Old 10-07-2018, 06:15 PM   #151
nlped
nlped's Avatar
Re: Walter DeWayne...Walt for short
I decided not to wait & got the transmission in place too. Now, me & my sore back are going in for the night.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-12-2018, 09:15 PM   #152
nlped
nlped's Avatar
After a bunch of tweaking and measuring, I’ve concluded that the BBC sits entirely to low in the chassis to fit any kinda manifolds or headers. It sits about an inch lower than it did in the camper chassis. The mounts seem to be for a SBC vs a BBC?
Carter
Old 10-12-2018, 11:19 PM   #153
68bowtie
68bowtie's Avatar
Ruh roh
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 10-13-2018, 05:19 PM   #154
nlped
nlped's Avatar
Originally Posted by 68bowtie View Post
Ruh roh
Yep! Even the stock exhaust manifolds hit the frame and the upper PB k-member mounting points. No way this motor can stay this low in the frame. Nate's travelling, but he's emailed me a few times and says he'll help out when he gets back to the shop.
If it won't work... I'll snatch the BBC out and put the fresh SBC out of Vern into this chassis and put the BBC in Vern. The ole swap'O'Roo.
Carter
Old 10-15-2018, 04:10 PM   #155
nlped
nlped's Avatar
Well, I haven't heard back from Nate, but I found a post from Nate in 2007 that states, " The BBC tabs are just over 1/2" taller than the SBC tabs. So, you can run a SBC with the tabs for a BBC, but not the other way around". But then in 2014 he stated that for the Mild DM, the SBC and BBC tabs are the same...that was me that asked the question back then. I don't think that was the correct answer. So, now I know I've got SBC tabs instead of BBC. I hope to get an answer soon, so I'll continue to wait to hear back from PB.
Carter
Old 11-09-2018, 09:05 PM   #156
nlped
nlped's Avatar
I finally got the rearend bag mounts welded in place and had it blasted and powdercoated.
Carter
Old 11-09-2018, 11:07 PM   #157
Advanced Design
Advanced Design's Avatar
Ever hear from Nate? The diff came out nice.
Advanced Design is offline   Reply With Quote
Old 11-09-2018, 11:15 PM   #158
nlped
nlped's Avatar
Hey Doug,
I did hear back, but don’t have a remedy yet. I’ve sent him quite a few pictures of the chassis & motor (& it’s orientation). He’s going to design/make a set of motor mount plates that'll raise the current setup about 5/8”. That should be plenty, or so I hope. But he said it’d be a week or so before he’d have time to draw them up and such.
We’ll see how it goes.
Carter
Old 12-20-2018, 11:21 PM   #159
nlped
nlped's Avatar
Well, still no solid word from Nate. I’m really pretty disappointed in the lack of give-a-$h!T. I can do a lot of things but chassis/motor metal fab stuff on a planned out setup ain’t my game. But, I guess I’m going to have to figure it out.
On another note, I sold my 77 C10 so I’m going to be more focused on this build again...hopefully until the end this time. I’ve gotten the rearend housing back from powdercoat and I’ll be assembling and setting up the gears and Eaton Posi this weekend. I decided to go 3.42’s instead of 3.73’s since the BBC/700r4 should be good with a lower rpm functioning range.
Carter
Old 01-06-2019, 09:46 PM   #160
nlped
nlped's Avatar
No word from Nate, but I did get the rearend back from my buddy. Eaton posi and new 3.42 gears done! I did some checking & cleaning tonight, but tomorrow I’ll try like He77 to get it completely assembled.
Carter
Old 01-07-2019, 08:31 PM   #161
nlped
nlped's Avatar
Not a lot of pictures but I got the rearend mostly assembled. Somehow I lost the d@mn C-clips, so I had to order some but they should be here tomorrow. I got everything else done and stuck it under the chassis.
Here’s a pic to prove I’m progressing.
If I ever get the correct engine mounts, I’ll fit the exhaust. Then.... I’ll get the fuel lines, tranny lines, brake lines and airlines routed and fit the cab and frontend. After that, blow it apart & powdercoat, paint and such.
Carter
Old 01-18-2019, 06:53 PM   #162
nlped
nlped's Avatar
Well, finally got it on the ground. I just ran airlines to a shrader valve for fronts & back. But it has wheels on it to give me an idea of how it’ll sit. I did figure out that the shocks I have are all 4 for the front so I made a call and have the correct rears on the way. But they don’t affect these pictures.
Carter
Old 01-18-2019, 06:59 PM   #163
nlped
nlped's Avatar
Comparison...down & up.
Carter
Old 01-18-2019, 09:20 PM   #164
68bowtie
68bowtie's Avatar
Cool. That thing is LOW.
Old 01-18-2019, 11:18 PM   #165
nlped
nlped's Avatar
It’s pretty low considering its a touring front & rear PB setup. The front PB crossmember is actually laying on the ground and the low spot on the frame by trans crossmember is 1/2” off the ground. Not as low as the Extreme stuff, but plenty low for an ole beater like Walter.
Carter
Old 01-18-2019, 11:43 PM   #166
kxmotox247
kxmotox247's Avatar
Looks good. Your raised height... is that going to be your ride height?
kxmotox247 is offline   Reply With Quote
Old 01-19-2019, 12:09 AM   #167
nlped
nlped's Avatar
It’ll go a good bit higher as it sits now. But I think the last pic will be close to ride height but until I get the body on there I won’t know for sure.
Carter
Old 01-19-2019, 12:24 AM   #168
kxmotox247
kxmotox247's Avatar
Looks like it going to sit nice with plenty of good ground clearance.
Old 01-19-2019, 08:04 PM   #169
nlped
nlped's Avatar
I got a little bit done today. Got the PB tank/compressor mounts located and bolted up.
Carter
Old 01-19-2019, 08:10 PM   #170
nlped
nlped's Avatar
I also finalized my EFI decision today and ordered the Holley Sniper 550-511 system.
Carter
Old 01-19-2019, 09:18 PM   #171
68bowtie
68bowtie's Avatar
Cool. Looking forward to getting your thoughts on how it fits the big block.
Old 01-20-2019, 06:34 PM   #172
nlped
nlped's Avatar
Time for a test fit of the body to check out fitment.
Carter
Old 01-20-2019, 09:01 PM   #173
TA_C10
TA_C10's Avatar
Subbed. Build looks good so far man. Glad to see you kept the truck and started this thread
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 01-21-2019, 04:18 PM   #174
nlped
nlped's Avatar
Thanks man! I’m glad I kept it too. I think it’s going to be pretty cool when finished.
Carter
Old 01-21-2019, 04:22 PM   #175
nlped
nlped's Avatar
I got some time to work on it this morning. So, I got the stock chassis moved out of the way and tucked the Porterbuilt chassis under Walter. Motor & transmission seem to clear just fine. The inner fenders are the only problem I ran into today...they hit the shocks, but I "clearanced" them to fit, but the 18" tires hit the inner fender about 2" before full bottom. So now I've got to figure out what inner fenders I can use and keep the stock style hood hinges as I have a pretty pricey set of billet hinges on the shelf for Walter...
Carter
