Old 05-03-2014, 02:38 PM   #151
jcramsey
jcramsey's Avatar
Re: The Egg Hauler.... not much of a build
Found the right fiber gasket material at the True Value hardware store beside my house. The napa it shares a building with didn't have anything in stock so I figured I would poke my head in to see if the hardware store carried anything. Got a small roll of 1/32nd fiber gasket material with chemical treatment to withstand oil and gas. Got my gaskets cut out and Now I am fighting with needle bearings today...
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 05-03-2014, 04:39 PM   #152
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
All part of the fun! LOL!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 05-05-2014, 11:21 AM   #153
jcramsey
jcramsey's Avatar
Hahah yea it is TJ!
Finally got the trans all back together and it looks like everything is working like it should. Now to tackle the electrical side of this beast. Need to test my solenoid and see if it is working.. Debating on whether or not I need to use the governor...
The Egg Hauler
The Government Mule
Old 05-05-2014, 01:24 PM   #154
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Originally Posted by jcramsey View Post
Hahah yea it is TJ!
You don't need no stinkin governor()! Just watch this video of my truck! https://www.youtube.com/watch?v=YoiM0nIA_7c
Old 05-05-2014, 01:32 PM   #155
jcramsey
jcramsey's Avatar
You're right, I could probably get by without it... I was just reading that if you bypass some of the factory electricals when using the OD, the trans will just freewheel when you let of the gas and you get no engine braking. I like being able to have a little extra help when gearing down from time to time.
Your 292 sounds pretty healthy for an old wore out 6!
The Egg Hauler
The Government Mule
Old 05-08-2014, 08:27 AM   #156
jcramsey
jcramsey's Avatar
Got my solenoid cleaned up and tested yesterday.... it works!!! So happy I dont have to buy a new one...those jokers ain't cheap!
The Egg Hauler
The Government Mule
Old 06-22-2014, 09:20 PM   #157
jcramsey
jcramsey's Avatar
Finished up the Rustoleum Rebuild on my trans....Now to get it in the truck! Hopefully this one works out good. Still trying to figure out what I want to do with all the spare OD parts I've got laying around now.
The Egg Hauler
The Government Mule
Old 06-22-2014, 10:50 PM   #158
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Tranny looks good dude!
Old 06-23-2014, 09:31 PM   #159
Dean'smeanmachine
Dean'smeanmachine's Avatar
looks good
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 06-24-2014, 08:12 AM   #160
jcramsey
jcramsey's Avatar
Originally Posted by Dean'smeanmachine View Post
looks good
Thanks TJ and Dean!
Just picked up an s10 T-5 and vintage metal works adapter for my brother last night. Looks mighty tempting setting on my workbench though
The Egg Hauler
The Government Mule
Old 06-24-2014, 11:33 AM   #161
1963c-10
1963c-10's Avatar
Trans came out great....and I'd hang on to the spare parts. Hopefully you never need them, but better to have them if you do.
And glad you were able to find sheet gasket!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-01-2014, 04:12 PM   #162
jcramsey
jcramsey's Avatar
Thanks! Will probably putting off the trans install until the cooler weather comes. Right now is driving time. Probably a good idea to keep the extra trans parts just in case.
Yes, I was pumped to find the correct gasket material so close to the house! Its a good little hardware store. I love being able to ride my bike over to pick up little stuff like nuts and bolts when I'm in the middle of working on something.
The Egg Hauler
The Government Mule
Old 07-01-2014, 10:18 PM   #163
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Then get to work!!!!!
Old 07-03-2014, 03:12 PM   #164
jcramsey
jcramsey's Avatar
Drove The Egg Hauler to a local monthly cruise in last night. I've been having some clutch/column shifter interference lately and the problem finally worked itself into a need-to-fix situation about a mile from the show. Somehow my clutch pivot bar had worked itself out of the frame mount so it was hitting my shifter rod when engaged, and it finally worked out far enough to where the clutch was no longer disengaging when the pedal was pressed. Thirty minutes in a bowling alley parking lot on my back in the blazing heat and I had it back in place and secured.
