#151 |
Re: Project "River Truck" - CCLB 4x4
And here's a video that has more info on how I built them:
1982 GMC Crew Cab 4x4 - "River Truck" build thread 1973-1987(91) Chevy/GMC How-To Videos |
#152 |
Second Chance Program
Those are pretty awesome!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
#153 |
I love the tow hooks!
#154 |
Hmm... I dunno. Not beefy enough.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#155 |
Nice job on the shackle mounts!
#156 |
Thanks guys! I'm glad you like them. Sodell, yesterday I saw a $30 tailgate on craigslist off a '79....
#157 |
I saw that in Huntsville, I am going out of town tomorrow, hope I can pick it up next week...Thanks.. I am going through KC and I am going to stop by Classic Parts
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
#158 |
Not much to report lately but I've been having fun with the truck. Drove it to an outdoor wedding where it got a lot of attention. Cut and split some wood the other day. These are the sort of outings that this truck is for.
#159 |
So some bigger news.... Yesterday I ordered a 4" lift from Offroad Design. I'm pretty excited about it! I decided to pull the bed off so that the rear lift install will be a little easier but mainly because I've been needing to get access to the fuel lines near the tanks. They need to be replaced and it would be almost impossible to do with the bed on. I had never taken a bed off before but it's not a massive job. 8 bed bolts, a few electrical connections, rear axle breather tube, disconnect the fuel fillers from the bed and it comes off.
#160 |
A few more...
#162 |
Thanks! The truck has 33"s on it right now and I'm going to see how it looks after the lift. I think 35"s might be the ticket but I really don't want to spend $1000 on tires for this truck right now. I do have a set of very worn 35"s that I could swap on there so we'll see....
#163 |
Sweet! Did you go with custom ORD springs? Or the tuff countrys?
#164 |
The custom ORD springs are a cool product but I didn't think they would be worth the money in my case since this truck will rarely be flexed out. Plus they are about twice as expensive. I went with the Tuff Country HDs because they are supposed to be for heavier trucks. Since this is a crew cab and has a 454, I thought the HDs would be better. Plus, there is a chance that I might swap in a cummins later on.
#165 |
Nice. I think thats the perfect choice for you!
#166 |
Cool truck. Are you using the shackle flip in the rear?
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
#167 |
Thanks guys! Here is a run down of what I ordered:
4" Tuff Country HD springs for the front Dana 60 U bolt kit 2" drop pitman arm Tuff Country SX8000 shocks front and rear ORD 4" 1-ton shackle flip for the rear ORD greasable main eye kit for front of the front springs ORD greasable heavy duty front shackles I already have the ORD extended brake lines and also their weld in and bolt in steering box braces. I thought about doing the heave duty greasable rear shackles but I didn't want to spend another $200 right now. Shipping on everything was $133.
#168 |
Just read the whole thread and your doing a great job! And you did real well with this truck, not easy finding a truck like yours that hasn't been abused terribly. Keep it up!
#169 | |
#170 |
I've been working on the truck quite a bit over the last few weeks. The lift progress has been much slower than I expected. Mainly because of rusted/seized fasteners. It's coming along though! I started on the rear of the truck first.
Here is a full parts list: ORD 4" shackle flip brackets ORD 4.5" Super Shackles ORD greasable bolts and bushings for entire rear suspension Replacement rear stock springs New rear spring U-bolts Tuff Country SX8000 shocks front and rear Tuff Country HD 4" lift front replacement springs New Dana 60 U-bolt kit ORD greasable bolts/bushings for the front of the frontsprings ORD heavy duty greasable front shackles Skyjacker drop pitman arm ORD extended braided stainless brake lines Here are some picture's of most of the parts and the frame prep.
#171 |
When I first went to trial fit the new shackle hangers, shackles, and old springs, they did not line up. Both rear spring eyes were to far towards the center of the truck. After a while I decided to cut the U-bolts so I could check the spring alignment more closely and that's when I found out there were 3 or 4 broken leaves in on spring pack. At that point I had to order new rear replacement springs. These should be stock replacements (or at least close) without any lift built in. It's tough to tell what weight rating springs actually came on your truck. If you ever have to do this, make sure and shop around. Lot's of places carry the same springs and the prices vary wildly. Make sure and check shipping also. I had a friend pick these up for me and saved $120 in shipping. Each spring was about $160 but there were places charging double that.
#172 |
Here are a few shots of when I finally got everything back together. It looks good and I feel like its a pretty heavy duty suspension now.
#173 |
This is the pile of dirt, rust, and metal shavings that came out of the truck during just the rear lift install. And then the pile of parts that I removed from the truck.
#174 |
The first picture is of how low the truck was before. I really think the springs were sagged. And then a couple of pictures of the truck after the rear was lifted. I still have to tackle the front lift. The rear lift actually gave me 6.25" of lift even though it was supposed to be a 4". I think that is mostly due to the sagged old springs. Its possible that it might settle down some too. I was surprised buy how tall it is.
#175 |
Here's a video that shows the rear lift installation. If you're interested or are thinking about doing a lift, I think it's worth a watch. There's a lot of good information in there that I had to learn along the way:
