Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-02-2012, 06:35 PM   #151
turp mcspray
turp mcspray's Avatar
Re: New life for an old 2wd, farm Blazer
More front suspension.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 06-02-2012, 07:10 PM   #152
turp mcspray
Shocks installed, more spindle and backing plates.
Turp Mcspray
Old 06-02-2012, 07:16 PM   #153
turp mcspray
Front brakes, and some tie rod stuff.
Turp Mcspray
Old 06-02-2012, 07:31 PM   #154
turp mcspray
Last batch for the day.
Turp Mcspray
Old 06-03-2012, 12:10 AM   #155
47thriftmaster
47thriftmaster's Avatar
Nice work, it's coming along great.
47thriftmaster is offline   Reply With Quote
Old 06-03-2012, 09:37 AM   #156
fxdxharley
Just a nother gear head
fxdxharley's Avatar
Great detail with all your photos. almost like a assembly manual for the rest of us. lol! great job!
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 06-16-2012, 07:03 PM   #157
turp mcspray
Time for a few more pics.
The engine was rebuilt just before the blazer came to me. I wasn't "frame off quality" in the looks department, so I cleaned it up and recolored it. The trans had also been rebuilt, so I just put in some fresh seals, and a pan gasket, and cleaned it up.
Turp Mcspray
Old 06-16-2012, 07:46 PM   #158
turp mcspray
The clean trans, and new seals. And a load of black pieces.
Turp Mcspray
Old 06-16-2012, 07:50 PM   #159
turp mcspray
Parts painted black. Installed new EEC lines, under rear of body.
Turp Mcspray
Old 06-16-2012, 07:55 PM   #160
rsavage
rsavage's Avatar
Looking great.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 06-16-2012, 07:56 PM   #161
turp mcspray
Engine and trans installed. Working on e-brake lines
Turp Mcspray
Old 06-16-2012, 08:02 PM   #162
turp mcspray
Installing misc. stuff.
Turp Mcspray
Old 06-16-2012, 08:09 PM   #163
turp mcspray
More engine stuff. Body is back on chassis.
Turp Mcspray
Old 06-16-2012, 08:16 PM   #164
turp mcspray
Just some misc. pics.
Turp Mcspray
Old 06-16-2012, 08:22 PM   #165
turp mcspray
Adding pieces to the engine.
Turp Mcspray
Old 06-16-2012, 08:28 PM   #166
turp mcspray
Adding more engine and suspension pieces. The more I looked at the tailgate, the more rust I found. Finally decided that a new one would be best. Hung new gate to check fit.
Turp Mcspray
Old 06-16-2012, 08:34 PM   #167
turp mcspray
A little welding and grinding for more precise fit. Out of the box, it is a really nice tailgate. It fit at least as good as the original,if not better!
Turp Mcspray
Old 06-16-2012, 08:42 PM   #168
turp mcspray
Fit top rail and drill holes. Drill holes and fit taillight, and upper gate trim.
Turp Mcspray
Old 06-16-2012, 08:52 PM   #169
turp mcspray
Fitting lower gate trim. I hung a woodgrain band on it, just to show Joel how good it would look! He said no, it wasn't stock. (I tried!) Finished metal work on right bedside. Mocking up lower side trim. I like to mock up any new parts, so I can drill or modify any holes before paint. It saves grief later!
Turp Mcspray
Old 06-16-2012, 11:00 PM   #170
rsavage
rsavage's Avatar
That is going to be one perfect 2wd Blazer.
1961 C1 Corvette
2021 Durango RT 5.7
Old 06-17-2012, 06:22 PM   #171
turp mcspray
I don't know about perfect. I guess it depends on who's looking at it! It WILL be a nice blazer, that I would be proud to own. Joel said once, that it will probably be the nicest blazer that I have ever done. I told him yes...with the exception of mine! Of course mine will HAVE to be just a wee bit nicer, just because it's my own! LOL!
Thanks for the compliment, and thanks for looking!
Turp Mcspray
Old 06-17-2012, 07:02 PM   #172
hgs_notes
GEARHEAD
hgs_notes's Avatar
C'mon already. Tease us with just one pic of it completed.
hgs_notes is offline   Reply With Quote
Old 06-18-2012, 01:50 PM   #173
El Campo
El Campo's Avatar
How difficult was it cutting off the outer bed skin from the new bedside? I've thought about doing that also
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 07-02-2012, 10:48 PM   #174
JJH Jimmy
JJH Jimmy's Avatar
Nice looking blazer. I am new to the to the site and am doing a frame off 72 jimmy 4x4. What product did you use on the under side of the body. I like the textured look and would like to do that with mine. Thanks.
JJH Jimmy is offline   Reply With Quote
Old 07-04-2012, 10:50 AM   #175
turp mcspray
El Campo
Separating the new bedside outer from the inner, is as simple as drilling out spotwelds, and using a cutoff wheel, around the wheel well. If you really move slow, it might take all of 30 minutes.
LLH Jimmy
I used undercoating sprayed on with an undercoating gun. I usually prefer the way it looks from a spray can, but on this blazer, I was trying for a more original (rough) look.
Turp Mcspray
