Old 11-30-2014, 06:20 PM   #151
mooseknuckles
mooseknuckles's Avatar
Re: Owen's C10
....threw down a layer of rage gold, and sanded till I found them. then I sealed it up with two coats of epoxy.
mooseknuckles is offline   Reply With Quote
Old 11-30-2014, 09:38 PM   #152
Bennett68C10
Bennett68C10's Avatar
Re: Owen's C10
Looks good
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-01-2014, 09:35 PM   #153
mooseknuckles
Re: Owen's C10
Originally Posted by Bennett68C10 View Post
Looks good
thank you.
Old 12-03-2014, 12:51 AM   #154
tune_1
Re: Owen's C10
Looking good.
Dwight
tune_1 is offline   Reply With Quote
Old 12-03-2014, 08:39 PM   #155
mooseknuckles
Re: Owen's C10
Originally Posted by tune_1 View Post
Looking good.
Dwight
thanks.
Old 12-07-2014, 06:50 PM   #156
mooseknuckles
Re: Owen's C10
messin' around...
Old 12-07-2014, 06:53 PM   #157
mooseknuckles
Re: Owen's C10
...this morning I went to look at a motor, and ended up buying it....02 5.3l with supposedly 177k. I forked out $450 and brought 'er home, stripped it down and cleaned it up some..
Old 12-08-2014, 09:36 AM   #158
Sac
Re: Owen's C10
Nice find on the motor.
Green Survivor Father/Son Truck
<SeveredTies>
Sac is offline   Reply With Quote
Old 12-20-2014, 09:40 AM   #159
McDeezl
Re: Owen's C10
Very cool project and beautiful work!
Jealous of your welding skills ... I'm about 25% welder and 75% grinder :-)
Will be a huge wow factor when you're done.
Guess we can both safely say that Bill's in Oshawa is our saviour!
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=626178
McDeezl is offline   Reply With Quote
Old 12-20-2014, 06:21 PM   #160
Pinky6872
Re: Owen's C10
Originally Posted by mooseknuckles View Post
messin' around...
I like how you made the front frame rails match. It looks great. I plan on doing the same to mine.
My Dropmember Equipped Build
Instagram @chrispinkosky
Pinky6872 is offline   Reply With Quote
Old 12-21-2014, 05:44 PM   #161
mooseknuckles
Re: Owen's C10
thanks
thanks, got bill lookin for a front clip for me right now....
I saw it done on another thread and couldn't help but do it too. I think it cleans it up a lot...
Old 12-21-2014, 05:45 PM   #162
mooseknuckles
Re: Owen's C10
shaved cowl..
Old 12-22-2014, 11:34 AM   #163
Bennett68C10
Re: Owen's C10
Wow nice job on the cowl
Keith
66 Suburban
IG: bennett68c10
Old 12-22-2014, 06:09 PM   #164
mooseknuckles
Re: Owen's C10
thanks bro...
Old 12-28-2014, 07:09 PM   #165
mooseknuckles
Re: Owen's C10
removed the manual steering box, linkage, and sway bar...(I put the sway bar on the '69) and got the front cross member unbolted and ready to come out....I'm going to be using a PB drop member
Old 12-28-2014, 07:13 PM   #166
mooseknuckles
Re: Owen's C10
removed the steering box mounts...
Old 12-28-2014, 07:19 PM   #167
mooseknuckles
Re: Owen's C10
....cut the rivets for the rad support mounts, and made some 3/16 plates. I'm going to make a tubular cross member that bolts on with the mounts.
Old 12-28-2014, 08:04 PM   #168
dkauffman05
dkauffman05's Avatar
Re: Owen's C10
Fantastic work! I love the attention to detail.
dkauffman05 is offline   Reply With Quote
Old 12-28-2014, 08:08 PM   #169
mooseknuckles
Re: Owen's C10
thank you.
Old 12-29-2014, 09:10 AM   #170
mcbassin
Still Learning
mcbassin's Avatar
Re: Owen's C10
Killer work on the frame, dash and cowl! Looks great....
Nice score one the 5.3 too
mcbassin is offline   Reply With Quote
Old 12-29-2014, 11:23 AM   #171
mooseknuckles
Re: Owen's C10
thanks.
Old 01-01-2015, 06:50 PM   #172
mooseknuckles
Re: Owen's C10
I've been super bored lately with the holidays, so I spent some time in the shop getting caught up on some things that were bugging me....pancaked the front cross member...cause I always wanted to try it, and I finished the other front cross member, and shaved the hole in the firewall where the wiring went through....
Old 01-04-2015, 03:50 PM   #173
Pinky6872
Re: Owen's C10
What thickness metal did you use for the frame work? I tried to use some left over crossmember metal but it was a different thickness so I'll have to buy some.
Old 01-04-2015, 04:00 PM   #174
mooseknuckles
Re: Owen's C10
I think it was 3/16"....it was a bit thicker but I kept the top flush and ground most of it down...
Old 01-11-2015, 07:42 PM   #175
mooseknuckles
Re: Owen's C10
I picked up some '68 front fenders cheap, that some body hacked some Camaro vents into the side of, so I made a quick patch, and slapped some bondo on 'em quick to hide that mess....not sure if I will use these, but they work good enough for mock up...
