Old 02-04-2016, 02:12 PM   #151
Jferrante
Jferrante's Avatar
Re: All about heaters.
Originally Posted by red450ih View Post
I recently purchased three new reproduction cables for my 1964 with Deluxe heater but the fit and quality is very bad.
Can anyone recommend a place to get high quality reproduction cables? I would also consider good working originals. A PM might be more appropriate.
Thanks!
I am also interested in this - also is there a trick getting the cables off at the heater? Mine seems to not want to come off easily
Jferrante is offline   Reply With Quote
Old 02-08-2016, 10:35 PM   #152
red450ih
red450ih's Avatar
Has no one else had trouble installing new reproduction cables due to poor fit (quality)?
GMC
red450ih is offline   Reply With Quote
Old 02-14-2016, 11:04 PM   #153
OK you heater experts, hopefully one of you can help my poor old brain out. I have 64 with deluxe heater. Finally getting things hooked up, but what I am wondering is what does each slider do.
Is up the neutral position?
I would assume that the heat one is temperature and the down position is a hotter heat, correct?
What does the center one do beside turn the fan on. There is a cable, but for the life of me can't figure what function it is doing?
The def slider, if that to change from defrost (down) to heat (up)?
Sorry if it sounds like stupid questions, but I haven't found any explanation anywhere and use to controls with different labeling.
Oh the only clear picture I had was one before I replaced all the arms.
Thanks all
Old 02-15-2016, 01:00 AM   #154
Vernski
Palf70step all the way to the top on all three is the neutral or off position. Left side is defrost when it's all the way down it closes the baffle so all the air goes to the windshield to defrost, all the way up and the baffle lets all the air go to warm the feet. Right side adjusts the temp up and down the top is off, down is hot. The center control is the fan speed at top is off down a bit is low then medium then high all the way down. The workshop manual might have some info on the heaters I can't say for sure cause my knowledge comes from working on GM stuff for years it's been the same for a long time I believe. Hope that helps any....Vernski
Vernski is offline   Reply With Quote
Old 02-15-2016, 08:07 AM   #155
I'll take experience over books most of the time. Thanks for the input Vernski. I just got the defroster tubes on imne hooked up right, so maybe I can tell the difference when I move the controls.
Old 12-17-2017, 12:04 PM   #156
akqj9
I have a 64 C10 with the thrift heater (one knob). I'm trying to take the core out to check it and I undid 4 screws that hold it in place. Each time I hear something drop like a nut or clip to thread into. I can't get the top off since there seem to be 3 screws on the back side that I can't get to without taking the entire until out. Do I need to take the glove box out to get to the bolts that hold the unit in?
akqj9 is offline   Reply With Quote
Old 12-18-2017, 12:32 AM   #157
Captainfab
60-66 Nut
You will need to take the entire heater unit off of the firewall. There are 2 studs that have nuts on them on the inside of the firewall. Then once you have the heater unit removed, you can separate the top and bottom halves apart. Then you can access the heater core and the brackets that attach it to the top.
Old 12-18-2017, 02:42 PM   #158
akqj9
Thanks. I hope the guy who designed that is rotting in hell. It should be designed so the core can be replaced without removing the entire unit.
Old 12-18-2017, 10:12 PM   #159
rvrfoot
Thay are all a pain. I am doing a 1961 impala.
rvrfoot is offline   Reply With Quote
Old 12-20-2017, 12:06 PM   #160
argonaut
argonaut's Avatar
Trust me, taking the hater unit off a 60-66 is 10 times easier than a 67-72 where you also have to remove a hood hinge and the inner fender just to get the damn housing off the firewall.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 01-12-2018, 02:14 AM   #161
joe dirt
joe dirt's Avatar
What heater is this one in my 61 c10... is this the delux heater?..id like to remove it and put in a heater that isn't put in the engine bay
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline   Reply With Quote
Old 01-12-2018, 03:51 PM   #162
akqj9
I installed a new core but the fan still blows cold air. My engine doesn't get any hotter than 180. Is that enough to have heat?
Old 01-13-2018, 12:46 AM   #163
Captainfab
60-66 Nut
That is the '60-'63 deluxe heater with a '64-'66 heater core. It sounds like you are wanting the recirculating heater. Also known as an economy heater. Everything is inside the cab. It does not heat as well as the deluxe heater which may or may not be an issue for you. In cold climates such as here in Idaho, it is an issue. There in Portland you have mainly a lot of moisture to deal with.
Old 01-13-2018, 12:48 AM   #164
Captainfab
60-66 Nut
Yes 180* is enough for you to have heat in the cab. It sounds like you have either a flap open that shouldn't be or one closed that should be open.
Old 01-30-2018, 03:02 PM   #165
Chevystep
Thrift heater blend door
Is there any way to pull the “blend” flap on the thrift heater to maybe replace the rubber gasket around it? I can’t really tell if the rod that goes thru the flap is spot welded or just a wedge fit....not too big of a deal, but sealing it off a little better since it’s always “on” would be nice.
Chevystep is offline   Reply With Quote
Old 02-26-2018, 07:18 PM   #166
Jferrante
Jferrante's Avatar
What am I missing here? I rebuilt a thrift air heater box last year with this same heater core without issues. Now this time the heater core brackets are too big? Were there 2 size heater brackets based on heater cores? I am just going to cut these down to size to make them work if thats the case.
Old 02-26-2018, 07:40 PM   #167
rvrfoot
That looks a little thin.
Old 02-26-2018, 08:04 PM   #168
Jferrante
Jferrante's Avatar
Agreed - I am going to send it back and get the thicker core one.
Old 02-26-2018, 08:09 PM   #169
rvrfoot
Show pictures when you get the other one.
Old 02-27-2018, 12:51 AM   #170
Captainfab
60-66 Nut
It looks to me like the core may be the correct thickness but the tanks are not the correct size.
Old 03-02-2018, 03:33 PM   #171
Jferrante
Jferrante's Avatar
Here is the update from before - the new core came in today.
The thicker core fits the brackets
Old 03-02-2018, 04:03 PM   #172
botoepfer
botoepfer's Avatar
great thread I have the cheap heater in Our 63 and it appears the controls are Home made?
botoepfer is offline   Reply With Quote
Old 03-26-2018, 12:48 AM   #173
Powerlineman06
Anybody knows where to buy the control valve like the one on post #81. It is the control valve inside the blower box which is controlled by a cable on a 1960 c10 heater.
Powerlineman06 is offline   Reply With Quote
Old 03-26-2018, 03:51 PM   #174
jbgroby
jbgroby's Avatar
You can find some on ebay.
https://www.ebay.com/i/162898225384?chn=ps&dispItem=1
or this company has rebuilt units.
http://www.southeastchevyparts.com/1...ILT_p_215.html
jbgroby is offline   Reply With Quote
Old 03-13-2019, 07:32 PM   #175
SBPage1
Need some help. Took me awhile to find a thread that talked about heaters. Yes, these 60-66 heaters can be a challenge.
I have a 1961 C30 Apache Stakebed. I need to replace the Heater Blower Resistor. This truck has the recirculating heater. On this particular year, it appears that the resistor snaps into position on the backside of the heater box. Its difficult to get your hand behind the heater box to replace it.
Two questions:
1. Where can I get a resistor for this truck?
2. Any pictures for a breakdown on how to remove the heater box to replace?
I've attached a photo on how it looks. It was like this when I bought the truck. Only thing I can figure is someone took it out and couldn't get it back in.Name:  IMG_3060.jpg
SBPage1 is offline   Reply With Quote
