Old 07-04-2014, 08:47 PM   #151
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Project "Schrum" 1959 Gmc 100
I'm stumped on some things
Put a new fuel pump in and its still not pumping fuel..
I wish more people would respond
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 07-04-2014, 09:28 PM   #152
lowrodderchev
lowrodderchev's Avatar
Ok did u check your tank maybe blow a little air in the line that's before the pump still a issue try running a line from pump to a gas can to isolate the problem
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 07-06-2014, 12:13 PM   #153
Root2812
Root2812's Avatar
Make sure fuel is getting to the pump like lowrodderchev said. The tank outlet could be plugged and so could the line. If you have fuel to the pump check your lines to the carbs and your fuel filter to make sure none of those are clogged or restricted. Its a basic system so tracing your way through it you should be able to find the problem. A blow gun will be useful here.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 07-07-2014, 01:58 AM   #154
OrrieG
OrrieG's Avatar
This thread pretty much gave you the road map for figuring out what is wrong.
http://67-72chevytrucks.com/vboard/s...d.php?t=633007
Go back and review and test the system from your plastic tank to the carb, opening each fitting in sequence: line from tank to pump, pump outlet, fuel line to carb. Also make sure that the carb bowl is primed, if is has been sitting for a while without running the gas has evaporated out the vent, saves time and battery and starter life not having to grind away while the pump fills the float bowl.
OrrieG is offline   Reply With Quote
Old 07-07-2014, 05:30 PM   #155
SCHRUMGMC
SCHRUMGMC's Avatar
I put a new fuel hose that goes into the tank..checked the fitting i blew through it and put a piece of paper towel at the end before the pump it blew out..so it couldn't be clogged up.When the money comes in, I am going to have new fuel lines put on before I put the new tank in
1971 GMC Sierra
1959 GMC 100
Old 07-08-2014, 06:29 AM   #156
coralhead
coralhead's Avatar
Are you gravity feeding the fuel from a bottom tank fitting or are you trying to pull the gas up through the tank filler opening. A stock mech fuel pump has a hard time siphoning. I used a temp outboard motor fuel tank with a fuel squeeze ball to prime the mech pump.
coralhead is offline   Reply With Quote
Old 07-08-2014, 10:20 AM   #157
SCHRUMGMC
SCHRUMGMC's Avatar
The hose goes into the opening. it worked fine until, I put the rebuilt carb on there. It cranked up fine, and then eventually no gas what so ever. I am going to put new, fuel lines in when I put a new tank in
1971 GMC Sierra
1959 GMC 100
Old 07-08-2014, 11:13 AM   #158
dubie
dubie's Avatar
it sounds like your rebuilt carb might be the problem. Maybe a dirty seat or needle, fuel filter in backwards or your float isn't operating properly. I've rebuild many carbs and you will run into problems like this from time to time. I'd be starting with that carb if I was you
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 07-08-2014, 11:28 AM   #159
SCHRUMGMC
SCHRUMGMC's Avatar
It is not the carb, I put a mason jar after the pump to see if it'd pump gas and it didn't do one drop. I may just end up buying new fuel lines for the future, so I won't have to worry about debris or rust getting into the pump
I may just try putting more gas into the tank, I know I will need a new fuel line from the pup to carb as the current one isn't lining up, and rig it behind the thermostat so it is easier access
1971 GMC Sierra
1959 GMC 100
Old 07-18-2014, 03:44 PM   #160
lowrodderchev
any luck?
