03-04-2012, 08:51 PM | #1 |
Re: 1948 Chevy / S10
Well, today was a 10 hour day. I got a lot done. Started out fixing the drivers door. Once I shaved the drip rails off I noticed that the top of the door sat in farther than the passengers door. I noticed it on my panel truck too and I checked my 54 cab that I have and it was like that too. So I slit the back side and pulled it out where I wanted it and put a screw driver it the slit to keep it there so I could tack it. Then welded it up and now it fits right. Then I had to finish the gaps on the doors, and now they are done. Then I welded the fire wall in, I only had it tacked in before. Then finished the underside of the passenger headlight brow and they are now finished. Next was the hood. The center is all done and smoothed out and I cut out the front emblem holes and made panel for them. I drilled out the clutch head bolts under the hood to fix the corner of the hood. I figured I would never get them out. After I drilled them out I welded nuts to the underside of the panel so it bolts up like it did. I still have to fix the front edge because it is dented up. I found some filler in the hood so I will hammer and dolly it so it will not need to much. Here are some pictures.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
03-04-2012, 08:54 PM | #2 |
some more
Shannon
03-04-2012, 10:00 PM | #3 |
Looking great Shannon! What are you using to make your fillers, 18 gauge 1018 sheetmetal? Since you're planishing the hood pieces, are you MIG or TIG welding it in?
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
03-04-2012, 10:12 PM | #4 |
great job !
03-04-2012, 10:19 PM | #5 |
Shannon, excellent work as always, everything looks great.....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-05-2012, 12:01 AM | #6 |
Sweet job on the metal. That is a unigue firewall. I assume you made it yourself. You could probably market that design.
av8tr33337 AKA Bartman Email av8tr33337@yahoo.com Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
03-05-2012, 09:24 PM | #7 |
Wow, over 500 posts. I just saw that!
BlueJeep, Thank you. Yes, I am using 1018 sheet metal. I am using MIG. I have a TIG but need to get some smaller tungsten for doing sheet metal. Just have not had time to mess with the TIG on sheet metal too. I would have loved to go to one of those sheet metal workshops you went to. I love doing sheet metal. Daze57, Thank you. oldman3, Thank you. It would have been a lot easier to just fill that step in the hood! At least the filler would have not warped the hood! I got most of it out just a little work on it yet, like the front edge. av8tr33337,Thank you. I must confess it was not my idea. Ironworks and Nsane were the ones that I saw do it, I just made the one for this truck. Shannon
03-05-2012, 10:46 PM | #8 | |
Keep up the great work!
03-08-2012, 09:52 PM | #9 |
BlueJeep, I would like to try that steel but like you said it is hard to find. I would like to see the difference working it. I will have to try that tungsten. Was he using a inverter machine or a transformer machine? I was told to use a smaller tungsten like 1/16 for sheet metal. I too do not like to spend all to time when I know I can do it quick with MIG. But I know it works better than the MIG when metal working something that was TIG welded.
Shannon
03-09-2012, 04:48 PM | #10 |
He was using a water cooled transformer machine, looked to be fairly old.
I stand corrected on the difficulty in finding 1008. Just got back from the local steel warehouse and they had 1008 20ga. in stock, $26/sheet. I didn't ask if they had 19ga. (what Ron said he uses) because I mainly bought it to start playing with my bead roller. Sorry for hi-jacking your thread.
03-11-2012, 06:59 PM | #11 |
Shannon, looks great, nice job. What's his thoughts on the rest of the dash?....Jim
03-11-2012, 08:49 PM | #12 |
Jim, Thank you. I am also getting rid of the radio delete and smoothing that out. It will keep the factory glove box and speaker grill. I will be turning the ash tray into a false door for his Ipod hook up (that will be his radio). Sometime it will get a lower dash panel extension made for the heat/AC ducts.
Shannon
03-11-2012, 10:11 PM | #13 |
Looks great Shannon, as always!
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
03-14-2012, 11:14 PM | #14 | |
Shannon
Did you have a fix for strengthening the hood after it is seamed ? TKS KC Quote:
03-14-2012, 11:16 PM | #15 | |
Shannon Im back in the States & just catching up on your work...Fantastic stuff as always. I will start a thread in the 51 c4 susp & LT1 next week after I rebuild the F@#$ 9 inch in the Burb I blew up last fall..Are you going to OC in May? It would be cool to finally meet up
KC Quote:
48 GMC Burb 51 Chevy AD 3100/C 4 byShannon 74 Chevy P 10 48 Double Duty 04 SS Burb 01 Springer HD |
03-15-2012, 01:43 PM | #16 |
oldman3, Thank you. It will be different but I think it fits well.
48 GMC BURB, Thank you. I would love to come to OC but we are so busy at work and I will be trying to get everything done to get the panel at least driveable for the Nat East. The truck is leaving tonight and I will be back on the panel by the weekend. We will have to met up though. You are coming to the Nats aren't you? I can not wait to see your build. What happened to the 9 inch? I knew you blew it on the way to the Goodguys show. Shannon
03-15-2012, 08:16 PM | #17 |
Well the 48 left tonight and it went back to its home. He is building the bed and I will get it back when the bed and fenders are on. Then I will build the running boards, tranny tunnel and one of those front tilting hoods. Now back on to my panel truck.
Shannon
03-15-2012, 10:04 PM | #18 | |
Shannon
Too bad you can't make it to OC I got some good press from Classic Trucks & Hot rod hotline..Not bad for a Low buck beater ! I just made my hotel rez for Nats East. We will see you there for sure ! KC Quote:
03-11-2012, 10:24 PM | #19 |
Wow that looks great. Very unique way to blend different years into one..
I like it, I like it. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
03-12-2012, 10:22 PM | #20 |
Atommik, youngrodder, Thank you
I got it welded up tonight and only have to make 2 small filler pieces for the sides and the filler piece where the old column came through the dash. I also filled the radio holes. It is coming along really nice and is soon going home. My buddy can not wait to work on it. Shannon
03-13-2012, 09:00 AM | #21 |
That's some nice finish work. Everyone is going to notice that dash being different than stock....Jim
03-15-2012, 10:47 PM | #22 |
Shannon, truck looks good, but will be glad to see you back on the panel....Jim
03-16-2012, 09:52 PM | #23 |
48 GMC BURB, I would have loved to be going to OC. It has been over 15 years the last time I have gone to it. What hotel are you staying at for the Nats. We will have to get together when you come.
oldman3, Thank you and me too. It is in the garage now. Shannon
04-26-2012, 12:30 AM | #24 |
Hey man very nice lookin metal work you have done so far ... What are you runnin for a rear end?
Posted via Mobile Device |
04-26-2012, 06:46 AM | #25 |
FiddyRidinFowler, Thank You, It is a C4 corvette. I think it is a 1992.
Shannon
