Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 10-09-2014, 03:39 PM   #151
BigDaddyV
BigDaddyV's Avatar
Re: No Limit Spy Photos
with a c-notch?
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 10-09-2014, 03:54 PM   #152
CHRIS67GMC
CHRIS67GMC's Avatar
Yes sir
CHRIS67GMC is offline   Reply With Quote
Old 10-09-2014, 03:58 PM   #153
BigDaddyV
BigDaddyV's Avatar
Very cool. Now to get some S#i1 Rolling!
Thank you sir!
Old 10-09-2014, 04:12 PM   #154
CHRIS67GMC
CHRIS67GMC's Avatar
FYI Rob is finishing his move. There new phone number is on his site or I can also order it.
Old 10-27-2014, 10:32 AM   #155
BigDaddyV
BigDaddyV's Avatar
Does anyone have a Photo of the rear rail kit w/ air bagged fat bar set up?
Old 01-16-2015, 10:58 PM   #156
Jayschevy
I would like to see this as well.
Jayschevy is offline   Reply With Quote
Old 06-22-2015, 09:24 PM   #157
duallyjams
duallyjams's Avatar
3 link update would be cool
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 06-23-2015, 10:34 AM   #158
robnolimit
robnolimit's Avatar
3-Link Update.
3-link kits are now in production and available for the following trucks.
55-59, 63-72, 73-87. They can be purchased in partial or complete kits. Complete kit pricing is the same as our FatBar 4-bar. $1150. Some measuring and drilling is required, also welding. We can also offer a Moser 9" with the mounts welded for $1245. (housing, axles, bearings, studs and brackets) If you are using a bolt in C-notch, you may need to modify (grind to fit) the upper coil-over (or bag) and panhard mount brackets.
We have been testing these on Wes Drelleshack's Apache, and on a local '78 SWB for over a year. No problems, no failures, great handling and control, smooth ride. If Wes can't hurt it, it can't be hurt.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 06-23-2015, 10:37 AM   #159
robnolimit
robnolimit's Avatar
The crossmember shown above is for 55-59's, and mild dropped 63-87. LOW 63-87 will have the drive shaft kick on the top of the crossmember, and the 3-link mounting points are raised.
Old 07-06-2015, 01:04 PM   #160
theastronaut
theastronaut's Avatar
Rob, I'm building a '66 short bed and I'm interested in a three link kit. The frame rails under the cab are 5" off the ground at ride height (truck is on air). I'm thinking that I'll need to Z the frame after the cab to raise the rear frame rails up enough so the crossmember will be high enough to get the links at the correct angle at ride height? Or will the Low version have the correct link angles with a 5" ride height without Z'ing the frame? I want to be able to tow with the truck so I want a full frame rail height, so I'm already planning to either Z the frame or do a step notch. The links look to be a good bit shorter than the original trailing arms, so I think there's room for a Z behind the cab, but before your crossmember? I'm interested in a kit either way, just wanting to make sure I order the correct version so the link angles are correct at ride height.
theastronaut is offline   Reply With Quote
Old 07-17-2015, 01:49 PM   #161
tinydb84
tinydb84's Avatar
What is the benefit to the three link over a 4 link (or wishbone style 3 link)? I read your make it handle thread (a few times) but don't remember seeing this in there.
Edit: I remember reading some of Ron Sutton's articles about positioning the upper (3rd) link on the passenger side to help counteract the torque and push the car/truck straighter. Any other benefits?
David
Instagram: myfabguy
Old 07-20-2015, 10:37 AM   #162
patrickk1
Three links have less bind than a 4 link. The one small disadvantage (not that big of a deal to me) is that you have to run a panhard bar or watts link to control lateral axle movement while the suspension is cycling. Ideally, the longer the panhard, the better. With a triangulated 4 link, a panhard or watts link is not needed as the angled links control the lateral axle movement.
- Patrick
1964 GMC pickup lwb ~ My newest build!
1937 Ford Coupe ~ Custom frame, LS1, quickchange
1950 Chevrolet 3100 ~ Bagged (Sold)
1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car)
1967 Chevelle ~ 454 Triple Black (Sold)
1964 Chevrolet Impala SS (Sold)
patrickk1 is offline   Reply With Quote
Old 09-09-2015, 11:25 PM   #163
HellaciousA
HellaciousA's Avatar
Is no limit really busy with a SEMA build? I've tried emailing twice with no reply. I don't have time during the day to call, and when I do, they are already closed. Is there a dealer for them I could work with as well?
HellaciousA is offline   Reply With Quote
Old 09-10-2015, 03:04 PM   #164
duallyjams
duallyjams's Avatar
http://www.smittyscustomauto.com/ is a dealer
James
IG duallyjams
Old 11-13-2015, 09:35 AM   #165
whitesilverado
Originally Posted by moregrip View Post
if I were starting from a clean sheet of paper and wanted to turn my 1973 longbed into a shortbed, could I use this kit? I understand it was engineered for the 67-72 frames.......but
Are the red spring mounts/ brackets still available???
whitesilverado is offline   Reply With Quote
Old 01-21-2016, 01:29 PM   #166
SierraMtns
SierraMtns's Avatar
Hey Rob,
Do you have any pictures of the LOW 63-87 3-link kit mounted in a 67-72? Where dose the 3rd link connect to a stock GM 12 bolt?
SierraMtns is offline   Reply With Quote
Old 01-28-2016, 11:11 AM   #167
robnolimit
robnolimit's Avatar
No Limit 3-links must have the upper mount welded to the housing. - So, 12 bolts are a no go.
Yes, I have seen the kits with plates bolted through the rear cover with longer bolts and two gaskets. I have also seen cracked housings, broken bolts and destroyed gear sets. Remember that ALL of the 'pull' load from a launch, and ALL of the 'push' load from a hard brake (sometimes more violent than the launch) go through the top bar. We expect that No Limit customers will drive their trucks out to the edge more than once, and we want them to survive the test.
