Old 09-29-2014, 07:46 PM   #151
vannatta20
vannatta20's Avatar
Re: 1968 C10 5.3 swap, the easy way.
I used a explorer rear but its too narrow. It will require deep dish wheels or 2 inch spacers on each end. I used 2 inch spacers that convert the bolt pattern back to 5x5.
vannatta20 is offline   Reply With Quote
Old 09-29-2014, 08:24 PM   #152
mooseknuckles
mooseknuckles's Avatar
no such thing as too narrow...
mooseknuckles is offline   Reply With Quote
Old 09-29-2014, 08:49 PM   #153
w00dst0ck
w00dst0ck's Avatar
Yeah it's 2 inches narrower, but it's an off center pumpkin so you would have had to take 2 15/16 off the long end to center it up.
That's what I do to fit them in car swaps. Other option would be drilling the plug on the short side, and putting 2 long tubes and it would be 2" longer than the 12 bolt
w00dst0ck is offline   Reply With Quote
Old 09-30-2014, 12:27 AM   #154
vannatta20
vannatta20's Avatar
Old 09-30-2014, 12:29 AM   #155
vannatta20
vannatta20's Avatar
Pic above is the 8.8 versus 12 bolt length. Its almost 4 inches less in width.
Old 09-30-2014, 08:11 AM   #156
w00dst0ck
w00dst0ck's Avatar
Did you center the pumpkin or is the 12 bolt not a centered pumpkin either? Hard to tell in pics.
Old 09-30-2014, 10:21 AM   #157
vannatta20
vannatta20's Avatar
Its offset 2 1/4 inches i believe. I had to cut open the rear crossmember a bit since the driveshaft would hit it with the offset pumpkin
Old 09-30-2014, 10:53 AM   #158
w00dst0ck
w00dst0ck's Avatar
Thanks I have yet to measure my 12 bolt, but the factory 96-00 explorer rear ends are offset 2 15/16 to the passenger side. I was just curious if the 12 bolt it similarly offset from the factory. Otherwise the long tube on the 8.8 needs to be cut down 2 15/16 and use the short axle shaft on both sides. Or vice versa if you want it to be longer. -only required if you need to center the pumpkin depending on the vehicle it's going into.
Did you weld on new u bolt perches to it?
Old 10-01-2014, 12:11 AM   #159
vannatta20
vannatta20's Avatar
Yep I welded new perches on. It would be best to put long axles on best sides.
Ol blue was cast in a college film. Its in the first minute of the vid.
https://www.youtube.com/watch?v=w18xDj9ACU4
Its all in fun so pls know all actors are volunteers.
Old 10-15-2014, 02:03 PM   #160
lowlyfec10
finally getting started on my lq4 swap....got DD mounts otw....did you have any issues with cab clearances? now im being told to not go the DD 73+ mount way lol
lowlyfec10 is offline   Reply With Quote
Old 10-15-2014, 02:13 PM   #161
w00dst0ck
w00dst0ck's Avatar
I ended up buying !@# mounts.
I couldn't imagine spending $240 on motor mounts as I usually make my own, but these are beautiful, and heavy duty!!!
Old 10-15-2014, 03:51 PM   #162
solidaxel
solidaxel's Avatar
With DD M mounts everything fit in my 78 including the driveshaft, just had to move the rear X member
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-15-2014, 03:53 PM   #163
lowlyfec10
forgot to mention i have a 69. with the added extra inch from using the 73+ stuff and a 4l80 trans i was told id have cab issues.....
Old 11-24-2014, 03:05 PM   #164
Cuate
I installed dirty dingo adjustable plates on 2001 5.3 motor .I had to remove the AC compressor to be able to bolt plate up to the motor. Is there something I can do do be able to bolt AC bracket and compressor back on same location and keep the adjustable motor mount plates? I'm getting ready to install on 1968 chevy truck and I really want to keep the 5.3 original AC compressor. Any help will be appreciated.
Cuate is offline   Reply With Quote
Old 11-30-2014, 09:02 AM   #165
zteca
Junior Member
I am actually having problems with DD mounts, I measured the engine angle to be 7 degrees pointing downward.if I lift the transmission to get 3 degrees, pointing downward, it will hit the cab. By the way I am using the same clamshell rubber mounts vannatta but using a 1980 front crossmember, could that be why and is 7 degrees too much?
zteca is offline   Reply With Quote
Old 11-30-2014, 10:21 AM   #166
lolife99
67-72 parts collector,…
lolife99's Avatar
Are you using the factory high hump trans cover?
Keith
Convert to disc brakes.
Old 11-30-2014, 11:20 AM   #167
zteca
Junior Member
It's the low hump but I will also need a new rear cross member. When I lift the transmission to the -3 degrees the drive shaft will hit the rear cross memeber. Is there away to lower the engine instead? Thanks
Old 12-13-2014, 12:55 AM   #168
cagodinez
cagodinez's Avatar
Did u have to notch the frame to run the AC lines?
cagodinez is offline   Reply With Quote
Old 12-24-2014, 10:53 AM   #169
vannatta20
vannatta20's Avatar
I did not need to notch the frame for the ac line . I used factory 5.3 ac lines. I had one line cut and welded to get a better angle.
Old 01-01-2015, 05:19 PM   #170
ls1nova71
ls1nova71's Avatar
Ok, tell me I'm not losing my mind, your sig says you live in Vegas, but I would swear I just saw this truck northbound on 291 in Independence about a half hour ago? I was going the other way and the nearest place to turn around was 1/4 mile away, so I couldn't just turn around....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-02-2015, 02:00 PM   #171
vannatta20
vannatta20's Avatar
It's in vegas still. I'm actually in your area by sedalia but I left my truck back home.
Old 01-20-2015, 10:03 AM   #172
tinsoldier
tinsoldier's Avatar
Sorry but what and where did you get your billet insert for the guages? You posted saying they sent you the wrong one.
tinsoldier is offline   Reply With Quote
Old 01-25-2015, 05:29 PM   #173
vannatta20
vannatta20's Avatar
http://www.classicparts.com/1969-72-...tinfo/24-194B/
Its actually a overlay. I thought is was the entire panel. Still worked.
Old 04-05-2015, 11:28 AM   #174
the1snyder
did you guys use stock ls oil pan
the1snyder is offline   Reply With Quote
Old 04-05-2015, 03:32 PM   #175
vannatta20
vannatta20's Avatar
Yes I used a stock truck oil pan with all truck accessory's. It will hang down below the crossmember about an 1-2 inches. No issues since my truck only has been lowered 3 inches.
I did a bunch of changes of this last month. Sold the 6.0 and got a L33 5.3 engine for cheap (all aluminum block).. Had the heads milled .036 for high 10's compression. Installed a free lq9 cam. My 4l60e went bad and had that rebuilt. I also custom made a complete engine harness from scratch since I now build and sell them. I kept the DBW setup but re wired it to work with a 90mm LS2 throttle body. Im hoping to get decent economy out of this setup. Hoping for high teens in the gas mileage with 300hp to the wheels. I also installed headers finally.
