Old 05-16-2015, 04:56 PM   #151
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: Dunce's 59 Fleetside build
Nice work! Will have to use the seat belt mount idea!
ChuckDriver is offline   Reply With Quote
Old 05-17-2015, 08:34 AM   #152
Advanced Design
Advanced Design's Avatar
Really nice work on the exhaust! The exhaust pipe to header connection looks like a ball seat? I've never seen that on a header before. Were the headers built with the connection or did you add it? Apologies if you covered and I missed it.
Advanced Design is offline   Reply With Quote
Old 05-19-2015, 02:45 PM   #153
dunce79
Yeah those are from heart throb exhaust. Hoping they seal well. Thought I'd give them a shot over traditional flanges. I welded them on my headers after trimming them down some. http://www.heartthrobexhaust.com/hea...ccessories.htm
dunce79 is offline   Reply With Quote
Old 06-13-2015, 12:14 PM   #154
djracer
djracer's Avatar
Dunce what are the headers?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-16-2015, 03:21 PM   #155
dunce79
Hooker F-body LSX swap headers. I looked up the application for putting an LS in a 73 firebird and went with that. 1 3/4 primaries into 2.5 collectors. Thought about long tube but just not worth what little gain you get on a somewhat stock engine.
Old 06-21-2015, 01:10 PM   #156
OneOffStroker
Originally Posted by dunce79 View Post
I see that you notched your crossmember like I did. Inside, I hope that you may have gotten the idea from my build thread, because then I can finally say that I gave something back to the community! haha
BTW, I like your build. This truck is gonna be sick!!
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 06-23-2015, 05:41 PM   #157
dunce79
Yep - I saw someone's notched crossmember on here and it served as inspiration : )
Old 06-23-2015, 05:56 PM   #158
CMACDONALD1
CMACDONALD1's Avatar
Yeah I had to notch my crossmember as well. I have a c notch about the same as your. The drive shaft only rubbed under hard acceleration and at first I thought it was wheels rubbing. Glad I got that figured before I had a major problem.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts.
1972 Cheyenne Short Bed
1958 Apache short fleet
1980 Chevy short bed
http://67-72chevytrucks.com/vboard/s...d.php?t=761005
1959 "Henry"
http://67-72chevytrucks.com/vboard/s...d.php?t=670461
1966 Biscayne
http://67-72chevytrucks.com/vboard/s...d.php?t=444419
1972 Suburban
http://67-72chevytrucks.com/vboard/s...d.php?t=478828
CMACDONALD1 is offline   Reply With Quote
Old 06-23-2015, 06:06 PM   #159
dunce79
Long time no update.. lets remedy that...
6x9s in some custom cab corner closeout panels
decided to change the shifter from lokar to B&M quick silver. The classic look of the lokar is nice but its operation sucked ( in my opinion ) and I like the ratchet action of the B&M.
mocked up radiator ect
test fit hood
mock up ac and condensor ect
faux snakeskin material for interior, teakwood
custom mount for PCM
since this thing is staying in bare metal for the summer I painted the window channels to keep the rust at bay once the glass is in
painted the inner fenders and backside of grille surround
Old 06-23-2015, 06:13 PM   #160
CMACDONALD1
Looks great! nice detail work. Is it going to stay satin black under the hood?
1959 "Henry"
1966 Biscayne
1972 Suburban
Old 06-23-2015, 06:24 PM   #161
dunce79
Yep : ) not really going for show with this one.. more go and just have fun with it.
Old 06-24-2015, 01:09 AM   #162
Kim57
Kim57's Avatar
Looks great.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-24-2015, 01:59 AM   #163
Nut Case
Nut Case's Avatar
Dunce should not be on the same page with your work, you are way better than that. The speed and quality is astounding. When I grow up I want to be just like you. Just read the whole tread, oh my! I'm headed down the same rabbit hole as you have done. Just hope Grace Slick is there and handing out those special pills. My project is 57 GMC Stroker 496 Gen 6 block, 6L90, Full C-4 on shockwaves. Not slammmed, 6-7 frnt bumper with +2-4 " rake. I need 17" rim to clear vett disk calappers. Still need so meat in the sidewall. with your permission i I'd like to PM you for further information. Thanks
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 06-24-2015, 09:57 AM   #164
BIGglaSS
BIGglaSS's Avatar
Dunce, very nice work! I will also be stealing your x-member, seat belt, and battery access mods. I was wondering what radiator and fan? My heater hose ports are too close to the upper control arm. Did you have to modify to make them fit?
BIGglaSS is offline   Reply With Quote
Old 06-24-2015, 10:31 AM   #165
dunce79
Radiator is from Champion Radiators. They have a website and ebay store, also used their shroud but I didn't like how it fit all the way around the rad so I cut the sides off a bit and screwed it to the mounting flanges on the rad. Fan is a Flexalite Syclone 16 inch. It pulls 2500cfm and I've used it before on a camaro with 383. It doesn't even have a shroud and it keeps the camaro cool so I have some confidence in it. Not sure on the rad yet though - haven't tested it out of course.
To get around the heater hose problem I used some heater hose with molded in 90 degree bends at the water pump and just ran it forward and up/around the ac compressor. Probably cleaner ways to go like routing the stuff on the other side of the fender or I think you can pull those fittings out of the water pump and thread in actual 90 degree or AN fittings if you like. But I was after quick/simple and functional without looking shoddy. I may eventually use some gates heat shrink clamps on the hoses after I get through through whatever bugs await me during/after the first start.
Old 06-25-2015, 01:43 AM   #166
Nut Case
Nut Case's Avatar
Dunce Where did you get the sheet metal replacement parts? Sorry if you have already posted earlier in your thread.
Thanks NC
Old 06-25-2015, 06:29 AM   #167
bowt1ed
Hey Dunce, what model number CPP booster/master did you use? Disc/disc? Any issues with mounting bracket? Thanks, Jim
bowt1ed is offline   Reply With Quote
Old 06-25-2015, 10:01 AM   #168
BIGglaSS
BIGglaSS's Avatar
Thanks for the info!
Old 06-25-2015, 10:12 AM   #169
62 Barnfind
62 Barnfind's Avatar
Nice work!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 06-25-2015, 11:07 AM   #170
dunce79
I think I bought most everything from Tuckers, Classic Parts or Mar-k. If you need to know part specific source let me know.
Thanks NC
Old 06-25-2015, 11:09 AM   #171
dunce79
No issues, only hard part is getting that old support outta there : )
Old 06-25-2015, 11:13 AM   #172
dunce79
Anyone know where to find the glass lock bead installer tool that has a roller on it? The cheapy I bought just scratches the chrome plating off of the bead.. has no roller. I've never seen one but a local body guy here has one but can't currently find it.
Old 07-29-2015, 05:49 PM   #173
dunce79
Update time..
Seat, headliner and door panels upholstered (haven't installed the panels yet though)
wiring pretty much done except for AC/heat
modified the stock LS1 harness from the 02 camaro and remove all the stuff I didn't need. That was a good time ; )
Fired up for the first time, first attempt it popped right off. Friggin amazing.
Short first test drive under my belt, gunna be a lot of fun
started working on the bed
Hoping to be done enough to get it to a car show in a couple weeks.
Old 07-29-2015, 06:19 PM   #174
Rods57
Rods57's Avatar
Wow that look great.
Rods57 is offline   Reply With Quote
Old 07-29-2015, 06:41 PM   #175
Advanced Design
Looking very very nice!
