Old 01-12-2018, 02:57 AM   #151
findog78
Re: Another way to skin the cat; the High Torque 292 LS swap
Originally Posted by dayj1 View Post
and more...
That fuel set up is sweet! I've been reading through this forum for weeks reading up on on how to do the fuel return issue for EFI. That's the cleanest one I've seen to keep my tank. Where do I buy all those pieces?
findog78 is offline   Reply With Quote
Old 01-12-2018, 03:58 AM   #152
findog78
Well I found the Tanks, Inc link in your thread. Where would I get the electrical lead pieces for the bulkhead? Thanks.
Old 01-12-2018, 10:05 AM   #153
aggie91
I'm just glad to be here!
aggie91's Avatar
I think he made his own, but here are a few links of a quick online search...
https://www.efihardware.com/products...head-terminals
http://www.vpw.com.au/Category/Index/340230
https://rebling.com/product/copper-bulkhead/
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-12-2018, 10:33 AM   #154
solidaxel
solidaxel's Avatar
Just make sure you secure the bolt on the inside of the tank "in case the other guy removes both nuts" to tighten the wire lug on the post!
I am open to suggestions on what to use in a wet fuel environment
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-12-2018, 01:36 PM   #155
dayj1
Tanks, Inc (as you found) for the mounting ring parts. They sell the parts for far less than I value my time
I buy the tubing at NAPA because they're the only local supplier that sells tubing that isn't coated and I think the zinc plated steel and/or Nickel-Copper line looks more period correct on an old car/truck.
I buy almost all of my fittings at http://fittingsandadapters.com That's where all the tube nuts and JIC (AN) fittings came from.
I made the electrical bulkhead and replacement fuel sender plate on my lathe because the price for fuel bulkheads from any supplier that I've found is ridiculous for what they are. It's made of nylon which isn't affected by gasoline.
Correct
The bulkhead is threaded such that the stainless stud is screwed into/through the nylon. I get what you're saying, but someone would really have to try to screw it up even if they removed the locking nut. That said, nothing is fool-proof when you have a sufficiently talented fool.
dayj1 is offline   Reply With Quote
Old 01-12-2018, 02:13 PM   #156
SCOTI
SCOTI's Avatar
.....The bulkhead is threaded such that the stainless stud is screwed into/through the nylon. I get what you're saying, but someone would really have to try to screw it up even if they removed the locking nut. That said, nothing is fool-proof when you have a sufficiently talented fool.
This is soooooo true. It sucks too. We have to create SOP's @ the manufacturing plant where I work for equipment operation, cleaning, & adjustments.
The 'sufficiently talented' group you speak of constantly create (force?) revisions w/these SOP's.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-21-2018, 04:51 PM   #157
buddylee
Why can't I see the pictures
buddylee is offline   Reply With Quote
Old 02-21-2018, 08:51 PM   #158
mongocanfly
Post Whore
mongocanfly's Avatar
he used photosucker for his pics...there's something you can do with your computer that allows you to see them but I'm no computer guru and I don't understand it...put (photobucket) in the search...we have a thread on it how to fix it...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-21-2018, 09:15 PM   #159
mongocanfly
Post Whore
here's a couple I have handy of his setup
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-22-2018, 10:44 AM   #160
gringoloco
A guy with a truck
gringoloco's Avatar
Few more. I have lots on my computer. Best swap ever...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-22-2018, 01:21 PM   #161
sprint_9
sprint_9's Avatar
I wanted to add that the radiator hose information was spot on. I crossed those numbers to a Gates hose and it worked great on my truck. Saved me a bunch of searching.
sprint_9 is offline   Reply With Quote
Old 02-22-2018, 11:30 PM   #162
dayj1
PhotoBucket quit supporting third party hosting a while back and created broken links across the interweb, I've attached an overall shot of the motor below.
Originally Posted by gringoloco View Post
Best swap ever...
LOL. Thank you for the kind words!
I'm glad it helped.
Old 07-18-2018, 09:54 PM   #163
garmar
garmar's Avatar
Awesome build!
As to the great Photobucket debacle, there's an extension you can add if you are using Chrome Browser called Photobucket embedded image fix. It works great and I've had zero issues with it for over a year now.
garmar is offline   Reply With Quote
Old 10-21-2018, 12:10 PM   #164
jjzepplin
jjzepplin's Avatar
Just read through this and it gave me goose bumps. (is that ok?) That is one beautiful setup! So you could run a carb with a MAF sensor adapted on top of it? I have a 99 TA 5.7 and T56 I want to put in my 72 Blazer. I am probably going to use the stock harness. Man those wires are intimidating! I redid both harnesses on my trucks using stock stuff and that scared my neighbors (HAHA)!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-21-2018, 07:26 PM   #165
dayj1
Thanks!
That could work. You'd need to block the fuel inlet(s) and you'd need a TPS sensor adapted to your carb. The tune would be a bit more difficult. Enough so, that, if I were using a carb as a TB, I'd probably just go speed density and skip the MAF altogether.
Old 10-22-2018, 10:43 AM   #166
ls1nova71
ls1nova71's Avatar
Glad to see the pictures are back! Any idea why?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-22-2018, 12:20 PM   #167
mongocanfly
Post Whore
I've been wondering about pics as well....I'm not seeing the pb crap anymore anywhere.....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-22-2018, 02:45 PM   #168
gringoloco
A guy with a truck
gringoloco's Avatar
Shhhhhh... we shouldn’t mention it, else they may disappear again... Save ‘em while you can.
-Chris
Old 01-29-2019, 12:26 AM   #169
Dads79GMC
Dads79GMC's Avatar
dayj1, I ran across your thread in the middle of receiving ordered parts for the same type build (just a couple nights ago). I love the way you did the MAP on the TB!! My one question is this; what did you do with your Intake Air Temperature (IAT) sensor? My tune is a speed density closed loop. On newer MAF sensors, the IAT is a part of that component.....based on my research.
Your thread has helped enormously, thank you. I plan on doing my MAP just like you did.
Below is a pic of the factory location of my IAT. Help
Thanks Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 01-29-2019, 12:44 AM   #170
dayj1
Thanks Mike
Thanks for the compliments! My IAT was built into the MAF, but you could just put it in the base of the breather (with the sensor element inside the breather). The factory IAT grommet should even work for a clean install.
Old 01-29-2019, 12:47 AM   #171
Dads79GMC
Dads79GMC's Avatar
I truly appreciate the quick response!!! I think I've got it figured out now The grommet recommendation is a great idea!!! I had another question but just had a senior moment!!! Thanks Mike
Old 01-29-2019, 12:48 AM   #172
ls1nova71
ls1nova71's Avatar
ItHis truck has a MAF sensor mounted under the Intake so the IAT is mounted in that. On mine I went SD so I added the sensor to the underside of the air cleaner.
Old 01-29-2019, 12:50 AM   #173
Dads79GMC
Dads79GMC's Avatar
Perfect! What I'm doing is in the 78 link below....critiques are welcome. Thanks for the help fella's. Mike
Old 01-29-2019, 01:00 AM   #174
ls1nova71
ls1nova71's Avatar
I tried to find a pic of mine but cant find one. I took an IAT out of a late 90's gm car and put it in a grommet like Jonathan mentioned.
Old 01-29-2019, 01:27 AM   #175
Dads79GMC
Dads79GMC's Avatar
Now I remember! How are your truck injectors working in the fuel rail and intake. I did the same thing as you and cut-down the LS1 brackets. Great idea! Mike
