Old 09-12-2023, 11:30 AM   #151
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: Project "Buffalo Blizzard Surprise" 71 SWB build
Time to work on assembling the Ford 9" rear end.
Here is the axle with one of the emergency brakes installed
Axle shafts painted and ready to install
Assembling the rotors and hats
One of the rotor assemblies installed
Rear end is complete with rotors, calipers and brake pads installed
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 09-12-2023, 11:38 AM   #152
derotoreut
derotoreut's Avatar
Now on to the front end.
Installing the wheel studs into the Mustang II hub assembly
Mustang II drop spindle
Assembling the front rotor and hat
Passenger side brakes complete
~ Dan
Old 09-13-2023, 05:44 PM   #153
derotoreut
derotoreut's Avatar
Installed the Ford 9" and coil overs into the truck.
~ Dan
Old 09-27-2023, 10:51 PM   #154
derotoreut
derotoreut's Avatar
Time to lay out the bed cross sills, so I can get bedsides installed.
~ Dan
Old 09-27-2023, 10:57 PM   #155
derotoreut
derotoreut's Avatar
Bedsides are now installed.
~ Dan
Old 10-01-2023, 08:30 PM   #156
derotoreut
derotoreut's Avatar
More body work on the bedsides completed.
~ Dan
Old 10-01-2023, 08:40 PM   #157
derotoreut
derotoreut's Avatar
All of these body mods are pretty much complete and ready at this point.
~ Dan
Old 10-01-2023, 08:44 PM   #158
derotoreut
derotoreut's Avatar
Roofline, drip rail and gaps are complete.
~ Dan
Old 10-02-2023, 09:52 AM   #159
loudchevy
Active Member
loudchevy's Avatar
Super nice build. Love your shop addition. It's gotta be nice to have the dirty and clean sections to work in.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 10-02-2023, 12:13 PM   #160
derotoreut
derotoreut's Avatar
Thanks very much. I won't kid you... I love having both sides to do work in. My wife said "we're not going to be snowbirds and go down south for the winter" because all of our family is nearby. So I told her then I need something to do during the Buffalo winters here. Because of that she agreed to the workshop addition. I definitely made out on the deal.
~ Dan
Old 03-14-2024, 09:08 PM   #161
derotoreut
derotoreut's Avatar
Well after a big delay and no time to post, I'm back at it again. I want to get this build thread caught up.
Time to marry the 4L70E to the LS3
I bought the Holley Mid Mount accessory drive system. Got that all put together and installed on the engine.
Engine and transmission installed into truck
~ Dan
Old 03-14-2024, 09:26 PM   #162
derotoreut
derotoreut's Avatar
I ended up having a leak with the Lube Locker gasket set in my Ford 9". Had to tear it apart and reinstall it using good old Permatex Gear Oil gasket maker. Got the center member installed and rear end back together.
Tear down and remove the Lube Locker gasket
Re-installed the 9" center member.
Ford 9" back together.
~ Dan
Old 03-15-2024, 08:51 AM   #163
derotoreut
derotoreut's Avatar
Finally got the truck fully assembled and made it a "Roller". It's been a long time coming and it's finally on some wheels. The only thing is I'm not happy about the stance and the rake it has at this point. Hopefully some adjustments can be made with the coilovers to bring the rear end down.
Finally a roller on wheels, but the stance needs work
~ Dan
Old 03-15-2024, 08:54 AM   #164
derotoreut
derotoreut's Avatar
Here is the truck in the front part of my shop. Fully assembled and in roller form. The next big step is coming up. Stay tuned....
~ Dan
Old 03-15-2024, 08:38 PM   #165
zicc1835
zicc1835's Avatar
NICE WORK ill stay tuned
zicc1835 is offline   Reply With Quote
Old 03-16-2024, 07:16 AM   #166
72 tigger
72 tigger's Avatar
To be continued….
I’m watching with my bucket of popcorn!
Nice progress
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 03-16-2024, 03:53 PM   #167
1972CheyenneSuper
1972CheyenneSuper's Avatar
Great progress so far! I'm along for the rest of the ride. FYI, if you are doing a factory dashpad and getting a reproduction, you may want to test fit it now to see if you have to slot the holes any. It's definitely doable after paint and windows though. Hindsight being what it is, it would've been a lot easier at this stage before paint.
EDIT* Well, I just went back and read this whole thing. Gotta say this lift point is pretty nifty. Is it something you made?
Originally Posted by derotoreut View Post
Now that the fender modification is complete. I moved the truck back to the cleaner part of my shop to set the engine back in for some fit up.
1972CheyenneSuper is offline   Reply With Quote
Old 03-29-2024, 07:05 PM   #168
derotoreut
derotoreut's Avatar
Thanks for the heads up. I'm planning to use the factory dashpad, so I know it fits. I'm just planning on having it recovered.
The lift arm was made by a friend of mine. I came up with the design and he built it. He has some pretty sophisticated machining capabilities in his business. Worked out great.
~ Dan
