-2013, 12:22 PM   #170
noonzor
looks great man!
Old 09-08-2013, 12:28 PM   #171
LSPWRD67CHEVY
Originally Posted by noonzor View Post
looks great man!
Thanks guys!
1967 C-10 (project)
Old 09-08-2013, 01:28 PM   #172
68GMCCustom
That looks sweet!
Kurt -
Old 09-09-2013, 01:22 AM   #173
LSPWRD67CHEVY
Got fuel cell mounted back in truck today and line ran. Ill post up pics of tubs as soon as dad gets em formed.
1967 C-10 (project)
Old 09-11-2013, 04:16 PM   #174
mcbassin
Still Learning
mcbassin's Avatar
This is a killer project! Not far from me either. Hope to see in person some time.
mcbassin is offline   Reply With Quote
Old 09-12-2013, 06:42 AM   #175
69trk
69trk's Avatar
looks like you might get yours done before i get mine done.... I think you should put the fuel cell under the bed with a billet cap coming thru that floor unless the cell hangs to low... to bad you live in shawnee i would like to come see it....
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
