Old 11-10-2012, 11:51 PM   #151
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Project Roxy
Nice work on the tank mount.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-11-2012, 12:10 AM   #152
Rochlow
Re: Project Roxy
Thanks guys..
Rochlow is offline   Reply With Quote
Old 11-11-2012, 01:28 AM   #153
67c10rustbuket
67c10rustbuket's Avatar
Re: Project Roxy
Very nice progress!
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 11-15-2012, 11:15 PM   #154
Rochlow
Re: Project Roxy
Not sure if I'm doing this right, but I'm not building the truck to win trophies, just to go to a few shows
Old 11-16-2012, 12:01 AM   #155
sduckworth13
sduckworth13's Avatar
Re: Project Roxy
Looks pretty solid from here, nice work
Scott
sduckworth13 is offline   Reply With Quote
Old 11-16-2012, 10:17 AM   #156
Rochlow
Re: Project Roxy
It was pretty hard to get that panel to sit right. And still it's all wavy by the toe board. I guess I will put some seam sealer on top and bottom and see how that goes.
Old 11-16-2012, 11:31 AM   #157
DeaconT
DeaconT's Avatar
Re: Project Roxy
You may want to put the door on before you weld the rocker on. This will help with the door reveal. Nice work on the frame. Are you going to shave the any of the cab or are you going for a stock look? I'm working on my 72 and will keep most of the stock look. I will weld up the seams that are seen but kinda like the drip rail but don't like the leaks from the caulk.
DeaconT is offline   Reply With Quote
Old 11-16-2012, 11:44 AM   #158
Rochlow
Re: Project Roxy
Yea the outer rockers were the last thing I was going to put on and want to use the door as a reference.
I am going for a stock appearance. However, I did see a mod to the drip rail that I like alot. It's filling the seam just above the windshield. I will probably pass on doing it, but I liked it alot.
Old 11-24-2012, 08:56 PM   #159
Rochlow
Re: Project Roxy
Holy crap!! Thought I'd never see this!! First test fit of the outer rocker.
Old 11-24-2012, 11:50 PM   #160
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Project Roxy
Good progress. Will be worth it to know its all rust free
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-25-2012, 12:08 AM   #161
Rochlow
Re: Project Roxy
Lol.. I don't about rust free, but less rusty.. It's been a lot of work and I've been doing everything myself. At least I will have a sense of accomplishment when it's done.
Old 11-25-2012, 02:25 PM   #162
DeaconT
DeaconT's Avatar
Re: Project Roxy
Test fit looks good. I am working on the doors on my project and noticed the bottom curved in on one corner. It has no damage but it doesn't look like it belongs there. I haven't put the rockers on yet because I want to make sure they will match up to the doors.
I have sandblasted the bottom of the inside of the doors to eliminate the rust spots and have been looking a good way to fill in the pocmarks left from the rust. It's not bad enough to replace but a couple go all the way through the inner skin. Any suggestions?
Old 11-25-2012, 04:11 PM   #163
Rochlow
Re: Project Roxy
Places that go all the way through I might just make a patch. Places that had pockmarks or imperfections left from rust I might use spot filler putty to see if that would work.
Old 11-27-2012, 10:26 PM   #164
Rochlow
Re: Project Roxy
I put these up for sale, but after putting the trim rings and caps on, I really like them.
Old 12-24-2012, 09:30 PM   #165
Rochlow
Re: Project Roxy
Merry Christmas, Roxy!
Old 12-25-2012, 01:41 PM   #166
Last_Paladin
Re: Project Roxy
Run 'em.
Last_Paladin is offline   Reply With Quote
Old 12-25-2012, 02:33 PM   #167
Stefan.
Stefan.'s Avatar
Re: Project Roxy
Nice wheels
Stefan. is offline   Reply With Quote
Old 12-25-2012, 03:20 PM   #168
mooseknuckles
mooseknuckles's Avatar
Re: Project Roxy
sweet build!
mooseknuckles is offline   Reply With Quote
Old 12-29-2012, 04:24 PM   #169
Rochlow
Re: Project Roxy
Driver's side test fit.
Old 12-29-2012, 05:20 PM   #170
sduckworth13
Re: Project Roxy
Looking good, you've been busy. I like that you took a real nice truck to start with and are making it better than it was. I've never rode in a porterbuilt dropped C10, but I had 1967 gmc longbed with a 4 1/2 front drop and 6 in the back and it steered like a truck on rails. I can only imaging how your truck is going to handle. Nice work.
Scott
Old 12-29-2012, 05:29 PM   #171
Rochlow
Re: Project Roxy
Thank you sir! Been referring to you build for the sheetmetal repair.
Old 12-29-2012, 05:42 PM   #172
sduckworth13
Re: Project Roxy
Cool, glad it's helping you. I actually used a level to line my rocker and door up. First on my cab ( the flat front part the seats sit on), then my rocker and then after I got the door on where I thought it fit right, I then put a level on it and it was by luck exactly 0 degrees level. Most people just eyeball it but since I had never done any panel replacement, I needed the assistance.
Scott
Old 01-03-2013, 03:04 PM   #173
Rochlow
Re: Project Roxy
I've been eyeballing most of the stuff. I'm stuck on the replacing the drivers side floor panel now. Not sure how to approach the toeboard/floor board seam. I have an idea how to do it, just have to cut a patch out of my other cab.
Old 01-03-2013, 03:44 PM   #174
sduckworth13
Re: Project Roxy
On the toeboard seam floor, I wouldn't worry to much about folding a piece of metal to match the seam. Get your flat floor panel in first and then if you want to fancy cut a gap where the seams meet and put a strip of metal in and weld it up for your edge. If that make sense.
Scott
Old 01-03-2013, 03:54 PM   #175
Rochlow
Re: Project Roxy
That's one of the approaches I was looking at. The other is cut the seam out of other cab on each side and weld it place. Then, butt the floor pan against the hangover on the lower portion of the seam.
