#151 |
Re: 66 c10 first timer build
[IMG]http:/
![]() Posted via Mobile Device |
#152 |
Alright finally figured out how to post pics from my phone. That's my 700r4 I just got. Painted it up waiting for my crossmember and pan and dipstick to install.
#153 |
Here's my rebuilt 327. I just put the pulley kit and alt on looks pretty sweet to me what y'all think?
[IMG]http:/ ![]() Posted via Mobile Device |
#154 |
Also all new posi rearend with finned aluminum cover . Running 373's any thoughts? new brake lines also[IMG]http:/
#155 |
If you would like to see how the truck will perform, send me the following info:
1. engine hp rpm and torque 2. trans ----700r4 3. rear axle ratio 3:73 4. tire diameter (ground to top of rear tire.... 5. your email address I will send you a spread sheet that shows most commom engine/trans/rear axle ratios and speeds at 1500, 2000, 3000, 400, rpm...... pm me here ![]() ![]() |
#156 |
Ok cool ill send it after work. Thanks
#157 | |
What is that (I assume is) rear bumper hanging on your wall? Man that would look cool flipped upside down and used as a grill with head lights mounted in the wells.....
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#158 |
Thanks mcmurphy. The one one the left is a 66 grill and the one on the right is a 59 grill.
#159 | |
Tire size from ground is27 3/4 Hp is375. Don't no anything else. Email is cbwilliams47@aol.com Posted via Mobile Device |
#160 |
I've been doin some brake work lately and I started to put the front lines on and they stick out from the crossmember quite a bit . It's the correct year kit from brothers I ordered with the disc kit. It just seems like I've seen a lot of people attaching the lines to the crossmember. Is mine set up wrong? Also these clips I got do I just use a.self tapping screw to connect all my lines to the frame?
[IMG]http:/ ![]() ![]() ![]() Posted via Mobile Device |
#161 |
Any pics how y'all ran talks
#162 |
Sorry auto text on phone I guess ment to so any pics on the way yall ran yalls
#163 |
Well got some goodies today!
#164 |
chevy only
![]() Join Date: Sep 2006
nice work duudes and you guys have done a ton of it!!
CHEVY ONLY... Nothin Else ! |
#165 |
#166 |
I went a head and installed rad support just to get it on there and not just sitten in a corner. Still need to paint it but it's to cool out right now
#167 |
Any pics on the brake line route yall took .
#168 |
Hey, I like your truck and have enjoyed your posts. The Gilmer belts and pulleys on the front of the engine, now that is cool. Great idea. Just a thought on that new rad support. Take some measurements and compare it to the original. I had a repo rad support from two different manufacturers, and they were both short from end to end by more than 1/4 inch. Also a lot of the holes where the square weldnuts are, aren't in the right place. I had to fix an original that had areas rusted out. The rad support is the most important piece. The inner fenders, outer fenders, and header panel all bolt to it, so it has to be right, or a ton of problems start. I hope yours is right. If I can save anyone a headache that some of these parts give, I will do it. Don't throw any of your old panels away, you can maybe patch them, or you may need them to compare the new one to.
#169 | |
#170 | |
I will be keeping that in mind as well, though I am probably going to be using my original rad support.
#171 |
Just found your build, gotta love workin outdoors, makes for interesting times.... Great job, Lovin' the motor... Keep up the great work!
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#172 | |
#173 |
This is what's taking up the other half of the garage. A 77 corvette I recently got from my mom.
#174 |
Nice Vette, my plans are to build a 2 car garage sometime this year!
#175 |
