#151 |
![]() Join Date: Apr 2013
Re: Parting out another 72 LWB and other parts
I'm sure that I have several of the arms.
How about $10.00 for just the arm mailed to you. QUOTE=allons;6439010]Do you have a windshield wiper motor with the offset arm attached? I don't care if motor works, I just need that offset arm. Thanks, Jim[/QUOTE]
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
#152 |
I'll do the $10 for the arm. Please chose the best one for me. How do I pay you?
#153 |
paypal or money order.
PM sent with info.
#154 |
I do have a 6 lug rearend, as far as the condition goes I don't know much about it.
#155 |
I don't know if your still looking, but I just came across a complete gas pedal assy, and I believe I have the carb bracket for a 4 barrel. I don't have the cable for through firewall.
#156 |
Any auto trans shift linkage available? Thanks...
#157 |
![]() Join Date: Aug 2007
looking for grille surround support brackets if you have them....
#158 |
I might have some, I'll try to check this weekend.
#159 |
In need of a 69 grille and under hood wiring harness
#160 |
Do you have a center Link for sale?
#161 |
What are you referring to as a center link?
#162 |
#163 |
How bout a steering wheel?
#164 |
if you cut up the bed I would be interested in the passenger side tail light section.
#165 |
![]() Join Date: Jul 2013
Hey Brian,
How about the upper windshield/roof lip section? As last time, I'll come visit you.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#166 |
I'm needing a few random parking brake cable parts -
* the 2 guide loops that hook into the frame (x2), * the U-shaped connector that joins the rear and the intermediate cables (x1), * the equalizer with hex nut for adjusting the tension on the cable (x1), and * the pin & C-clip to connect the parking lever arm to the brake shoe inside the drum (x1). Any chance you have them? I would be able to send you some pics of the exact parts needed. Thanks!! |
#167 |
Sorry I don't have one.
#168 |
Sorry, I don't have any good tail light sections.
#169 |
Mike, How about a picture I have a part of a cab that might can donate.
#170 | |
If I have any of those parts I'll just have to go dig through my storage bus. I'll try to this weekend.
#171 |
#172 |
Is the bench seat available?
1969 GMC SWB |
#173 | |
Let me know
#174 |
do you have the v8 350 engine frame mounts/perches? if so, how much to 95822?
#175 |
do you still have the bench seat?
