05-06-2014, 12:24 PM | #151 |
Re: 56 made2drag
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
05-06-2014, 12:25 PM | #152 |
Re: 56 made2drag
05-06-2014, 12:32 PM | #153 |
Re: 56 made2drag
i cut 14.5 inches out of the long wheel base frame to make it the same as a swb 76 c10.
keeping it the stock specs as a swb c10 lets me keep a stock swb driveshaft in it (when i get a c10 rearend), but from what i have read there will be a 3 inch gap between the bed and cab because a stock swb 76 wheelbase is 3 inches longer than a swb 56. i think since i flipped the axle on top of the leaf spings and DIDNT drill a hole in the axle pad to move the rearend back 1 inch....i may have a 2 inch gap now between the bed and cab. i plan on moving the cab and fenders back 1 inch and the bed forward 1 inch to give me the right gap. or leave the cab and move the bed forward and have a 1 inch gap
05-06-2014, 12:34 PM | #154 |
Re: 56 made2drag
if anyone has any other ideas, feel free to express them...but mods must be free or dirt cheap. LOL
05-06-2014, 12:37 PM | #155 |
Re: 56 made2drag
once i know everything will work. i will weld diamond shape fishplates to the inside and outside of frame where welded and also box the inside to strenghten as much as possible.
05-06-2014, 02:13 PM | #156 |
Re: 56 made2drag
Nice work on shortening the frame.
IMHO you're going to have to make sure your rear tires are centered properly in the rear fenders for your bed placement and then adjust from there. Kim |
05-06-2014, 04:10 PM | #157 | |
Re: 56 made2drag
Yes, i think you are right. May just adj everything loose until its close enough then mount things up.
05-06-2014, 04:14 PM | #158 |
Re: 56 made2drag
anyone know if a 73-87 swb c10 driveshaft will work with my 89 camaro rearend?
(250 straight 6 with a turbo 350 with short tailshaft)
05-06-2014, 04:27 PM | #159 |
Re: 56 made2drag
the 76 c10 donor didnt have a driveshaft or c10 rear end so i dont know.
i could measure my 86 c10's but it has a 700r4 when i searched the forum i found that someone says the drive shaft is 59.5 in from center u-joint to center u-joint using a short tail and a c10 rear end. any other help would be appreciated
05-08-2014, 11:18 AM | #160 |
Re: 56 made2drag
anyone know if a 89 camaro will accept a c10 driveshaft?
05-20-2014, 10:45 AM | #161 |
Re: 56 made2drag
05-20-2014, 10:47 AM | #162 |
Re: 56 made2drag
05-20-2014, 10:48 AM | #163 |
Re: 56 made2drag
05-20-2014, 10:48 AM | #164 |
Re: 56 made2drag
05-20-2014, 10:53 AM | #165 |
Re: 56 made2drag
ran out of welding wire. plans are to fishplate the insides then box the frame in that area.
05-20-2014, 05:38 PM | #166 |
Re: 56 made2drag
Nice work.
Kim |
05-21-2014, 09:05 AM | #167 |
Re: 56 made2drag
06-29-2014, 11:03 AM | #168 |
Re: 56 made2drag
06-29-2014, 11:09 AM | #169 |
Re: 56 made2drag
06-29-2014, 11:30 AM | #170 |
Re: 56 made2drag
You have more patience than I do.
I would be looking for replacement pieces if mine had that much rust and damage. Lets me know how fortunate I am with what I started with. You've got a real good start on it. Kim |
06-29-2014, 11:45 AM | #171 | |
Re: 56 made2drag
i think i'll have to buy the doors though (500 each). Mine would require too much work and i would end up not being happy unless they were new.
06-29-2014, 11:52 AM | #172 |
Re: 56 made2drag
Im hoping the I can buy the "front face" fender patches and make them work....at 72 bucks each, i'll hopefully get everything looking good up front. Still have alot to do in the fall...i want to do the step notch in the rear and then put the bed on to work on the cab placement then do brakes and steering and transmission....once i'm able to drive it then slam it...then do more body work...most people would do the bodywork first but if its driveable i feel i'll be more likely to work on it more often. once every couple months right now...
06-29-2014, 04:27 PM | #173 |
Re: 56 made2drag
You might talk to this guy and find some parts you need. From the Atlanta CL:
http://atlanta.craigslist.org/nat/pts/4520184163.html |
06-30-2014, 05:03 PM | #174 | |
Re: 56 made2drag
07-21-2014, 07:36 PM | #175 |
Re: 56 made2drag
