Old 10-10-2014, 09:25 PM   #151
Heylookitsdylan
Re: First Steps LS Swap......
You answered SO many of me questions with this build thread!!! Keep up the awesome work!
What are you found to do for a drive shaft, and speedometer???
Heylookitsdylan is offline   Reply With Quote
Old 10-10-2014, 11:01 PM   #152
Heylookitsdylan
*going to do for the speedometer*
Old 10-17-2014, 03:57 PM   #153
lynnfield
The Waco Kid
lynnfield's Avatar
Dylan, I'm going to run these gauges from new vintage. They were the closest in looks to the stock gauges I was able to find. They fit into a factory bezel and Summit had them on sale back in August. http://www.summitracing.com/parts/nv...del/c10-pickup
lynnfield is offline   Reply With Quote
Old 10-17-2014, 04:01 PM   #154
lynnfield
The Waco Kid
lynnfield's Avatar
Replaced the O rings on the stock fittings. They are viton size 109 & 110 for 5/16" and 3/8".
Old 10-17-2014, 04:12 PM   #155
lynnfield
The Waco Kid
lynnfield's Avatar
Working on the fuel system………I had to trim the ears (maybe a 1/16") on the lock for the 5/16" line at the fuel filter to get it to slide on the end of the fitting. The way the return line comes out of the filter, there is a larger section and then it necks down to the 5/16" line size and that gets in the way of the lock, but just slightly. If you look closely at pic 3, you can see what I am referring to. Greg
Old 10-17-2014, 04:17 PM   #156
lynnfield
The Waco Kid
lynnfield's Avatar
I ordered an airaid intake tube and filter to replace the stock one. Also a large metri-pack kit to make up my connections.
Old 10-17-2014, 04:22 PM   #157
lynnfield
The Waco Kid
lynnfield's Avatar
Decided to use the transmission cooler from the 06' truck.
Old 10-17-2014, 04:25 PM   #158
lynnfield
The Waco Kid
lynnfield's Avatar
More trans cooler mounting, made it to fit directly under the hood latch.
Old 10-17-2014, 04:35 PM   #159
lynnfield
The Waco Kid
lynnfield's Avatar
Now for the transmission lines. I rolled the line going into the bottom of the radiator back toward the engine, inline with the crossmember both to clear the fans and I'm going to use this point to attach a cushion clamp. The push connect end had to be cut off the stock line and a regular flare connection put in its place. Also, had to get adapters to go from 5/16" to 3/8" line size at the radiator.
Old 10-17-2014, 07:15 PM   #160
oldman3
oldman3's Avatar
Great update and pics...Jim
oldman3 is offline   Reply With Quote
Old 10-21-2014, 04:56 PM   #161
lynnfield
The Waco Kid
lynnfield's Avatar
Still working on transmission lines, started on the oil cooler side….
Old 10-21-2014, 04:58 PM   #162
lynnfield
The Waco Kid
lynnfield's Avatar
More of the transmission lines
Old 10-21-2014, 05:04 PM   #163
lynnfield
The Waco Kid
lynnfield's Avatar
Here's the cushion clamp installed, and the finished product. I don't really like using compression fittings, but it was the only way to use the stock components from the 06' truck because of the "push connect" type fittings the factory uses. I'll probably try to come up with something better later. Greg
Old 10-21-2014, 05:10 PM   #164
lynnfield
The Waco Kid
lynnfield's Avatar
IT LIVES!!!……….I got to this point and hooked up only the wires I needed to start it up. I slung wires every which way, and it started on the first try. There's still a lot of work to be done, but at least I know it fires up and will go into gear. I can't say enough about Bill from BP Automotive, the guy has literally answered the phone or returned my call every time I've tried to contact him. Thanks, Greg
Old 10-21-2014, 07:24 PM   #165
oldman3
oldman3's Avatar
Lines look good. Glad to hear about the engine, should only get better from here...Jim
Old 10-21-2014, 11:40 PM   #166
boynton
boynton's Avatar
I really like what you did with the trans cooler. I may have to borrow that idea!
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 10-22-2014, 12:18 AM   #167
lynnfield
The Waco Kid
lynnfield's Avatar
At start up I had a gas leak, an exhaust leak, and an oil leak. The gas leak was easy, I didn't tighten one of the fittings all the way. The exhaust leak is going to be fixed at the exhaust shop, they missed a small bit at the top of one of the seams when they welded it (not happy with that or the job they did overall). The oil leak was the oil cooler block off, where I had drilled and threaded the port for the oil sender. I have ordered one of these to fix that issue: http://www.jegs.com/webapp/wcs/store...Term=555-23681
I don't have any of the gauges hooked up, so I have not let it run more than 2 or 3 minutes at a time. I'll start running wires with permanent connections, and wiring up the gauges this week. Thanks, Greg
Old 10-22-2014, 12:25 AM   #168
lynnfield
The Waco Kid
lynnfield's Avatar
I need to find a good (above average?) black and chrome gauge bezel, if anyone has or knows where I can find one. I don't want to use a new one, I think it would stick out. My interior is in good shape, but not new. I have contacted a few board members, no luck so far. Greg
Old 10-22-2014, 12:39 AM   #169
boynton
boynton's Avatar
Ill look through my parts and see if I have a decent one if so im driving through waco on the 31st
1970 SWB Step-Side
Old 10-22-2014, 01:08 PM   #170
Low Elco
Congrats! I did something similar with my trans cooler.
Low Elco is offline   Reply With Quote
Old 10-25-2014, 03:29 PM   #171
lynnfield
The Waco Kid
lynnfield's Avatar
Thanks guys! Little progress this week, started wiring the gauge panel.
Old 10-25-2014, 03:33 PM   #172
lynnfield
The Waco Kid
lynnfield's Avatar
Received a few things in the mail this week also. The new block off plate, to fix the oil leak, it's well made and beefy. I went with the Holley A/C brackets with a sanden compressor mount. Greg
Old 10-29-2014, 09:35 AM   #173
boynton
boynton's Avatar
Would this work? Not a chrome bezel but a nice dusty black one.
1970 SWB Step-Side
Old 11-01-2014, 11:35 PM   #174
lynnfield
The Waco Kid
lynnfield's Avatar
Still working on the wiring. I'm probably going way more into this than I have to. I want to keep the bulkhead connector on the outside of the firewall able to be separated into the two halves. I have moved a couple wires, first the original coil wire is now the ignition on for the ECM. I have moved that wire to the left side of the block. Second the oil sender now has a wire, I used one side of the old amp gauge to get it up to the cluster and moved the lead to the left side of the block. The new gauge package has a volt meter and only requires a positive and negative lead to work.
Old 11-01-2014, 11:41 PM   #175
lynnfield
The Waco Kid
lynnfield's Avatar
Last, the fuel gauge wire, I de-terminated the lead on the front of the of the fuse block, swapped out the male connector for a female connector and routed it thru the left side of the block. Pic #2 & #3 are of an extra fuse block I had laying around. Greg
