Old 02-21-2013, 03:49 AM   #151
Desperado454
Desperado454's Avatar
Re: Parked Indefinite
Originally Posted by Dieselwrencher View Post
That is so freaking awesome on that dresser! I loved that man!
Nice! Glad to know I'm not the only one who enjoyed that...and it's pretty clear 354's are nearly as plentiful nor cheap as smogger 350's, so I can understand the hesitance about putting the screws to it. Wouldn't mind seeing some pics of the car and engine though!
Twin Turbo '76 C10 Build
'28 Model A Build
-Brooks
Desperado454 is offline   Reply With Quote
Old 02-21-2013, 04:21 AM   #152
Desperado454
With the doors aligned to standard that these trucks provide, which is what it is, it was time to fit the fenders and finish the inner fender raising job on the driver side. I was dreading this since the passenger side seemed like a never ending cycle of cut, weld, grind, repeat. I was also was holding off because the fender was rotten in some ugly places, but the search to find another was plagued by no one on craigslist returning my calls or messages. I ended up deciding to just fix the fender I had which turned out okay I guess. Used another fender that I had around back to fix the bottom and made a sheet metal patch to repair the wheel opening area. Also got a start on raising the inner fender flange...here's some pics of where I'm at:
Aligned somewhat:
Not fun:
Fender bottom...you know you're grasping at straws when you have to patch the patch!
Old:
New:
Inner fender raising...drivers side:
Last pic:
'28 Model A Build
-Brooks
Old 02-21-2013, 12:14 PM   #153
canadian trucker
A day should have 30 hours.
Looks great
Want to do the body work on my truck when you are done?
Keep it up
canadian trucker is offline   Reply With Quote
Old 02-28-2013, 12:00 AM   #154
Desperado454
Just about finished with the inner fenders and aligning the fenders themselves...just a few more welds, a little more grinding, then some sanding and painting. Will be glad to have it done.
'28 Model A Build
-Brooks
Old 03-06-2013, 11:31 AM   #155
canadian trucker
any updates?
Old 03-07-2013, 03:05 AM   #156
Desperado454
Originally Posted by canadian trucker View Post
any updates?
I haven't made much progress but I can give you an update of where I'm at: Both fenders are now smoothed and basically ready for an epoxy/clear coat, and the inners have been massaged and beaten to the point where they are just about ready for the same finish. Some pics I took:
Fender bottom welded up:
Each side sans well:
Aerial mock up:
Hope to have this painted soon...next thing to tackle will be the fuel system
'28 Model A Build
-Brooks
Old 03-07-2013, 03:38 AM   #157
355bullet
355bullet's Avatar
awesome build!
355bullet is offline   Reply With Quote
Old 03-07-2013, 01:31 PM   #158
canadian trucker
That look so cool with the shaved firewall, smothed fenders and TWINS under the hood.
Old 03-10-2013, 02:15 AM   #159
Desperado454
Originally Posted by 355bullet View Post
awesome build!
Thanks!
Thanks man!
Finally painted...here's some pics of how it turned out:
While that stuff dried I picked away at a few things:
I'll try to get some pics of everything back together up soon.
'28 Model A Build
-Brooks
Old 03-10-2013, 06:57 PM   #160
Desperado454
And it's all back together. Glad this part is over with
'28 Model A Build
-Brooks
Old 03-11-2013, 12:24 AM   #161
Desperado454
'28 Model A Build
-Brooks
Old 03-11-2013, 07:27 AM   #162
68Timber
I know the pieces fit
68Timber's Avatar
Looks great!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-13-2013, 10:10 AM   #163
canadian trucker
So clean.
Old 03-17-2013, 03:41 PM   #164
canadian 4x4
canadian 4x4's Avatar
looks wicked dude!
85 swb c10 6/6 drop
83 c10 bagged and sfbd project
canadian 4x4 is offline   Reply With Quote
Old 03-18-2013, 01:23 AM   #165
Desperado454
Originally Posted by BRUISER View Post
Looks great!
So clean.
Originally Posted by canadian 4x4 View Post
looks wicked dude!
Thanks guys!
So after doing some reading on the turbo forums, I think I pretty much figured out what I need for a fuel system. Going to go with a single walbro 255 pump, mallory 4309 regulator, and -8 for the feed and return. Should be enough I think...
Anyways, in the meantime I managed to get the battery mounted:
Put the rear window back in and started to put the dash back together:
Been putting off the swaybar for a while, so I finally got that reattached and took a few dark pictures:
While on my back under the dash, I thought I saw a photo opportunity, maybe not:
'28 Model A Build
-Brooks
Old 03-23-2013, 07:39 PM   #166
Desperado454
Picked up my fuel system stuff today. Tried my hand at putting a fitting on the hose and it went smooth. More to come...
'28 Model A Build
-Brooks
Old 03-25-2013, 01:14 AM   #167
Desperado454
I decided to clean up the the tank a little bit before I did the final install, came out decent enough, especially for something that wont be seen. While I was on a roll I put a sending unit in for the fuel gauge. Next up will be mounting the pump and running some lines.
'28 Model A Build
-Brooks
Old 03-25-2013, 11:42 PM   #168
Desperado454
Pretty much figured out where the pump and regulator are going to mount, and also got an idea of where I'll run the hose:
Some new hardware under the hood:
Roughed out a piece of aluminum to mount the pump and filter onto which will bolt to the bottom of the frame:
'28 Model A Build
-Brooks
Old 03-27-2013, 12:09 AM   #169
Desperado454
Didn't get much time to pick away at it today but managed to run a couple lines.
To the regulator:
And just in front of the spring hanger where they come through the frame:
'28 Model A Build
-Brooks
Old 03-28-2013, 07:24 PM   #170
pwradder
pwradder's Avatar
coming along nicely! looks like it wont be long now
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 03-28-2013, 09:59 PM   #171
stepside-mitch
stepside-mitch's Avatar
Man your truck is sweet! What's that steering wheel out of? How did you make it fit?
stepside-mitch is offline   Reply With Quote
Old 03-29-2013, 10:48 PM   #172
canadian trucker
Drivable yet?
Old 04-01-2013, 12:09 AM   #173
Desperado454
Thanks man, looking forward to driving this thing again
I think it's out of a 66 or 67 chevelle, and it was a bolt on after I clearance the back of the wheel a bit
Drivable yet?
Yep!
Walk around:
Revved it up a bit:
'28 Model A Build
-Brooks
Old 04-01-2013, 09:17 AM   #174
6772owner
Gearhead
6772owner's Avatar
Man that truck is awesome, great work!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 04-01-2013, 11:45 AM   #175
KevinD85
KevinD85's Avatar
love the truck.
would love to do that one day
1986 chevy k10 silverado rust free from oregon 350 crate big cam,headers and 2.5" duals with an x pipe.
2001 subaru 2.5 rs with a full wrx sti swap track car project
1991 Lexus Ls400 rwd drift toy
2012 lexus is350 awd daily driver
KevinD85 is offline   Reply With Quote
