Old 06-04-2015, 09:33 PM   #151
0311Chevy8152
Re: 1972 K10 Disabled Veteran First Build
So, two days ago I beat the body lift blocks and I thought I was in the clear going to make progress. That's until I met this little guy:
We have been fighting for two days so I did this:
and used this:
and I won:
But I did notice both cab corners are being rub against by the bed:
0311Chevy8152 is offline   Reply With Quote
Old 06-04-2015, 11:03 PM   #152
First c10
First c10's Avatar
I have one like this. They work great for stubborn bolts and screws.
Man you are taking that thing apart. Wow I haven't done that yet.
Hammer down my friend!!!
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 06-04-2015, 11:07 PM   #153
0311Chevy8152
Man I totally forgot about that tool. Used one a long time ago and thought then how I wanted one. And yes I'm taking it apart as far as I can. I want to be able to put it together and know it's ready for another 40 years.
Old 06-06-2015, 05:45 PM   #154
0311Chevy8152
I finally conquered the bed. If now I only had someone to help me get the floor pulled outside. That thing is heavy. Everything else I've been able to handle alone. And it's awkward being flimsy in the middle.
Old 06-06-2015, 11:08 PM   #155
0311Chevy8152
Nothing prettier than a new tool in the sunset.
Old 06-06-2015, 11:23 PM   #156
Xeen
Xeen's Avatar
Nice, that's one rig every mechanic should own.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 06-06-2015, 11:34 PM   #157
Ozzy2013
Ozzy2013's Avatar
Doing a great job!
Ozzy2013 is offline   Reply With Quote
Old 06-07-2015, 11:52 PM   #158
DWilbur
Thats the same cherry picker I have they work great for the price can't complane
DWilbur is offline   Reply With Quote
Old 06-09-2015, 09:53 PM   #159
0311Chevy8152
I had the dogs buid me a cab dolly. I think they did an ok job. Have to see how it works to know for sure. One way or the other the cab is coming off soon.
Old 06-10-2015, 10:17 PM   #160
0311Chevy8152
Just have to disconnect the two shifters and the cab should be ready to come off. I'm trying to figure out how logistically. The area that the truck is in is not wide enough for me to be able to lift the cab and wheel it away. So I either lift it up and push frame out from under it, or push it out and than take off the cab. Either way I doubt I'm going to be able to push it back in on my own. So decisions, decisions.
Old 06-11-2015, 04:10 PM   #161
DWilbur
I have seen some members use cherry picker with 4X4 frame on top of the lift that would pivot on the lift run the 4x4 frame through the door opening and lift the cab off then roll the frame out from under it. the lift should be center in the cab front to back and side to side.
Old 06-17-2015, 12:45 AM   #162
0311Chevy8152
My neighbor pulled through for me an hour ago and stopped by with his tractor. We successfully removed the cab. Nothing dropped or bent as far as I can tell. The first couple pictures are from me holding the strap with one hand and taking a picture with the other.
Old 07-07-2015, 11:49 PM   #163
Ozzy2013
Ozzy2013's Avatar
Looking good!Wish i would have made cart for mine i used a little wobbly mess of one and the cab tilts every time i move it!ha ha
Old 07-07-2015, 11:56 PM   #164
Xeen
Xeen's Avatar
Any updates?
Old 08-03-2015, 07:38 PM   #165
0311Chevy8152
I'm alive!!! Survived some personal issues and getting back on track. The machine shop was a waste of time and money so I'm back to searching for an engine. This will sound pretty uneventful for most but today I removed my first engine and transmission. I didn't break anything on me, the truck, or the engine so I'm feeling pretty proud of myself. Couple things I will remember the next time, I didn't drain the transmission prior to disconnecting it, made a mess, and didn't start out with the leveler all the way towards the transmission, that little handle is hard to turn with the weight on it on one end. Hopefully I'll be back to making some progress.
Old 08-24-2015, 07:14 PM   #166
0311Chevy8152
Getting closer. There has to be an easier way to change a tire!
Old 08-25-2015, 10:45 PM   #167
swamp rat
swamp rat's Avatar
Clever use of the engine hoist! Keep on making headway!
Last time i pulled a 205 T case i did it without a jack while under the truck, that was one hurtin mother let me tell you.. I couldn't do that today.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-26-2015, 10:11 AM   #168
72again4x4
72again4x4's Avatar
What type of output brake is that on the 205? Just wondering if it's a kit or the PO built something.
Thanks,
Roger
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears
72again4x4 is offline   Reply With Quote
Old 08-27-2015, 06:37 PM   #169
Tylerz181500
im curious as well and as to why?
Tylerz181500 is offline   Reply With Quote
Old 08-27-2015, 06:47 PM   #170
0311Chevy8152
It is the e brake. The PO installed a disc and mechanical caliper off a cushman truck.
Old 08-27-2015, 07:31 PM   #171
72again4x4
72again4x4's Avatar
Thanks Nathan, was wondering. Looks like a pretty clean setup. Might have to look into that when I convert the rears to disc.
Old 08-27-2015, 10:24 PM   #172
DWilbur
That E brake looks like the one I installed on my Atlas T-case. I forget who I ordered it from. google transfer case parking brake and sever companies pop up.
Old 08-27-2015, 11:44 PM   #173
swamp rat
swamp rat's Avatar
There are a couple aftermarket places that do a output disk setup, i got them bookmarked at home.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-28-2015, 11:21 AM   #174
TommyDuncan
Just read this whole thread. I just bought a 71 K10 to slowly build into a do it all rig also. It has an Sm 465/350 and my thoughts are Holley fuel injection, NV4500 and beefier axles.
Right now I have a newer Jeep and truck so I want to build a 4x4 truck to replace them both.
...anyways I have always had a Jeep to wheel all over the southwest. I'm hoping this will work just as well. A buddy used to go in his 76' K5 Blazer and it worked well. If this is the kind of thing you are building your truck for lemme know. You (or anyone) is welcome!
NW rim near Copper Mountain mine
TommyDuncan is offline   Reply With Quote
Old 08-31-2015, 10:06 PM   #175
0311Chevy8152
Anyone know what these studs are for? Other than looking studly. There are three of them all on the drivers side front axle. I know the axle is a Dana 44 but other than that I'm not sure. Any advice on what I should keep and what I should replace as I start the rebuilding process would be great. Whoever put together the passenger side hub forgot one of the locking clips. I'm glad I'm going through the whole truck. I have found too many things that have made me say "I'm glad I found that now."