Truck had a v8 in it when I first go it. Are the pivots different from a V8 to an L6?
Had a great time at the show though. Another guy had a slick 64-66 stepside with porterbuild goodies that he built for his parents, and I met local forum member ChuckDriver who has a really sweet 57 big back window truck.
The Egg Hauler
The Government Mule
Old 07-10-2014, 12:00 AM   #165
likaroc13
Rollin' Old Skool
Just read through your whole thread. Glad it was only 7 pages so far! It can get overwhelming trying to catch up on some of these builds. Such a cool truck you have acquired. It has lots of character. I like the original fenders on it. I would possibly patch the passenger fender & try to match the patina, but I'd keep the driver's side as-is. Like you, I wouldn't get too extreme with it. Keep it fairly simple & enjoy. You've done a great job with your modifications so far. Keep up the nice work!
Btw, I snapped a couple pics of your truck the other night at Bessinger's, without ever knowing it was yours. I think you & maybe your wife(?) were sitting behind when I walked by. If I had known it was you, I would've said hi. I saw & took pics of that other stepside '64-66, & I saw it last month at another cruise-in as well. It's a nice ride for sure! I had entered my Tahoe at Bessinger's last month but didn't this time around.
If you get a chance, you should come out to the cruise-in at Sonic on College Park Rd. in Ladson. The local street rod club puts it on the second Saturday of the month, & the muscle car club does it the third Saturday. I usually try to make it to at least one of them each month if I can. Also, not sure if you know about it, but here's a calendar with lots of car club events/shows in the Lowcountry & surrounding areas:
http://www.autoclubcalendar.com/
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 07-15-2014, 12:28 PM   #166
jcramsey
jcramsey's Avatar
Hey Phillip...
Glad you like the truck...I appreciate the comliments. Good thoughts on fixing the passenger fender and leaving the driver's as is. I need to hone my welding skills before I start in on that. I've got the tools...just not the skill yet
I hate that I missed you the other night! Yea I was sitting with my wife (tall blonde) behind the truck along with my inlaws and some friends who came in town to visit.
I will have to hit up the Sonic cruise-in. Our summer schedule has us all over the place for the next month or two, but hopefully I can slip in a weekend cruise soon.
Thanks for the calendar...that's awesome to know what's going on!
Jeremy
The Egg Hauler
The Government Mule
Old 07-15-2014, 03:23 PM   #167
likaroc13
Rollin' Old Skool
Hey Phillip...
Jeremy
You're welcome for the calendar. I know what you mean about being all over the place, as we've been/will be in the same boat. Maybe we'll catch up with each other sometime though.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 07-15-2014, 04:23 PM   #168
rusty76
rusty76's Avatar
Glad to see you out and enjoying it.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 07-15-2014, 09:58 PM   #169
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Glad you had a good time bud!
Old 07-16-2014, 09:39 AM   #170
jcramsey
jcramsey's Avatar
Thanks guys...I am definitely enjoying it!
The Egg Hauler
The Government Mule
Old 12-29-2014, 12:35 PM   #171
jcramsey
jcramsey's Avatar
Just won a 4bt Frito Lay stepvan on DoveBid, now to get it home.....
The Egg Hauler
The Government Mule
Old 12-29-2014, 12:43 PM   #172
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Old 12-29-2014, 05:36 PM   #173
rusty76
rusty76's Avatar
Hmmmmm. Sounds interesting.
My build thread
Crossmembers CC
Old 01-09-2015, 10:34 AM   #174
jcramsey
jcramsey's Avatar
Here she is. Drove it home yesterday. 93,000 mile 4bt with Allison trans. Not sure if I will use it in the 66 or not, but it's not off the table just yet.
The Egg Hauler
The Government Mule
Old 01-09-2015, 10:35 AM   #175
jcramsey
jcramsey's Avatar
93,000 miles
The Egg Hauler
The Government Mule