Old 07-18-2014, 09:12 PM   #161
SCHRUMGMC
SCHRUMGMC's Avatar
I've been gone out of town for a week, honestly I have not even touched it and neither do I care right now as I have no money
1971 GMC Sierra
1959 GMC 100
Old 08-01-2014, 09:08 AM   #162
SCHRUMGMC
SCHRUMGMC's Avatar
Finally fixed the problem
Put a new Fuel pump in, all it needed was priming
Put a new fuel line on
I will put a new Vacuum line on here soon
1971 GMC Sierra
1959 GMC 100
Old 08-01-2014, 10:20 AM   #163
lowrodderchev
Sweet glad you got her running
Old 08-01-2014, 11:16 AM   #164
Denee007
Denee007's Avatar
Good job! I bet it's nice to hear it running again!
dne'
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 08-01-2014, 11:38 AM   #165
SCHRUMGMC
SCHRUMGMC's Avatar
It sat there for so long the grass died under it Ha !!
I need to do the tail light wiring on it to finish that to make it look decent under there
Well, I have a local newspaper coming out to do a story on me and the truck. It may make it to Magazines not really sure.
1971 GMC Sierra
1959 GMC 100
Old 08-01-2014, 11:54 AM   #166
Daze57
Daze57's Avatar
Good Deal !!! Glad you got it up and runnin;
Good luck with the newspaper story -i;m sure your grandfather would be proud of you.
Daze57 is offline   Reply With Quote
Old 08-01-2014, 12:35 PM   #167
Denee007
Denee007's Avatar
Just for fun, you may want to start writing your story in advance (don't be too wordy), then fine tune your story to the point, possibly with a past pic or two, that way when you're approached, you'll have the story ready. If they don't, you'll have a story to pass down to your grandchildren Keep the story short and sweet; humans today have short attention spans and don't like to read paragraph after paragraph.
Perhaps put your story on here~ we'll proof it for you, but remember short and to the point!
Old 08-02-2014, 12:28 PM   #168
OrrieG
OrrieG's Avatar
Glad its running, usually something basic. Denee, probably good post, but you lost me after the first sentence!!!;
Old 08-02-2014, 03:15 PM   #169
Denee007
Denee007's Avatar
Hey Orrie! I was just offering suggestions for if/when Schrum gets a spot in his local magazine. See that last sentence that he wrote down below
dne'
Old 08-02-2014, 10:21 PM   #170
SCHRUMGMC
SCHRUMGMC's Avatar
I went to start the truck today and it wouldn't stay cranked
I've got to figure somethings out with this thing quick
1971 GMC Sierra
1959 GMC 100
Old 08-03-2014, 09:37 AM   #171
coralhead
coralhead's Avatar
How much fuel do you have in the tank. If you are going to siphon from the fuel opening you should have the bottom of the pickup tube at least 4 to 6 inches below the surface of the fuel. These 235's use more fuel than you think . If you suck just a bit of air from the line coming out of the gas surface you will lose siphon. You could then again put the fuel tank in the truck and get that working before anyone comes and takes pictures. Makes it look like you know what you are doing. If it's a newspaper article they can imply that it is running unless they want to put a video in the article. Not too many videos in the printed papers.
Old 08-03-2014, 06:19 PM   #172
SCHRUMGMC
SCHRUMGMC's Avatar
http://www.youtube.com/watch?v=deBKS...ature=youtu.be
Truck runs awful
1971 GMC Sierra
1959 GMC 100
Old 08-28-2014, 02:42 PM   #173
SCHRUMGMC
SCHRUMGMC's Avatar
http://www.youtube.com/watch?v=qd-9-...ature=youtu.be
Adjusted the timing and it cranked up again, still have issues with pushing the choke in
1971 GMC Sierra
1959 GMC 100
Old 08-28-2014, 07:01 PM   #174
Denee007
Denee007's Avatar
Hey Howard, so it runs now except for the choke? or does it die out when you push the choke in? or is it just an bad choke cable? Have you driven it since you've gotten it running?
dne'
Old 08-28-2014, 10:10 PM   #175
SCHRUMGMC
SCHRUMGMC's Avatar
How do I know if its a bad choke cable?
I've driven it occasionally, it dies when I push the choke in, watch the video and you'll see what happens to it
1971 GMC Sierra
1959 GMC 100
