Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-18-2015, 11:09 PM   #151
7dee2
7dee2's Avatar
Re: 72 K30 Build
More welded up holes…
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 01-19-2015, 01:17 PM   #152
7dee2
7dee2's Avatar
Re: 72 K30 Build
More dome light patch progress…
Brett
Old 01-20-2015, 01:33 PM   #153
7dee2
7dee2's Avatar
Re: 72 K30 Build
The grind, almost 50 holes filled so far counting the pillars and small dome patch!
Brett
Old 01-21-2015, 12:39 PM   #154
7dee2
7dee2's Avatar
Re: 72 K30 Build
So here is a fuss-bucket move in an effort to not make any more holes than really necessary. We anchored the outer upper patch using all the holes that were pre-existed by drilling from the inside out.
Brett
Old 01-21-2015, 02:03 PM   #155
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Re: 72 K30 Build
Wait, you don't like welding up random extra holes??
Nice work!
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 01-21-2015, 03:26 PM   #156
DWilbur
Re: 72 K30 Build
That kind of short cut is what some would call a party foul. I spent 2 days welding up 47 holes in my frame that are not required.
DWilbur is offline   Reply With Quote
Old 01-21-2015, 08:35 PM   #157
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 K30 Build
It's looking better already!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-22-2015, 12:47 PM   #158
7dee2
7dee2's Avatar
Re: 72 K30 Build
Nice work!
Thank you sir, yes less holes is better in my opinion.
I hear you. Thinking we have about that many more to go not counting the big panels.
Thanks D! I'm really pleased with how it's turning out.
Brett
Old 01-22-2015, 12:55 PM   #159
7dee2
7dee2's Avatar
Re: 72 K30 Build
Needed a fuel fill patch for the next round of welding.
Brett
Old 01-23-2015, 12:45 AM   #160
swamp rat
swamp rat's Avatar
Re: 72 K30 Build
Looks just like a pre made one!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-23-2015, 11:54 AM   #161
JJorgensen52
Re: 72 K30 Build
Maybe I missed the plan on this, but what are you going to run for a fuel filler?
I'm actually thinking about what to do with my '50 since it's going to have an under bed tank and I'm not a huge fan of the through-floor fill necks
CURRENT
SOLD
Old 01-23-2015, 12:47 PM   #162
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks!
Still have useable saddle tanks from the RV and even if we don't use that set up I'm sure it will be something similar. Also toying with the idea of running another tank all the way in the back between the rails.
Brett
Old 01-23-2015, 12:57 PM   #163
7dee2
7dee2's Avatar
Re: 72 K30 Build
It’s an attack of the Green Slim!! I wanted to treat the lower large patch panel cavity upside down so the slim could seep into the pinch weld. We always spray the can dry when using this stuff so the remainder of the can went in between the roof panels and pillars. It will get a second coat but needed to do this prior to the welding of the panel.
Brett
Old 01-23-2015, 01:24 PM   #164
7dee2
7dee2's Avatar
Re: 72 K30 Build
I didn't really answer your question earlier. The RV saddle tanks have a welded on neck and I'm not sure they will work with the flatbed. The other style tank I'm thinking about would be more like a semi with a screw on cap type fill.
Brett
Old 01-23-2015, 10:05 PM   #165
swamp rat
swamp rat's Avatar
Re: 72 K30 Build
Is that the Eastwood Internal Frame coating?
I was thinking about what to spray inside right above the mirror by removing the visors and spraying in from there. .
Eastwood also sells this stuff:
http://www.eastwood.com/ew-rust-enca...html?reltype=3
I almost pulled the triger on this today for the same purpose, .
http://www.eastwood.com/eastwood-hea...-in-black.html
Not sure what is better and why, any thoughts about one VS the other?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-24-2015, 12:06 PM   #166
7dee2
7dee2's Avatar
Re: 72 K30 Build
Yes it is and here is a link http://www.eastwood.com/internal-fra...arent_id=25961
We needed this kind of product for my 1/2 ton project and decided to use it again for this one.
Some of my reasons for using this product are I've used it before, the color you can tell where it is and where it ain't. This stuff does go on sale and if you buy enough you can get free shipping as well at times so the price was right for us (got 5 cans for under $75 delivered) . It has been around and I think has more favorable reviews?
Other than that I have no opinion except for as much time and effort that goes into fixing one of these cabs I think you would be foolish not to use something.
Brett
Old 01-24-2015, 12:10 PM   #167
mjensen
mjensen's Avatar
Re: 72 K30 Build
Brett, you're making some great progress! Why don't you stop working on yours and come down and work on mine!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 01-26-2015, 01:59 PM   #168
7dee2
7dee2's Avatar
Re: 72 K30 Build
What's next I'll be right over!
Brett
Old 01-26-2015, 02:08 PM   #169
7dee2
7dee2's Avatar
Re: 72 K30 Build
We went from nipples to scar tissue!
Brett
Old 01-26-2015, 09:24 PM   #170
swamp rat
swamp rat's Avatar
Re: 72 K30 Build
you using an arch welder??
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-26-2015, 09:29 PM   #171
nlped
nlped's Avatar
Re: 72 K30 Build
I was wondering if it was a battery charger and some coat hangers.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-27-2015, 02:19 AM   #172
7dee2
7dee2's Avatar
Re: 72 K30 Build
Man it's a tough crowd out there and yes we know it ain't pretty, my boy (who's better than me) and I don't claim to welders! In his defense he was welding over his head and it is solid!
I'll give you one guess who got to grind all that off!
Brett
Old 01-27-2015, 12:52 PM   #173
7dee2
7dee2's Avatar
Re: 72 K30 Build
More panel prep the lower is now ready to go. We needed to fill some holes in the upper outer patch.
Brett
Old 01-27-2015, 08:23 PM   #174
swamp rat
swamp rat's Avatar
Re: 72 K30 Build
You guys are definantly kicking butt on the thing!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-27-2015, 10:16 PM   #175
7dee2
7dee2's Avatar
Re: 72 K30 Build
Is this even possible? I told a buddy today about you and the swamp rat beating us up for the awful weld job and we all had a good laugh.
I'm guessing it was just a bad weld day and debated on posting it (Good, Bad & Ugly you know). So after we checked to see if their was any wire left in the machine we moved on as you will soon see.
Thanks man we are ahead of the thread a little. Gonna keep working the cab but looking into the next phase some.
Brett
72chevy, dually, flatbed, k30, motorhome
