Old 03-03-2013, 10:26 PM   #151
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 1963 C-10 in NC
Outstanding! Those are going to be very nice additions.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-04-2013, 08:52 AM   #152
clemdaddy
clemdaddy's Avatar
Re: 1963 C-10 in NC
those trim pieces look great. any time i'm out salvaging i always keep an eye out for that cab trim... very scarce. nice work on the sails too.
clemdaddy is offline   Reply With Quote
Old 03-04-2013, 10:00 AM   #153
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thank you all for the comments. Took me around 2 years to piece the set together. But its worth it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-06-2013, 07:49 PM   #154
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Heres the mock up of my door trim. Will be using it w/the sail panels and back trim i did above instead of the typical GMC trim. Kinda a marriage of both trim packages. The orange door is my pass donar. Will need some work on the bottom corner and it'll be solid. My original door would require bottom and reskinned, so it'll be easier. The blue door is my driver side donar and its a rust free door off the 61 mike & I bought for parts. Came off a 21,000 mile truck that got t-boned pretty fierce. It'll also convert me to the framed glass (which i plan to chrome). Ive always thought the chrome metal lined windows looked sharp. If anybody needs the trim mounting locations on the orange door or better pics of the part thats painted for the trim for reference, just let me know. Near as I can tell, neither door has ever been repainted. Ive posted on the general forum for the proper mounting locations for the window trim if anybody happens to know, please let me know. I just want to mount it properly.
Old 03-07-2013, 11:18 AM   #155
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Here is the look im after, but I will use the 60 wide windshield trim and back of cab trim too.
Old 03-08-2013, 10:48 AM   #156
flips72
flips72's Avatar
Re: 1963 C-10 in NC
nice, i have always liked the gmc trim, and would love to have the trim and sail panels for the rear of the cab.
flips72 is offline   Reply With Quote
Old 03-08-2013, 04:39 PM   #157
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
I might have a line on another set of GMC window trim. I can pm you the contact #.
Old 03-25-2013, 01:29 PM   #158
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Rainy day here yesterday, so was a good day to tear down the donar wiper motor & washer pump assembly. Got the wiper motor and washer cleaned up and ready to do the conversion. Switch, bottle and bracket installed. Just have to swap the motor/pump out and run the tubing from the pump to the bottle and nozzles. I have a single speed from the factory and am converting to a two speed w/washer option. Put a thread up to get some help on the wiring. Motor shows part # 5045342 Type E 12V Delco Appliances dated Jan 63
Old 03-25-2013, 06:45 PM   #159
flips72
flips72's Avatar
Re: 1963 C-10 in NC
looking good.
Old 03-26-2013, 06:07 AM   #160
Jmorales3181
Jmorales3181's Avatar
Re: 1963 C-10 in NC
I like that trim idea looks really clean!
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 03-26-2013, 08:08 AM   #161
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thank you. Thats what Im going for. I have to pick and choose my projects until I get the barn up and some warmer weather, so im doing alot of the trim prep and restoration on the parts Im converting, but at least its getting work done.
Old 03-29-2013, 11:00 AM   #162
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Heading off to pick up the new donar hood and passenger side inner fender.
Old 04-01-2013, 09:45 AM   #163
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
OK, got the hood picked up from Sharps, great looking hood and probably 20 hours less work involved than what I had in my original hood. Have two small areas to work on. Front driver side has a small dent/bondo (about 2"), and the front pass side has a little cancer (around 1.5" long). Rest of the hood is rust free. My current hood has issues along the entire front lip and needs work down both left & right sides/corners. Inner fender has one small area to reapir (around an 1" long), but thats ok, I have a rust free patch I pulled off another inner I had which will take most of the work out of the inner fender panel. He also gave me a tow bar, which needs a little work. I have some 1/4" steel plate that I need to work 2 - 2"x8" areas onto. No biggie. Also...will be going back this weekend for the rear half of the truck. Looks like I finally get to make my matching stepside trailor to pull behind the 63!!!
Old 04-01-2013, 10:29 AM   #164
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Last pic of hood repair that needs done and the tow bar that needs new metal.
Old 04-03-2013, 05:49 PM   #165
flips72
flips72's Avatar
Re: 1963 C-10 in NC
hoods not bad at all, great score
Old 04-03-2013, 08:30 PM   #166
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Great for our neck of the woods. My OEM hood is great for a work truck or always an upgrade for someone with more bodywork or rust in theirs, but I try and go as solid as possible on the sheetmetal with as little bodywork as I have to do.
I did also get my Opti-Kleen bottle done and installed. The decal was simple and straight forward. Did the best I could to polish the glass. Its dated 1961, so it has a little wear, but not much. It never had a decal when I got it, and there are several different ones out there...I guess there were some changes in different applications (cars vs trucks and different years). But I went with the one that closest matches the other GM Accessories tins, bottles and boxes. Either way, came out good, is installed and put up some pics to show it off. I dont know exactly where the dealers installed them, but it does show as an accessory in the book. If anybody knows, Id like to mount it in the proper spot. It will just hold extra windshield washer fluid for the system.
Old 04-04-2013, 06:01 PM   #167
CRGRS 66
CRGRS 66's Avatar
Re: 1963 C-10 in NC
Hey! Wonder if I could ask for a favor? I am working on getting a custom glove box emblem laser cut for Zane's Ride. Any chance you could send me some measurements of your Chevrolet Script glove box emblem, upper and lower case letter height overall length of script etc.? Posting the picture from page one of your thread.
Cool washer bottle BTW!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 04-04-2013, 06:31 PM   #168
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Would it help if I sent one to you and then you mailed it back? Could be scanned if they have the right software. Or I can try my copy machine at work tomorrow. The base dimensions I put on a thread here awhile back...glovebox scripts I think.
Old 04-04-2013, 06:32 PM   #169
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
And thanks on the washer bottle. I know its such a small thing, but just one of those neat old things that you don't see anyone or very often. I like alot of the smaller touches.
Old 04-04-2013, 07:35 PM   #170
CRGRS 66
CRGRS 66's Avatar
Re: 1963 C-10 in NC
I think just some rough dimensions would do the trick, my guy can do the artwork.
Craigerrr
Old 04-04-2013, 07:56 PM   #171
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 1963 C-10 in NC
Another option would be to do a rubbing with a crayon or soft pencil. Just put a piece of paper over the emblem and wipe a crayon flat against the emblem surface. It will produce an exact size pattern you can take measurements from, and eliminates the risk of breakage in shipping.
Old 04-04-2013, 08:41 PM   #172
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
good idea. get me an address and i will get it for you.
Old 04-04-2013, 08:52 PM   #173
Rich 5150 69
Rich 5150 69's Avatar
Re: 1963 C-10 in NC
Great score Jon....its amazing the stuff you been finding lately, Calif too picked over by the swap meeters, you can`t find much anymore...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-05-2013, 08:31 AM   #174
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Well, let me know what your looking for and I'll keep my eyes open. Might be able to help find some stuff here on the east coast.
Old 04-05-2013, 11:19 AM   #175
CRGRS 66
CRGRS 66's Avatar
Re: 1963 C-10 in NC
Great idea Mark! I will send a PM with my address.
Craigerrr
