#151 |
Re: Lattimer's 1970 C-10 build
Valves seemed to have some issues going on. It had been smoking now and then, and always had a little bit of a pop out of both exhausts at idle.
![]() Engine is kind of a greasy mess. ![]() Both engines sitting in the garage. I have to swap the intake and the P/S pump over to the new one before installing. ![]()
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#152 |
#153 |
That's a beauty, man
Posted via Mobile Device |
#154 |
Thanks. Once I get everything back in with the new shiny headers it should look even better.
#155 |
Still Learning
Awesome looking new engine!
#156 |
#157 |
Got the headers in between last night and tonight. Amazingly, they fit perfect with no issues, cleared the motor mounts and the crossmember. Couldn't believe it.
These are supposed to be the same as the ones I took out, and they look identical, but the old ones hit the passenger side motor mount and the PO had dented the header for clearance. On the flip side-----these did not clear the z-bar the same as the old ones. So I'm in progress of re-designing the z-bar to fit better. As long as I can weld it, I can't be stopped!!!!! LOL
#158 |
Z bar fits and works now. Got the alternator and Ac compressor mounted, carb i son, radiator in.
Made 3 trips to Auto Zone before I got a set of belts that actually fit. New pulleys caused me to have to get slightly shorter belts, and I guessed wrong twice. Spent a bunch of time fixing and cleaning up wiring. Put a lot of the wiring into black wire loom and routed and taped it. Looks a lot better and hides the rainbow of wire going everywhere. I have too much extra electrical stuff to hide it all. Also found my newest fuse holders for the electric fans melted just like the last ones. Fuses weren't blown, but the holders looked like they had been torched. Rewired that and installed a car audio style fuse block with the big glass fuses. If this melts I give up. ![]() I still have to get clamps for the lower radiator hose (forgot them all 3 trips today), fill with coolant, install trans and driveshaft, and wire the starter.
#159 |
#160 |
![]() Join Date: Dec 2006
Nice job on the engine swap, your right the orange looks much better
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#161 | |
I have to see if I can clean the hinges up enough to paint them. They probably need to be blasted. The booster I already painted with Eastwood Brake Parts paint, its supposed to be resistant to brake fluid. I have a new master going in soon when I do the rear brakes, and I already painted that as well.
#162 | |
#163 |
New engine is alive! Got it fired up today. Broke the cam in, got most of the tuning set up. Few minor issues to address still, but so far I did it right.
crappy video's are here: http://67-72chevytrucks.com/vboard/s...d.php?t=596848
#164 | |
I tied to view the videos, but yeah- the screen grab is poor quality, and I can't get them to play. Brother, you need to quit spending money on that truck, and get yourself a good phone lol Posted via Mobile Device |
#165 | |
#166 | |
The screen is large enough that you can look at service manuals, part schematics, etc. while you're under your truck too Posted via Mobile Device |
#167 |
I have a company supplied iPhone that I don't have to pay for, so I'm good to go. I also have a tablet I use in the garage for searching out info.
#168 |
#169 |
Got the valve cover oil leak fixed last night, and got my temp gauge working tonight. Still waiting for a replacement high torque starter so i can actually crank this thing over reliably. Regular old rebuild Gm starter just can't quite do the job.
Also added some bling under the hood. ![]() ![]()
#170 | |
That top cover above the grille support looks good Posted via Mobile Device |
#171 | |
#172 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
That engine turned out great! Looks good in there.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#173 |
Thanks!
I still have more wiring clean up to do in the engine bay to get it as clean looking as I can. The additional of the AC and electric fans added a whole lot of extra wire ![]()
#174 |
Got the high torque mini starter in tonight. Wow is that different. I took a quick video of it on a dead cold start. 2 pumps of the gas and then I cranked it with my remote trigger.
http://youtu.be/6obJRtfbF-4
#175 |
Also added a 10 ohm resistor to the wire to the coolant sensor, now normal operating temp has the gauge reading in the middle of its range. Before it read hot when the engine was at 190.
Tomorrow I have to re-do a header gasket. Can't get the leak on #3 to stop.
